The James Webb Space Telescope
546 replies · 80K views · last reply
T+3 weeks
Where is Webb added a mirror position tracker. The launch position was -12.5 mm, the nominal position is 0 mm. The mirrors move by about 1 mm per day, except A6 and A3 which will be moved separately later. About a week to go for most segments.
The cold side is now below -200 C.
Edit: I found an expected cooldown timeline
That's some very low gearing, I think. But things, in space, tend not to be intuitive.
The actuators move in steps of a few nanometers - the precision needed for the mirror alignment. A centimeter is millions of steps. To keep the operation simple they move one at a time, too.
Sure, it would have been possible to add some extra actuators for the coarse alignment, but it would have been useless extra complexity. Cooling down JWST will take longer anyway, two weeks to move the mirrors is not an issue.
-5 mm
-5 mm
so when fully deployed, the viewing time is scheduled based to some extent on the direction the telescope points as the Earth orbits the sun? What about pointing the thing perpendicular to the orbital plane? That would take weeks to accomplish?
No. The whole telescope/sunscreen rotates driven by reaction wheels. This can happen quickly. At any point in time it can see nearly half the sky. See the pictures I posted in post #117.
Most mirrors have reached their nominal position, A3 and A6 have moved by half of the distance.
NASA's 1 mm/day estimate was very conservative.
And soon, the L2 insertion burn will be occurring - 94% of the way there today.
So, what is Webb doing today? Where is Webb says it arrives at L2 with a velocity of 0.135 mi/s around 2pm EST. I've googled and found conflicting answers about whether there is a burn. Is there one?
It would need to have a thruster pointing "up" to do a burn to slow down, but wouldn't that be generating a lot of heat on the "cold" side?
https://www.republicworld.com/scien...-before-orbit-insertion-read-articleshow.html
https://space.stackexchange.com/questions/57702/james-webb-orbit-insertion
I see this from NASA.
https://blogs.nasa.gov/webb/2022/01/21/webbs-journey-to-l2-is-nearly-complete/
"On Monday, Jan. 24, engineers plan to instruct NASA’s James Webb Space Telescope to complete a final correction burn that will place it into its desired orbit, nearly 1 million miles away from the Earth at what is called the second Sun-Earth Lagrange point, or “L2” for short."
Houston, we have L2 Orbit. Flawless!
Thanks, so my questions are:
1. What direction relative to the spacecraft was the burn? (where was the thruster?)
2. Did it generate heat that could be problematic for the cold (cooling) instruments?
In addition:
"Where is Webb" still shows a cruising speed of 0.1255 mi/s (presumably the orbital speed?) and quite a large curve to orbit insertion (graphical license or freefall path?). And what's the orbit diameter? What are the corrections going to look like (perpendicular delta-V?)
It came in sideways, the thrust was somewhat in the general direction of the Sun. It's a three-dimensional problem and thinking of just slowing down/speeding up isn't representing the geometry of the orbit. Here is a good 2D projection. The displayed velocity is probably the velocity relative to L2, which is non-zero as it orbits L2 now.
You might have been writing that while I was writing the prior post. That's the graphic I was referring to. So, it's fairly accurate? Googling for the topography of the Lagrange points, it is difficult to see how it is pulled into a roughly circular if unstable orbit (per the graphic). For example:
https://upload.wikimedia.org/wikipedia/commons/e/ee/Lagrange_points2.svg
Anyway, it hadn't occurred to me that the reported speed and distance weren't along the same line. Though I guess at first they were closer to it.
This site says that, "Webb's orbit is represented in this screenshot from our deployment video (below), roughly to scale; it is actually similar in size to the Moon's orbit around the Earth! This orbit (which takes Webb about 6 months to complete once)...". If we assume that the "orbit" around L2 is circular with a radius of 400,000 km (moon's orbit SMA is 380,000 km), and that it takes 180 days to complete, then the speed would be 0.16 km/sec, and its current speed is 0.20 km/sec. So it all makes sense.
In the same way as getting to the right distance without retro firing, starting off (early deployment) can give the craft the right 'lateral' velocity so that it will be doing 30 days' worth of 'corkscrew' motion on the way. It will ideally not lose any of that translational / orbital energy as it slows down due to (radial with respect to Earth and Sun) potential energy. If the orbit around L2 takes six months (?) then it will have done around 360/6 = 60 degrees of corkscrew on the journey and arrived 'hanging there' and gently moving around in a large ellipse.
(Yep. After a bit of brain ache and arm waving.)
Navigating is space does have some advantages in that there's no wind, air pressure or rain to deal with so it's more predictable.
You do have radiation pressure and solar wind. They can lead to larger trajectory uncertainties, especially with uncontrolled spacecraft . An old Falcon 9 upper stage might hit the Moon in March. It launched a NASA spacecraft to L1, somewhat similar to Ariane 5's launch of JWST to L2. People are studying it to get a better estimate. If it hits then the impact will be used to study the Moon, just like the many deliberate impacts in the past.
Ah yes. Solar wind does vary too. It will always be outwards tho’ and must affect station keeping a bit.
The way I heard it described was the launch rocket gave it slightly less velocity than was needed to reach the final orbit, so rather than turning around and thrusting to slow down (which would expose the mirror and instruments to the Sun’s heat), the final burn had to add a small amount of speed in the direction it was already moving (the telescope has been slowing down continuously relative to Earth since launch).
“Webb received an intentional slight under-burn from the Ariane-5 that launched it into space, because it’s not possible to correct for overthrust. If Webb gets too much thrust, it can’t turn around to move back toward Earth because that would directly expose its telescope optics and structure to the Sun, overheating them and aborting the science mission before it can even begin. “
https://blogs.nasa.gov/webb/2021/12/25/the-first-mid-course-correction-burn/
You know, it just dawned on me that I finally understand the Dune song:
I was sent to
outer space
To find another happy place
Now I'm left here all alone
Million miles away from home
It was about Webb! 😆
There is a new video out from Launch Pad Astronomy explaining the Web orbit really well (I think):
mfb said:
NASA released an alignment picture. 18 images of a star, one from each segment. They already know which image is from which segment. The alignment will put the star in focus in each of them and then move them all to the same spot.
This may not seem like much, but to me this is a huge step. It means the detectors are working and they are able to read out the data from the detectors and send it back to Earth.
They must be able to identify each mirror without 'turning off' the others. Wobbling it a bit is the only way I could think of. No wonder it's all taking a long time. It's going to be even more of a problem when all the images are in one place; wobbling will have a much more subtle effect when an image is in amongst all the others. A very painstaking system and (yet again) very impressive. Unlike Apollo, there is no room for any seat of the pants stuff here.
