The orbital eccentricity change of the Earth ?
The Earth's orbital eccentricity is decreasing at a rate of approximately -0.00004292 per century, indicating that the orbit is becoming more circular over time. This conclusion is supported by observations of other planets and their orbital solutions consistent with General Relativity. The analysis of these orbital motions reveals quasiperiodic oscillations in eccentricity and inclination, contributing to Milankovitch climate cycles on Earth and Mars. Key data was sourced from J. Laskar's 1988 study on the secular evolution of the Solar System.
  • Understanding of orbital mechanics and eccentricity
  • Familiarity with General Relativity principles
  • Knowledge of Milankovitch cycles and their implications
  • Experience with astronomical observation techniques
  • Research J. Laskar's "Secular evolution of the Solar System over 10 million years"
  • Explore the methods of measuring astronomical distances without radar
  • Investigate the implications of Milankovitch cycles on climate change
  • Learn about the Runge-Lenz vector and its application in orbital mechanics
Astronomers, climate scientists, and students of astrophysics interested in the dynamics of Earth's orbit and its climatic effects.
Bjarne
Can someone answer one, some or all these questions;
  • Is the orbit of the Earth right now getting more circular or more elliptical?
  • How much?
  • How can we be sure?
Astronomy news on Phys.org
The eccentricity of the Earth's orbit is decreasing at a rate of ~-0.00004292/century.
  • How much?
We can be sure based on observations and measurements coupled with predicted effects based on physics.
We can so far I know not measure the distance to the Sun because the Sun does not reflect radar.
So how accurate is “observation” ?
Very accurate, actually. The trick is not to observe the Sun directly, but to observe the other planets, and to find a self-consistent orbital solution from these observations that agrees with General Relativity. One can even test for departures from GR and for unmodeled mass.
Once one does that, one can extrapolate the planets' motions several million years both forward and backward. When one does that, one finds that the planets' orbit orientations do loop-the-loops, and that their eccentricities and inclinations oscillate quasiperiodically. This leads to Milankovitch climate cycles on the Earth and likely also on Mars.
In particular, I've plotted
Eccentricity / Runge-Lenz vector: {e*cos(w), e*sin(w)}
Inclination / north-pole vector: {sin(i)*cos(W), sin(i)*sin(W)}
for the last several million years.
I've made videos for YouTube:
http://www.youtube.com/my_playlists?p=D0825FC30A2F00A6
http://www.youtube.com/my_playlists?p=86F2CCA7F3F677ED
I got the numbers from here:
J. Laskar
Astronomy and Astrophysics, 198, 341-362 (1988).
http://adsabs.harvard.edu/abs/1988A&A...198..341L
I had to OCR the numbers and then painstakingly correct the OCRing, so there might still be some typos.
There are direct observations that can be made to determine the distance to the sun. We don't need to reflect radar off of it.
See here for more info. http://curious.astro.cornell.edu/question.php?number=400
(Further down is how the 1st astronomers measured the distance to the sun)
  • · Replies 19 ·
  • · Replies 28 ·
