The orgin of the superposition principle of electric field
The superposition principle of the electric field is fundamentally based on the linearity of Maxwell's equations, as outlined in Jackson's Electrodynamics. The principle asserts that the electric field resulting from multiple sources can be calculated by vectorially adding the individual fields, which is mathematically represented by the divergence operator in the context of Gauss' law. This linearity ensures that the net electric field is equivalent to the sum of the individual fields, reinforcing the concept that forces can be added together in a linear system.
  • Understanding of Maxwell's equations
  • Familiarity with Gauss' law
  • Basic knowledge of vector calculus
  • Concept of linearity in physics
  • Study the implications of linear Maxwell's equations on electromagnetic theory
  • Explore the mathematical foundations of the divergence operator in vector calculus
  • Investigate the relationship between superposition principles in different physical contexts
  • Examine the differences between linear and nonlinear systems in physics
Physicists, electrical engineers, and students of electromagnetism seeking to deepen their understanding of the superposition principle and its applications in electric fields.
feynman1
Isn't the superposition principle of electric field just force being addable? Jackson's electrodynamics says it's based on the premise of linear Maxwell's equations. Which support(s) the superposition principle?
If something is linear, e.g. Gauss' law, then $$\nabla \cdot (\mathbf{E}_1 + \mathbf{E}_2) = \nabla \cdot \mathbf{E}_1 + \nabla \cdot \mathbf{E}_2$$ So really if you have ##\nabla \cdot \mathbf{E}_1 = \frac{\rho_1}{\epsilon_0}## and ##\nabla \cdot \mathbf{E}_2 = \frac{\rho_2}{\epsilon_0}## then you also have ##\nabla \cdot (\mathbf{E}_1 + \mathbf{E}_2) = \frac{\rho_1 + \rho_2}{\epsilon_0}##
It's the same principle that let's you superpose two solutions to the wave equation.
Thanks. I think you disagree with force being addable being the basis of superposition of electricity. If Maxwell's equations were nonlinear, forces would still be generally addable yet the vector sum of forces wouldn't be the correct net force, but rather just another force.
"Linear" is the technical term for "addable": f (a+b) = f(a) + f(b)
I'm not sure if I quite follow. The net force is the vector sum of all of the forces, that doesn't directly relate to Maxwell's equations. It's still always true.
You could apply the principle of superposition to forces at a point on an object too. If ##\vec{F}_1 = m\vec{a}_1## and ##\vec{F}_2 = m\vec{a}_2##, then ##\vec{F}_{net} = \vec{F}_1 + \vec{F}_2 = m(\vec{a}_1 + \vec{a}_2)##.
It's just two different ways of approaching the same thing.
Yes. So do you think linear Maxwell is exactly equivalent to net force being equal to the vector sum of forces?
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 73 ·
