The most difficult equation in mathematics
  • Context: Graduate
  • Thread starter Thread starter Demystifier
    Mathematics
The discussion revolves around identifying what participants consider to be one of the most difficult equations in mathematics. The scope includes theoretical aspects of set theory, mathematical logic, and the continuum hypothesis, as well as broader considerations of mathematical difficulty and problem-solving.
  • One participant suggests the equation $$2^{\aleph_0}=\aleph_k$$ as a candidate for the most difficult equation.
  • Another participant challenges the notion of a "most difficult equation," arguing that such a concept may not exist in mathematics.
  • Discussion includes the generalization of the equation to $$2^{\aleph_m}=\aleph_k$$ and the implications of finding k for a given m.
  • Participants explore the difficulty of finding k versus finding m, questioning whether these problems have been solved or considered.
  • The undecidability of the continuum hypothesis is mentioned, with references to Gödel's and Cohen's theorems, highlighting the complexity of the topic.
  • Some participants express interest in the foundational aspects of mathematical logic and set theory, while others prioritize applications to physics.
  • There is a discussion about the base of the exponent in the equations, with questions about whether it must be 2 or if other bases can be used.
  • Several participants propose other difficult problems, including those related to Hilbert's problems and the P vs NP problem, emphasizing the challenge of defining mathematical difficulty.
  • The difficulty of solving first-order ordinary differential equations is also raised, with acknowledgment that no single algorithm exists for finding integrals in general.
Participants express a range of opinions on what constitutes the most difficult equation, with no consensus reached. Some agree on the significance of the continuum hypothesis, while others propose alternative equations and problems, indicating multiple competing views.
Participants note that the difficulty of mathematical problems can be subjective and context-dependent, with discussions about the limitations of definitions and the criteria for measuring difficulty.
This discussion may be of interest to those studying advanced mathematics, particularly in set theory and mathematical logic, as well as individuals curious about the nature of mathematical difficulty and problem-solving.
  • #31
i think the most difficult equation is
1 = 0.9999999...
  • #32
Sticking to equations, find a zero of the zeta function that is not a negative even integer, and whose real part is not 1/2. Or show there is no such solution. I mean, this problem looks like it just needs the right algebraic trick, but ...
  • #33
Here's the "hard" version of that problem.
Find a method that will find an integrating factor for the equation
$$f(x,y)dx + g(x,y)dy = 0 $$
which I believe has been proven to exist but according to Tenenbaum and Pollard p. 83 no general method is known.
Edit: Oh I see I missed that this was essentially posted on the 2nd page well I'll just leave it for the reference anyway.
  • #34
I stumbled about a generalization of the eigenproblem : find the numbers ai and the transformation of coordinates g such that gCg^-1=diag(ai) where C is an operator that is not forcedly linear.
  • #35
Is ai a matrix? Or just like a column vector?
Linkage?
  • #36
1+1=2
  • #37
Linkage?
I wrote it wrong indeed its gCg^-1(x1,...)=(...,a_i*x_i,...) where the x_i are the coordinates
  • #38
Are x and y allowed to be functions of another variable? I'm assuming not, because then the equation would be exact, and you could find a function M(x(t),y(t)) such that dM/dt = f(x,y)dx + g(x,y)dy.
I however don't see why this wouldn't be allowed in solving a differentiable equation (at least from a physics perspective, I think most variable quantities could be expressed as a function of time). Do I win?
  • #39
BiGyElLoWhAt said:
Do I win?
No, no I don't. I think I see the flaw in my logic there haha. It's pretty straight forward for simple functions, but gets really hairy really fast.
  • #40
For ##2^{\aleph_0}##can we say it is simply the set of all function from N to {0,1} but such a function is simply described by 0,d1d2... Which is the coding in basis 2 of the real numbers in [0;1] hence the comtinuum and hence equals to ##\aleph_1## ?
  • #41
Your statement is essentially the continuum hypothesis, that is ##C=\aleph_1##.
  • #42
In fact this i think proves 2^aleph0=c but we need to know if c=aleph1 the next cardinal.
But writing aleph0,1,... already makes the hypothesis that the cardinals are countable
  • #43
Err, the ordinals are uncountable, and the cardinals are indexed by the by the ordinals (under AC).
Writing aleph-0, aleph-1, ... is a transfinite sequence, not an ordinary sequence.
  • #44
Well I am not really good at set theory but the cardinals are well ordered but the ch is does there exist a cardinal between N and R ? And that's why cantor created his dust set to try to construct a set inbetween you think ?
  • #45
Assuming the Axiom of Choice, every set has a cardinality and there exists a well ordering of the cardinalities, yes.
The Continuum Hypothesis asserts that there does not exist a cardinal between ##|N|## and ##|\mathbb{R}|##.
Whatever Cantor's motivations for defining his ternary set, the fact that the Continuum Hypothesis is undecidable means that it is impossible to construct a set and prove that its cardinality is strictly between ##|N|## and ##|\mathbb{R}##. If such a set could be constructed and if such a proof were possible then the Continuum Hypothesis would be decidable.
  • #46
can it be proven that Ch is independent of the others axioms ? If yes then we could decide to set Ch as true or false and get two different set theories ?
In fact my question is stupid since if it were dependent we could prove it from the other axioms
  • #47
Keeping it "simple", how about ##y' = f(x,y)##?
  • #48
I feel like problems of this type just prompt the definition of special functions (see e.g. Bessel functions).
  • #49
The most difficult equation in math is [tex]\mathbf{P} \stackrel{?}{=} \mathbf{NP}[/tex]
  • #50
Yes, if N=1 :D
  • #51
Mentallic said:
Yes, if N=1 :D
Or P = 0
  • #52
How About finding the configuration of charges minimal that is stable in electrostatics (i just invented that one)
  • #53
Well I am not sure what you mean by most difficult equation in mathematics. Any differential equations that needs computers to solve (have no analytical solution) seems "difficult". An example are the coupled Boltzmann equations for the Big Bang Nucleosynthesis (it's fresh in my mind).
  • #54
Mentallic said:
Yes, if N=1 :D
It can as well be [itex]N=P[/itex] if [itex]P[/itex] is idempotent. Eg the projection operators when written in matrix representation satisfy that [itex]P^2 =P[/itex]
  • #56
You can also build a semi group where 1+1=1 it is just a matter of symbols we use to describe the operations.
  • #57
Demystifier said:
Ah, but take a look at your post here:
Demystifier said:
The problem has been considered a lot. The most important result (by Cohen) is a proof that the problem is unsolvable by using standard axioms of set theory. Different non-standard axioms of set theory may lead to different solutions, but then the problem is how to know which axioms, if any, are the "right" ones?
For more details see
http://en.wikipedia.org/wiki/Continuum_hypothesis
Just like ##2^{\aleph_0} = \aleph_1## depends on the axiomatics used, so does 1+1=2 :-p
  • #58
Also, whether 1+1=2 is difficult depends a lot on your definitions of 1 and 2. It is certainly possible to find a definition where 1+1=2 is trivially true by definition. For example, in the Peano system, 1+1=2 can be very easily verified. The hard part is when 1 and 2 are taken as real or complex numbers. In that case, the definitions are much more complicated and do not allow for a trivial solution. And then there are other number systems such as the hyperreals or surreals which make things even more complicated! So the difficulty lies more in the number systems used than in the actual equation.
  • #59
Shyan said:
You should still note that no single algorithm exists for finding the integral of a function, even if we exclude integrals which can't be expressed in terms of elementary functions(Oops...its not applicable to such integrals, right?). So finding such an algorithm is an open problem and it seems to be very hard.
http://en.wikipedia.org/wiki/Risch_algorithm
  • #60
Demystifier said:
What, in your opinion, seems to be (one of) the most difficult equation(s) in mathematics?
Here is my choice:
Find the solution ##k## of the equation
What do you mean by difficult?
How about solving the Riemann hypothesis? This remains unsolved. The equation is Riemann zeta function = 0.
Solving the Laplace equation has inspired generations of research.
Solving the Heat equation has also led to generations of research.
The same holds for other PDE's e.g. Monge-Ampere equations, geometric evolution equations, the wave equation ...
The proof of Fermat's last theorem led to centuries of research. The solution shows that certain equations have no solution.
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 34 ·
10K
