The most difficult equation in mathematics
  • Level: Graduate
  • Thread starter Thread starter Demystifier
    Mathematics
62 replies · 25K views
Insights Author
What, in your opinion, seems to be (one of) the most difficult equation(s) in mathematics?
Here is my choice:
Find the solution ##k## of the equation
$$2^{\aleph_0}=\aleph_k$$
So what about finding k for any given m in [itex]2^{\aleph_m}=\aleph_k[/itex]?
Seems a nice challenge! Is it possible to give a more difficult equation than a given one?
Anyway, I think no such thing(most difficult equation) exists in mathematics. Or at least its existence isn't a trivial fact!
Shyan said:
So what about finding k for any given m in 2ℵm=ℵk 2^{\aleph_m}=\aleph_k?
It's a trivial generalization of the solution for ##m=0##. :D
I'm wondering which is harder! Finding k for a given m or finding m for a given k?
Has such a problem been solved in any of its cases?(or maybe in general!)(I was going to write 'considered' instead of 'solved' but I thought it surely is considered by someone! or not?)
Difficult and solved by traditional methods might be Fermat's Last solved by Andrew Wiles. Difficult and unsolved might be nonsense. How is difficulty measured, modus ponens ponendo?
Demystifier used "most difficult equation"! Those are proofs of facts. Of course proving things can become arbitrarily difficult. (EDIT: This is not trivial too!)
And about measuring difficulty. I don't think we need to get rigorous here. If a good mathematician says that something is difficult, Its enough for me to believe that thing is difficult. (I hope you don't ask for a definition of a good mathematician!)
The problem has been considered a lot. The most important result (by Cohen) is a proof that the problem is unsolvable by using standard axioms of set theory. Different non-standard axioms of set theory may lead to different solutions, but then the problem is how to know which axioms, if any, are the "right" ones?
For more details see
http://en.wikipedia.org/wiki/Continuum_hypothesis
I think you should use "desired" instead of "right"!
Anyway, why just use 2? We can generalize to [itex]n^{\aleph_m}=\aleph_k[/itex]. Right? Or there is some reason for that 2?
P.S.
Mathematical logic and set theory, or anything which seems that fundamental is really interesting for me but there lots of things to learn, and things with applications to physics have priority. A day will come that I'll learn those!:D
Of course there is. A set with ##n## elements has ##2^n## subsets. Since the set of integers has ##\aleph_0## elements, it can be used to show that the set of reals has ##2^{\aleph_0}## elements.
For a physicist friendly explanation of some basics in mathematical logic and set theory, including the origin of this basis ##2##, see
R. Penrose, The Road to Reality
Looks like I wasn't clear enough. Actually I meant Is it that we can only place 2 as the base, because of some features of aleph numbers, or its possible to put any other number as the base? Does that base have to be a natural number? An integer? Real?
Demystifier said:
For a physicist friendly explanation of some basics in mathematical logic and set theory, including the origin of this basis 22, see
I saw that book before. It was thick enough to make me think it contains much physics but I really didn't expect it to contain such a pure math subject! Thanks.
Here is my choice:
The continuum hypothesis says that k = 1. The continuum hypothesis is undecidable (Gödel theorem).
No, that's the Cohen's theorem. And it is only valid within the standard axioms of set theory, not within all conceivable set-theory axioms.
You can use any basis you like. But if you solve the problem for basis 2 (or for any other fixed basis larger than 1), other bases should not longer be a problem.
Anyway, this is not a topic about continuum hypothesis. I am sure there are also other candidates for the most difficult equation in mathematics. Any suggestions?
Solving any of the equations in this list in the most general case!(Sorry for ruining the chance for others but I want to emphasize my last sentence in post#2!)
These problems were and are also quite difficult to solve:
http://en.wikipedia.org/wiki/Hilbert's_problems
http://www.claymath.org/millennium-problems
A difficult problem that can be stated in simple terms: construct an algorithm that will find, if it exists, the general analytic solution of a first order ordinary differential equation y'=f(x), with f a specified (analytic) function.
Anyway, I think we can only sum up some unsolved problems in this thread. It is difficult to say 'this one is more difficult than that one, because it requires blabla theory' without a proper definition of what makes a problem 'difficult'.
How about $$y=\int dx\,f(x) + const$$
You're a genius!
I should have used a slightly more general first order ODE of course: y'=f(x,y).
You should still note that no single algorithm exists for finding the integral of a function, even if we exclude integrals which can't be expressed in terms of elementary functions(Oops...its not applicable to such integrals, right?). So finding such an algorithm is an open problem and it seems to be very hard.
bigfooted said:
You're a genius!
You are sarcastic. :)
That's much harder, I admit.
The solutions of differential equations mentioned above can always be found numerically, to an arbitrary precision. In that sense the differential equations are not really hard. But equation in the first post is really hard, in the sense that one does not even know how to find an approximate solution.
axmls said:
I'm sure the standard model Lagrangian is a contender: http://nuclear.ucdavis.edu/~tgutierr/files/sml.pdf
Though someone more well-versed than me may be able to elaborate on it.
If you mean varying it w.r.t. to all the dynamical variables to get all the equations of motion, I should say this is only a tedious thing to do. The algorithm for doing it is very well understood(So much that I won't wonder if there is a software able to do that), its just that its complicated and time consuming and messy calculation. So it isn't even a candidate for the hardest problem in math.
Haha, I don't even know what the solution is that we're looking for in most cases. Would many of these actually require multiple solutions? Some of these PDE's have multiple functions (and differentials thereof) with constraints on the equations; so I guess the first step, at least for me haha, would be to know what the solution would look like.
wow, thanks @Shyan , now I have yet another thing to eat up any possible free time I might run into (your link -> Heisenberg Ferromagnet -> spin wave -> ferromagnetism -> ? ...) ;)
When I saw the list the first time, I felt I know nothing!
Well, actually this isn't far from reality!
Well, if [itex]\alpha[/itex] is infinite, then there is no difference between [itex]2^\alpha[/itex] and [itex]n^\alpha[/itex].
The number [itex]x^y[/itex] can be defined as the number of functions from a set with [itex]y[/itex] objects into a set with [itex]x[/itex] objects. If [itex]y[/itex] is infinite, then this number is independent of [itex]x[/itex], as long as [itex]0 < x < \aleph_0[/itex]
