The Mysterious Water Bottle: Uncovering the Physics Behind It
  • Context: High School
  • Thread starter Thread starter Einstein60
    Physics Water
The discussion revolves around the physics of fluid flow in a water bottle with a small hole at the bottom and a valve at the top. Participants explore the conditions under which water flows out of the bottle and the implications of air pressure in the system.
  • One participant describes the setup of a bottle with a valve at the top and a small hole at the bottom, noting that water flows out when the valve is open but stops when it is closed.
  • Another participant questions what happens to the air pressure in the bottle when the valve is closed and whether anything flows into the bottle when the valve is open.
  • There are requests for further explanation regarding the mechanics of fluid flow and air pressure in the system.
  • Some participants express frustration at the lack of detailed responses to their inquiries.
Participants do not reach a consensus on the explanations for the observed phenomena, and multiple viewpoints regarding the mechanics of fluid flow and air pressure remain unresolved.
There are limitations in the discussion regarding assumptions about air pressure dynamics and the specific conditions under which water flows from the bottle.
Einstein60
Today, I filled a bottle with water and I created a small hole beneath the bottle on the side. I realized that if I open the cock of the bottle, the water flowed out of the hole but if I close it, the water stopped flowing. WHY?
As I understand it, you have a bottle with an opening at the top and a valve on the opening.
You have added a small hole at the bottom (small enough so that air does not bubble in through it). You notice that when the top valve is open that the water flows freely out the bottom. But if you close the valve at the top, water no longer flows out.
If you leave the valve open at the top, does anything flow into the bottle through the opening?
If you close the valve, what happens to the air pressure in the bottle above the water if some water, hypothetically, continues to flow out the hole?
Can you please explain further
Can you answer either question?
No
  • Skeptical
Einstein60 said:
No
You will do better here if you make an effort. We're here to teach, not to spoon feed.
russ_watters said:
You will do better here if you make an effort. We're here to teach not, not to spoon feed.
Okay.
10K
  • · Replies 18 ·
12K
  • · Replies 17 ·
  • · Replies 29 ·
