The Physics of Length Contraction of physical objects and distances
The discussion centers on the concept of length contraction in special relativity (SR) and how it relates to different frames of reference. Length contraction is not a physical shrinking of objects but rather a frame-dependent measurement, where observers moving at relativistic speeds perceive distances and lengths differently. Proper length is defined as the length measured in an object's rest frame, while contracted lengths result from the observer's motion relative to the object. The conversation also touches on the causal structure of spacetime, emphasizing that while measurements may vary, the underlying physical reality remains unchanged. Ultimately, the complexities of spacetime geometry and its effects on measurements highlight the nuanced nature of relativity.
mikiel
I've been trying for a long time to get an answer to the question, "What is the physics or mechanical explanation of contracting physical objects and the distances between them?" I understand that the phenomenon is theorized to depend on different observations from different frames of reference going at relativistic velocities and contracting in the direction of travel of the observing frame. But how can different observations of the same object or distance change (shorten) that physical object or distance?
Example: Earth's diameter is nearly 8000 miles. Special relativity (SR) theorists claim that a frame approaching at .866c would measure its diameter (in the direction of the approach) to be about 4000 miles. But of course Earth's diameter would not actually physically shrink by half in that case, so how is the paradox resolved, given that all frames are said to be be "equally valid" in SR, and also that "length is not invariable" (it varies.) How is "proper length" (the 8000 mile diameter) reconciled with frame dependent length (4000 mile diameter) in this case?
As for distance between objects, same question... Example: The astronomically determined distance to the Sun (ave. AU) is about 93 million miles. But a frame theoretically passing through our solar system at .866c would, according to SR, measure the AU to be about half that. Yet Earth obviously does not move 46.5 million miles closer to the Sun.
I know that length contraction is the math reciprocal of "time dilation," but how can a slower ticking clock in that fly-by frame cut the actual distance to the Sun in half?
Ps: If that clock showed only 4 minutes elapsed time for the Earth-Sun journey, would that mean that SR claims that the frame (future ship or whatever) made the journey twice as fast as light... which requires 8+ minutes to go the 93 million miles.
I would very much appreciate help in resolving the above related time dilation and length contraction paradoxes.
Thanks.
As far as I understand it, there is no such thing as "real length" of an object in SR. Coordinate systems that differ by a Lorentz transformation are as equally valid as are coordinate systems that differ by a rotation of coordinate axes or a displacement of the origin.
Proper length of an object is its length measured in the object's own rest frame.
Because the observed length of an object, or the observed distance between two objects, depends on the observer, not just the objects.
This is really no different conceptually than the fact that the same object can have a different apparent size when viewed from different angles. A coin, for example, has a very different apparent width when viewed face-on than when viewed edge-on. In spacetime, moving at different speeds corresponds to viewing things at different angles (I think this is what hilbert2's comment was getting at). The only added twist is that the "angle" involves time as well as space, which is why there is time dilation as well as length contraction.
It doesn't shrink. In that frame it was always an ellipsoid with a minor axis of about 4000 miles. There is no shrinking involved.
I feel so bold approaching this from such a different angle (no pun intended lol)
PeterDonis's answer is awesome, & Dalespam is right, "shrinking" is a misnomer, and contracting takes on a different meaning. In other words shrinking and contracting are not synonymous in this context. and it's ALL about how we are measuring & what is being measured, so the coin analogy is a wicked perspective...very visually "revealing".
The universe is a causal system*, generally what this means is one thing causes another and in that order. Oddly it must be said that the future does not effect the present (or the past).
Every observer must agree on this order of "happenings". Long and short of it is speed must have a limit for this to work, but results in observer dependent measures of time/length.
What is neat is while the length of the planet changed, because of as you mentioned, the math reciprocal time dilation, really that spacetime calculation of "distance" across the planet hasn't changed at all. Causally everything is physically the same. But it absolutely is length contracted...[STRIKE]as in less length[/STRIKE].
I find from this causal perspective it's better to think of time dilation as being "more time"; as in taking more time for the next "physical occurrence" due to a "contracted" length. all caused by particular angles of view through 4D of these "happenings" via comparative motion/speed.
It's remarkable how little spacetime has to do with time dilation / length contraction. :biggrin: To clarify I mean that spacetime really doesn't seem to have any effect on matter. Perhaps more diplomatically, spacetime seems physically elusive
Thanks for the kudos, but unfortunately I'm going to have to respond by pointing out some things in your post that are, at best, misleadingly phrased.
This is ok, but one could also add that spacetime has a causal structure, determined by the light cones: two events can only be causally connected if they are in each other's light cones--the one that's in the other's past light cone is the "cause", and the one that's in the other's future light cone is the "effect". This gives the ordering you mention.
Yes, but note that this only applies to events that can be causally connected, i.e., within the light cones. Events that are outside each other's light cones (i.e., spacelike separated) have no invariant ordering.
Exactly right; it's a pity that you followed this immediately with...
nitsuj said:
But it absolutely is length contracted...as in less length.
...which, with the word "absolutely", gives absolutely (pun intended :wink:) the wrong impression. Length contraction is frame-dependent, not "absolute".
Not sure what you mean by this; the structure of spacetime certainly does have plenty to do with why time dilation and length contraction are observed. Your clarification doesn't help much:
This doesn't seem right, since the geometry of spacetime determines which curves are geodesics, which certainly does have an effect on matter.
Measuring spacetime curvature is just measuring tidal gravity, which isn't elusive at all. Measuring the "effect of spacetime" on an object's motion is just measuring its proper acceleration (i.e., whether or not it is moving in a geodesic, and if it's not, how much it's not, so to speak), which also isn't elusive. So I'm not sure what you mean here either.
Doesn't that go without saying :wink:?
I can't quite follow the light cone description or what it means to say they determine causal structure. Light-cone graphs / visuals are structured according to "rules". the units are not arbitrary, they are.. that is must be properly orientated. The elsewhere area is physically meaningless. A great example are the galaxies [STRIKE]fading[/STRIKE] breaking from causal connection due to spacetime expansion.
Pulling them out of our "direct" future! (hows that for poetic lol)Peter of course when you read the term length contraction you understand what I mean by the "modifier" absolutely before the term length contracted when the question is "is it really contracted". So from a causal perspective it absolutely is length contracted. Of course as is the underling assumption for this discussion, this is a frame dependent magnitude, which we absolutely do not mean proper length. I re-read what I wrote, I took it to far saying "as in less length", that is flat out wrong..i had to strike through it lol .
I was being tongue in cheek to a degree with spacetime not effecting anything, we measure the spacetime only between things.
Mass/energy effects spacetime, not the other way around. I would guess GR presumes/calculates spacetime is perfect (straight lines we all agree are straight) when "empty/void", boo if it is mathematical nonsense.
It is the "things" that seem to length contract, and dilate. We don't measure tidal gravity itself by measuring how it effects spacetime. Is tidal gravity a physical property? In other words your measurement doesn't explain what it is that's distorted. We presume it's spacetime that's distorted, and for good reason our clocks and rulers become comparatively distorted, but alas those are objects themselves and not some magic spacetime-interval-measuring-stick that isn't part of the continuum. And yes gravity is very evident. Note it's "fictitious" force label & how we have yet to detect anything physical about it. The most clear way for me to put it is spacetime is not a field, it's just geometry, kinematics. Other then that it leaves matter alone. Bottom line I truly think the "physical" nature of spacetime is perspective/opinion.
Kinematics does explain proper acceleration, and not that I know certainly, but would be surprised to learn spacetime could also explain proper acceleration.
Physically elusive refereed to my understanding of quantum gravity, standard model stuff.
EDIT: reading about causality on wiki, it says that in GR acceleration is not considered an effect...GR ha, more like grrrrrr :smile:
I don't know the definition well enough, is gravity part of kinematics?
Yea, my confidence in his replies says it does.
And what's great is even if someone takes a point of contention with him, he sees them to the end...most often until they understand him. A teacher with patience is a great teacher!
Just a quickie until I find more time to ask the forum to reply to the specifics of the apparent paradoxes as I presented them.
PeterDonis answered my question,..." how can different observations of the same object or distance change (shorten) that physical object or distance?"... saying:
"Because the observed length of an object, or the observed distance between two objects, depends on the observer, not just the objects."
But my question is how the physical length of objects (and the distances between them) is supposed to become shorter as a result of differences in observation... if in fact a "real world" exists and has inherent, intrinsic properties, as naturally formed and distributed in space, independent of differences in observational perspectives, i.e., frames of reference.
Or is it believed, with Einstein, that there is no "real world" independent of observation. In that case, what was the shape (diameter) of Earth and the distance to the Sun before any observers were present?
The real (physical) world is FIRST about invariants. calculations with measures the whole (local:smile:) universe can agree on i.e. get the same magnitudes/results/determination. One of these fundamental physical attributes is causality, for the whole (local:smile:) universe.
The physical important part is the actual "interactions" and spacetime interval between them.
We are not blobs of mass-less EM or "overly" dense mass so must measure a spacetime interval with length and time separately to calculate the interval I think c is the "conversion" for this unit:-p. Downside to living within the "speed is allowed" zone is it gives goofy measures of spacetime if there is comparative motion, length & time give different results, the interval is the same. Why? Because spacetime is physically even more simple than both length & time, causation. A concept nearly as simple as "things don't appear from nothing", but has remarkably deep consequences (differential aging).
It's merely about intervals between happenings. What a kick in the walnuts to my ol' friends Simultaneity, ruler & clock :smile: So what's physically important is how "it all plays out" not specifically where & when, makes sense when everything is all moving around with their different points of view lol
Thanks.
In the picture below two plates are moving to the right at speed 0.99999999999999 c.
There are also two static observers.
Code:
                                           o
                                          o
The plates emit light, because they are radioactive. The emitted light is beamed to the right, because of the high velocity.
http://en.wikipedia.org/wiki/Relativistic_beaming
The observers see both sides of the rightmost plate very well, because of the aforementioned beaming effect.
Therefore we can conclude that the left plate does not see the other plate very well.
The plate will say: "The other plate seems to be very far away."
I'm not seeing the question being directly addressed, or I'm missing something...
If I am touring the galaxy in my spacecraft and notice that a star is flattened, its planets are flattened, and their orbits appear to be flattened, that is going to strike me as interesting. When I park close to the system to take a look, I'll notice that the flattening is now absent. As I go on my way I'll see they appear flattened, again.
In order to believe that the flattening is "real" (not sure the right word to describe existential vs illusory), I would seek an explanation... for the cause of what appears to be a deforming variation of the gravitational field of each planet and their star - a deformation that varies in intensity and in its axis of bilateral symmetry based on my craft's speed and line of approach or departure orientation.
A revolving planet would appear to keep its plane of flatness normal to my line of sight in spite of its volume appearing to be displaced and squeezed in an amazing way to maintain the flatness orientation, likewise the star. I would expect both entities should be destroyed as well as the orbits, because I don't think Kepler's laws would be observed. From my perspective when in relative motion, it would seem like the laws going on around the star and its planets are "not holding good"...
I would be suspicious that things seem to settle down and appear fine when I park and observe at relative rest, yet appear to attach unreasonable physical measures and dynamics when observed in relative motion.
The heart of the question is; what lines of thought encompass all this without attributing the flattening and otherwise to "illusion", and how is the potentially infinite variety of observable deformations (frames wrt) reconciled? That is, what are the assumptions that must be made (and those that must be discarded) for the "normal" and the flattened views to be understood as coexistent without contradiction?
There is no contradiction between the physics in different frames, because all laws of physics are Lorentz covariant. If a process obeys laws of physics in one frame, then it does in all others, too.
There are "inherent, intrinsic properties, as naturally formed ... independent of differences in observational perspectives", but length is not one of those properties. Those intrinsic properties are called "invariants".
Likes 1 person
It cuts the measured moving distance in half, thanks to a difference in clock synchronisation. The essential point which Einstein stressed in his introduction in 1911, is that clock synchronisation is necessary for the measurement of moving lengths (in fact you can do without, but whatever you do still includes an assumption about distant time).
Ps: If that clock showed only 4 minutes elapsed time for the Earth-Sun journey, would that mean that SR claims that the frame (future ship or whatever) made the journey twice as fast as light... which requires 8+ minutes to go the 93 million miles. [..]
This is a matter of not mixing up reference systems: a light ray still goes faster, and will arrive before the ship - and for the light the trip even takes even zero time! (if light could observe and establish a valid or useful reference frame, which it can't). However, it is true that in that sense one is not hindered by the light speed limit, as our "time" is slowed down; as Einstein remarked in 1905, because of that effect the speed of light plays physically the same role as infinite speed (in classical physics).
mikiel said:
[..] But my question is how the physical length of objects (and the distances between them) is supposed to become shorter as a result of differences in observation... if in fact a "real world" exists and has inherent, intrinsic properties, as naturally formed and distributed in space, independent of differences in observational perspectives, i.e., frames of reference.
It only depends on the observer in the sense that the observer is free to choose the synchronisation according to convention and his/her choice of inertial reference system. That should not be confounded (as often happens!) with QM effects of "observation" (interaction with detector).
Yes - pre-relativity, length was an invariant, independent of the observer. Post-relativity, length is no longer an invariant, is is not a property of the object alone but depends on the object and the observer. If you have an object, but don't know who is observing it, you don't know it's length.
What is invariant, observer independent, and a property of the object is the Lorentz interval. As applied to length, this would be the "proper length".
They determine causal structure because no causal influence can travel faster than light.
If you pick any event, call it event E, the past light cone of E is the set of all events that can send a causal signal to E; obviously this set is bounded by the set of incoming light rays at E, hence the term "light cone".
Similarly, the future light cone of E is the set of all events that E can send a causal signal to; obviously this set is bounded by the set of outgoing light rays at E.
I'm not talking about visualizations or graphs or spacetime diagrams. The light cone structure of spacetime exists independently of all those things; it's an invariant part of the underlying geometry of spacetime.
Huh? There are certainly events there, and those events can emit causal influences that we can eventually detect. (Note that the "elsewhere" area is *not* the same as the region beyond the cosmological horizon--see below.) Similarly, we could have emitted causal influences in our past that are now being detected at events in our "elsewhere" region. The fact that there can't be a causal connection between a particular event's "elsewhere" region and that particular event in no way implies that the "elsewhere" region is physically meaningless.
As noted above, this is *not* the same as the galaxies being in our "elsewhere" region. There are (presumably--see below) events on the Andromeda galaxy's worldline in our "elsewhere" region that we will someday receive causal signals from; we just have to wait for a couple million years (by Earth clocks). I say "presumably" only because it is in principle possible that something could have happened to destroy the Andromeda galaxy after the last light signals we have currently detected from it were emitted; but would you care to give any odds?
OTOH, galaxies that are moving beyond our cosmological horizon are no longer able to send causal signals to us at all--not even if we wait for an infinite amount of time by Earth clocks. This is why the term "horizon" is used, and why it's a very different thing from just being spacelike separated.
Sorry, I'm still not buying it. What does "from a causal perspective" mean? What specific causal properties of the object are different when it's length contracted, compared to when it's not? (Btw, this is a trick question: the correct answer is "none of them". That's why I'm objecting. Length, or length contraction, is not a causal property; it can't be since it's frame-dependent, and causality is not.)
Really? There's no spacetime inside the Earth? Or inside your body? Or inside an atom? If so, then our theories of the internal structure of these objects need some serious revision, since they all assume there *is* spacetime inside the objects.
Huh? Spacetime does affect mass/energy, by telling it how to move (in John Wheeler's phrase). I don't understand what you're getting at here.
Sure we do. Take two rocks and hold them high above the Earth at slightly different altitudes. Then drop them in free fall (we're assuming we're well above the atmosphere so there is no air resistance). They are initially at rest relative to each other, but they don't stay at relative rest; their separation increases with time. This is a direct measurement of tidal gravity (one component of it, anyway) using its effect on spacetime--specifically, on neighboring geodesics of spacetime.
Sure. Why not?
You appear to be confusing tidal gravity with length contraction and time dilation. They're not the same. In my description of a direct measurement of tidal gravity, above, nothing at all was distorted except the neighboring geodesics described by the motion of the two rocks--i.e., spacetime. If you wanted to confirm that nothing else was distorted, put very sensitive strain gauges and accelerometers on the rocks and verify that they read zero throughout the experiment.
Really? I guess you've never fallen down. :wink: Also, tidal gravity is part of "gravity", and I described above how to detect something physical about it.
I think you are confused about a number of things; see above.
Huh? I don't understand the distinction between "kinematics" and "spacetime" that you're making here. Proper acceleration is just a measure of how far a particular worldline departs from being a geodesic, which is a property of spacetime. So I would say that "kinematics" and "spacetime" are really different ways of describing the same thing, or at least aspects of the same thing (at least, as you appear to be using the term "kinematics" here--see below).
I would say it depends on what part of "gravity" you are referring to, but on the whole, I would consider it part of dynamics, since it involves the Einstein Field Equation, which goes beyond kinematics as the term is usually used. However, I think all of these terms get used differently by different authors, so it's hard to be sure.
My personal usage goes something like this: "kinematics" refers to properties that can be defined and studied without asking any questions about causes. If you tell me an object is moving on a geodesic, that tells me certain kinematic properties of its motion that I can use without knowing why it's traveling on a geodesic, or why that particular worldline is a geodesic instead of some other one (i.e., why spacetime in that region has the particular geometry it has). "Dynamics" refers to properties that you have to have some knowledge of causes to define and study. For example, the Einstein Field Equation is a dynamic equation, since you have to know the stress-energy tensor, which means you have to know what kind of matter/energy you're dealing with, how it works, what it's made of, what interactions it has, etc., etc. But the boundaries of these terms are fuzzy, and I prefer not to use them if I can avoid it.
Thanks.
Your question is really about how to measure the distance between two objects or two points on the same object. If you are at rest with respect to the object, then it's pretty easy--you just get out your ruler and measure it. Of course, nowadays the cool way to measure a distance is with at Laser Rangefinder. The principle of such a device is actually much better for really long distances and allows the observer to make the measurement without actually traversing the distance.
So let's consider the process of measuring a distance as great as the diameter of the Earth. To make it easier to illustrate, I'm going to assume that the object is simply a very long rod with reflectors at both ends and the observer at the near end. I'm going to assume that the speed of light is 1 foot per nanosecond or 1 million feet per millisecond. I'll place the length of the rod at 40 million feet which is close to 8000 miles.
To illustrate the process, I have drawn a spacetime diagram for the Inertial Reference Frame (IRF) of the observer at the near end of the rod in blue and the reflector at the far end of the rod in red. The dots show the Proper Time for each observer/object:
At the Coordinate Time of 0, the observer points his Laser Rangefinder at the reflector at the other end of the rod and pulls the trigger. A light signal, depicted by the thin blue line traverses the distance to the red reflector which hits it at the Coordinate Time of 40 msecs. The return signal, depicted in red, also takes 40 msecs and arrives back at the observer at the Coordinate Time of 80 msecs. Since the roundtrip time for the signal took 80 msecs, the Laser Rangerfinder divides that time by 2 to get the assumed time that it took for the light to propagate from the observer to the reflector and multiplies that result by one million feet per msec to get 40 million feet as the length of the rod.
But now let's use the Lorentz Transformation process to convert the coordinates of all the events (the dots) from the original IRF to one moving at 0.866c:
Now in this frame, we can see that the observer makes the same measurement because he assumes that the light takes the same time to get to the reflector as it takes to get back. Of course, in this IRF, this is not true, but the observer has no way of knowing that.
Note that at the Coordinate Time of 0, the distance between the observer and the rod is only 20 million feet. It doesn't matter which IRF we use to depict the scenario, the observer in the scenario sees the same things, makes the same measurements and calculates the same results.
Now let's see what happens to another observer who is traveling at 0.866c. How does he determine the length of the rod? Here's another diagram like the first one but with the added observer depicted in black:
Now since he is moving with respect to the rod, he can't simply do what the first observer did, instead he must make two measurements to each end of the rod and apply them at a point in time somewhere along his trajectory between the two ends of the rod and he does this by assuming again that the light takes the same time to get to the reflector as it does to get back.
In practice, the observer would be continually sending out laser signals from his rangefinder and making continuous measurements but I only show one for each reflector that happen to apply at the same point in time. Looking at the diagram, we can see that he sent out a signal at his time of zero to the far end of the rod and another one at his time of 1.5 msecs to the near end of the rod. He receives the echo from the near end at his time of 20 msecs so he takes the difference and divides by 2 to get a distance of 9.25 msecs times 1 million feet per msec or 9.25 million feet applied at the average of the two measurements or 10.75 msecs.
Meanwhile, the first signal is returning and arrives at his time of 21.5 msecs. Since this was sent out at his time of 0, this represents a distance of 10.75 million feet applied at his time of 10.75 msecs.
Now he can add those two distances together, 9.25 plus 10.75 to arrive at the length of the rod at 20 million feet. Now we can plainly see that in this IRF, the length of the rod is 40 million feet and yet he measures it to be half that by virtue of the fact that he assumes that his laser light traverses towards the reflectors in the same amount of time as the return.
Now there is another way that the observer can verify that the length of the rod is 20 feet and not 40 feet and that is by measuring the speed of the rod relative to himself. He uses the same measurements as before and can calculate the speed from either one of them. From his first measurement, he determines that the rod moved away from him at a rate of 9.25 million feet in 10.75 msecs or 0.856c, close enough for eye balling. For his second measurement, he has to wait until he reaches the far end of the rod and then he uses the time from the measurement until he reaches the end of the rod which is 23-10.75 or 12.25 msec so he calculates a speed of 10.75 divided by 12.25 or 0.878c, again close enough. We can average these to get 0.867c which is right on.
Now he can use the calculated speed along with his total time for the rod to pass him to determine the length of the rod. This is 23 times 0.867 which is 19.9 feet, in agreement with the other measurement.
In the next post, I'm going to show the same scenario for this second observer but in different IRF's to show again that different IRF's indicate the same observations for any observer.
Now I take the last IRF diagram from the previous post and use the Lorentz Transformation process to calculate the coordinates for a frame moving at 0.866c with respect to the first one. This puts the "moving" observer at rest and "validates" all of his measurements:
But since it is hard to see details in this diagram, I show another one zoomed in on the important activity:
You should confirm that the explanation of the radar signals and the calculations apply just as well to this IRF as it does to the first one.
And just to make the point even clearer, I transform to another IRF in which both observers are traveling away from each other at the same speed, 0.577c, but in opposite directions:
Here is a different approach that might make some sense. Warning: it's definitely an incomplete argument, and careless application will lead to Bell's spaceship paradox.
Think about an atom at rest with respect to you. It's a nucleus surrounded by a spherically symmetric electron cloud, all held together by the spherically symmetric electrostatic interaction between the nucleus and the electrons.
Now imagine an atom moving with respect to you. A moving charge is a current - so now there are magnetic interactions between the nucleus and the electron cloud in addition to the electrostatic ones. This electromagnetic field is not spherically symmetric - it is cylindrically symmetric around the direction of motion. So why would the electron cloud be spherically symmetric? The answer is that it is not - it is Lorentz contracted, which is to say that the atom is Lorentz contracted.
Of course, the Earth is just a big pile of atoms. If the atoms are contracted when seen from a moving frame, either the Earth must also be contracted or there must be gaps between the atoms. There are two reasons to believe that the Earth must be contracted. One, the forces between atoms are also electromagnetic in nature. Two, if gaps open up then there comes a point when it ought to be possible to fit another atom into the gap - but only from the moving point of view. That would be an unresolvable contradiction between the moving frame (where two objects could pass through each other) and the stationary frame (where they could not).
That's really it. The different lengths of an object viewed from different reference frames are a necessary consequence of the Lorentz covariance of the electromagnetic field. This argument is really only a plausibility argument, at least as I've expressed it. It doesn't really explain why distances between objects should contract, except for the consistency argument that I already made. However, it is a way to arrive at the realisation that objects must have different structures when viewed from different frames based solely in electromagnetic arguments - which we know must be right because of all the things we build using them.
My quantum physics book says that he Hamiltonian for the atom will have operators that only operate on the coordinates of the particular particles, but it also includes motion of the atom as a whole (the center of mass).
So the Schrödinger equation may be separated, and the eigenfunctions connected only through a common separation constant, which includes the kinetic energy of the center of mass of the atom.
So unless the atom is "in a box", the KE can assume any value, so the eigenfunctions are independent of each other, and the state of the atom is independent of the motion of its center of mass.
I was actually pointing to the physics in a single frame... where I would observe the rotating star, planets, and orbits as being flattened... and their appearent deformation by a strange variation of gravity with respect to my line of sight, etc... all this is in one frame.
Agreed, we are describing the same thing then (spacetime). Your initial retort implied light cone diagrams precede observations.
PeterDonis said:
Huh? There are certainly events there [elsewhere], and those events can emit causal influences that we can eventually detect. (Note that the "elsewhere" area is *not* the same as the region beyond the cosmological horizon--see below.) Similarly, we could have emitted causal influences in our past that are now being detected at events in our "elsewhere" region. The fact that there can't be a causal connection between a particular event's "elsewhere" region and that particular event in no way implies that the "elsewhere" region is physically meaningless.
First point as an executive summary regarding the diagrams, Regions exactly! those are defined. You throw out that defined region of elsewhere when you say "eventually". Eventually is not a definable region.
Causal connections & elsewhere; Yes & no, like your response says. It is easy enough to see that c or less is a causal (time/light like) connection and greater then c isn’t (space like). Of course it’s impossible to include all of time for obvious reasons in this context, less block universe ewwww!. This is where the continuum comes into play and we must add our own proper time/length to define a “now” moment and draw our light cone diagram to determine what we have a causal connection to. Any object in the “elsewhere” (spacelike) region we cannot not observe…and it goes without saying as at the diagram time, i.e as the different regions have been defined by the diagram.
so, are we talking fixed length of time light cone diagrams or a “time at infinity” perspective. Why use “eventually”, when discussing causal influence. Yes eventually we could catch up. Or eventually “it” could reach us, but we don’t observe or interact with the universe “all at once” we have to split it up into “diagrams” to examine something like causal structure.
Yes objects receding at greater then c are the same as the elsewhere region or as you'd call it "horizon", with the indisputable FOREVER component. That’s what makes it such a great example, the diagrams will always place those objects in the elsewhere region. Your “eventually” retort doesn’t “work” for that example. The causal connection is broken forever, not just now. that said you may think this is me kitty footing around semantically; The horizon is another way of saying forever spacelike.
The length MUST contract to maintain causal structure. It absolutely must contract, therefore it is absolutely length contracted. From a causal perspective means let the logic of causal structure “rule” or precede odd things like contraction/dilation. In other words it means what it says :wink: I would be more clear to say from the point of view of, but imagine your vocabulary puts mine to shame, so I used the word perspective thinking you’d get the intended meaning.
PeterDonis said:
Really? There's no spacetime inside the Earth? Or inside your body? Or inside an atom?.
If they “measure” spacetime between the objects within the Earth, my body or atoms then there is a spacetime interval there. As simple as that, I’m not sure how you interpret what I said to mean there is no spacetime between objects. That was kind of a strawman there.
Yes, and we assume gravity is spacetime distortions. We assume it’s the spacetime. If it works then hurray! Like I said ultimately this is perspective. We cannot measure nothingness (spacetime). We can measure just the physical stuff that spacetime is in between. And we can use two measures to determine the physically fundamental “distance” (interval) between those objects. You say that’s measuring spacetime, I can say that’s measuring the relationship between the two objects…not the spacetime itself.
It’s kind of a stupid thing to debate, less it can be proved one way or the other. I don’t believe that it can be and that this is just perspective that has no “physical significance” within the theory. I know basically nothing of GR, and it is a very “explored/tested” theory at this point so for all I know GR says explicitly (mathematically) that spacetime is something physical.
That’s measuring two rocks, you say that’s measuring the nothingness between them. Looks like for that situation, the Earth is affecting the kinematics of the rocks, or with the spacetime is something physical perspective the Earth affects the spacetime, and the spacetime (as Wheeler puts it) effects the of the rocks. What value does the additional component of Spacetime is something physical add to this scenario? Said differently, it’s the invariant properties of Earth that are affecting the rocks. This happens, by what ever means related to the Earths properties, over time and across a length, a coy way to say spacetime, which is a vague way to say geometrically. Is tidal gravity a physical property?
Sure. Why not?
Then what is it a physical property of; Measurements?
PeterDonis said:
Really? I guess you've never fallen down. Also, tidal gravity is part of "gravity", and I described above how to detect something physical about it.
I hope I didn’t say that gravity doesn’t affect matter, it certainly does. The difference between our perspectives (which for mine I’m defending merely to think more about it) is that you are saying matter affects spacetime, spacetime affects how matter moves. I think the popular saying is something like matter tells spacetime how to “bend”, spacetime tells matter how to move.
I am saying matter affects how matter moves, we measure/observe this across spacetime which getting to below, is effectively the same as saying geometrically.
PeterDonis said:
Huh? I don't understand the distinction between "kinematics" and "spacetime" that you're making here. Proper acceleration is just a measure of how far a particular worldline departs from being a geodesic, which is a property of spacetime. So I would say that "kinematics" and "spacetime" are really different ways of describing the same thing, or at least aspects of the same thing.
Kinematics is geometry. Effectively it seems that spacetime isn’t something physical and that we use geometry to coordinate physical occurrences. We have given a name to the nothingness between measures of time and length, spacetime. I feel a better name is area of causal structure :smile:
I’m cherry picking a point here sorry. But to your point about the Dynamic EFE SET; Is there some property of spacetime itself that must be “input” into the dynamic equation that can calculate gravity? Or does spacetime itself have no effect on the calculation. Does that calculation define the spacetime, inventing/implying that it itself is something physical, however is still dependent on “what kind of matter/energy you're dealing with, how it works, what it's made of, what interactions it has, etc., etc.”.
Poetically, spacetime is a physical occurrence messenger. Not a physical occurrence itself. The “messenger” doesn’t care about the message, doesn’t create/cause/change the message or affect it in any physically fundamental sense; the only “rule” for the messenger is that you receive messages in the right order and that every one agrees on that order.
Holy that took me a long time lol, but what great fun! Hopefully PeterDonis my replies don’t make you nauseous or exhausted, or that I miss your points because of semantics.
Thanks for playing :smile:
Shoot it looks like you were editing in the thread while I was composing in a word doc, there maybe some redundant points (lol they all are anyways) and stuff.
Ok, good.
I didn't say anything about light cone diagrams; you did. I talked about "causal structure", which, again, is distinct from how we visualize or draw it.
Please stop using the word "diagrams". Once again, I am *not* talking about diagrams or visualizations; I am talking about the geometry that the diagrams or visualizations refer to. To make an analogy, if I were to talk about the distance from New York to London, you are talking as if I mean a map that shows New York and London with a line between them.
Sure it is; it's just your future light cone at a given event on your worldline. When I say the Andromeda galaxy can emit signals that we will eventually receive, I mean that the worldlines of those signals intersects our future light cone somewhere.
You are confusing objects and events, and also confusing objects themselves with the signals they emit. An "object" is not a single point in spacetime; it's a worldline or world tube. And to observe an object, we don't have to actually intersect its worldline or world tube; we just have to intersect the worldline of some signal emitted from the object's worldline or world tube.
Once again, the diagram does not define the regions; the regions are there whether or not we draw a diagram of them, just as New York and London are there with a definite distance between them whether or not we draw a map showing them.
This is a little better because you are only saying we need diagrams to "examine" the causal structure; but it's still wrong, we can examine the causal structure of spacetime without drawing diagrams or visualizing anything. Diagrams are not the only tool in the physicist's toolbox. They are often very helpful tools, yes, but that doesn't mean they're necessary.
No, they're not. The Andromeda galaxy's world tube has a large portion that is in our "elsewhere" region, but the Andromeda galaxy is not receding from us faster than light; in fact it's moving towards us.
It is true that the objects receding greater than c are *in* our "elsewhere" region, but what you said implies that the two things are identical, which they're not. You state it better a bit further on:
Yes, this is true for the cosmological horizon; we can't send light signals to a galaxy beyond our cosmological horizon, and that galaxy can't send any light signals to us either. (It's worth noting that it is *not* true for a black hole horizon; that type of horizon is one-way, objects inside can't send light signals out, but objects outside *can* send light signals in.)
So again, what causal properties of an object are different when it's length contracted, compared to when it's not? If you can't show any, then I'm still not buying this way of describing it. The word "absolutely" is really what I'm objecting to; as I said before, it gives entirely the wrong impression, that length contraction is frame-independent when it's not.
But the way you put it, in what I quoted just above, makes it seem like the contraction/dilation precedes the causal structure; you say "the length MUST be contracted to maintain causal structure". If the causal structure precedes the contraction/dilation, then it would seem better to say something like "the causal structure of spacetime requires that objects appear length contracted/time dilated when they are moving relative to us".
I didn't interpret you to be saying there was no spacetime between objects; I interpreted you to be saying (or at least implying) that there was no spacetime *within* objects. You said "we measure the spacetime only between things" (emphasis mine). Unless by "things" you mean "only elementary particles" (and even that is problematic, since we don't know for sure that all elementary particles are really point particles), that statement implies, to me, that you are ignoring the possibility of there being spacetime within objects. (Not that you were unaware of the possibility, but that you ignored it in making your statement. But for this discussion, I don't think it should have been ignored.)
We assume it when we construct the theory, I suppose. But we don't assume it when we make measurements, such as the measurement of tidal gravity that I described. Once again, that measurement shows distortion of something--freely falling worldlines that start out at rest relative to each other don't stay that way. But the objects being measured show no distortion, so the only thing left that can be distorted is spacetime. That's not an assumption, it's a conclusion from the evidence.
I agree you can't measure nothingness (at least, classically you can't; quantum mechanically is a whole other can of worms...). But spacetime is not nothingness; that's why we can measure it.
We can *directly* measure only the objects, not spacetime itself, yes. But we can certainly measure spacetime indirectly, just like we measure lots of things indirectly. Nobody has ever directly measured a quark, but we can measure them indirectly and so we know they exist.
If spacetime geometry were fixed, as in special relativity, I would buy this point of view. But spacetime geometry is not fixed; it's affected by the presence of matter and energy. Once again, consider the measurement of tidal gravity that I described. The objects themselves are not affected (yes, in principle they could be if the tidal gravity were strong enough or the objects were large enough, but we're talking about a case where the objects are small enough that we can't measure any change in them during our experiment). But their rate of separation is not always the same; it depends on what masses are present. So something must be changing, and we call that something "spacetime".
AFAIK yes, that is the mainstream view in GR. (Bear in mind, also, that GR is not a quantum theory, so our current belief is that it is not fundamental; it is a low-energy classical limit of a quantum theory of gravity that we don't have yet. Quantum mechanically, the view that spacetime is something physical is even harder to avoid, because you can have quantum fluctuations in spacetime even when there is no matter or energy present, and those fluctuations can have physical consequences, just as with other quantum fields.)
It's directly measuring the two rocks, and indirectly measuring the spacetime geometry. See above.
Good question! This is really the crux of the issue. There are probably a number of possible answers, but here's mine:
- It allows us to eliminate direct action at a distance; we don't have to view the Earth as directly affecting the rocks without anything physical between them. The Earth affects spacetime, and spacetime affects the rocks; spacetime is basically a field, just like other fields, and GR is a field theory of gravity, with the same advantages as other field theories compared to "action at a distance" theories like Newtonian gravity.
This probably serves as a comment on much of the rest of your post.
Yes: you have to know how much spacetime curvature is produced by a given quantity of stress-energy. In other words, when we write the EFE in conventional units:
G_{\mu \nu} = \frac{8 \pi G}{c^4} T_{\mu \nu}
that ##8 \pi G /c^4## on the RHS is a property of spacetime.
You're welcome! I think this is a good discussion, and the questions you're asking are worth asking.
It is fun, and is how I try to learn from pf. I trust your responses are, where physically important, the same as textbook teachings, which should be the same as physics itself. In other words I have "what i understand it to be" and get your feed back on issues with "what i understand it to be", hopefully this is analogues to an experiment lol.
That said here we are discussing allot on perspectives. I now see what you meant by mentioning light cones. It is a good point, but it is pretty much describing causal structure then.
Yea I carried on and on with the diagram "issues".
The point I make about space like and passing of time and the forever spacelike objects with respect to the else where region and why it is a region is pretty clear. Can you define the region of spacetime where spacetime itself recedes at c? This is the same as when the sum of the spacetime receding and relative motion create a continuous spacelike interval.
About just measure spacetime not the objects is so fundamental. We measure edge to edge of what ever we want to measure the spacetime between, the object can be a big empty sphere for all i care. That's not even remotely complicated. In fact, it's explicit, objects are not spacetime.
The way the logic should be is if there is motion in an invariant causal system the comparative measures of length/time must contract/dilate. Here it is just semantics, I appreciate the word absolutely may imply to you invariant and forever, so swapped it out for must. The only thing here invariant and forever is the causal structure.
We agree about the rocks and what's measured then. And leads to the point about the importance of the distinction other then some metaphysical interpretation.
I think the phrase "action at a distance" is physical nonsense and has nothing to do with physics. Do magnets distort spacetime? are all "attractions" distortions of spacetime? So why is gravity unique? because of how we measure an interval?
Digression
I would really like to know the GR correct wording for the difference between attraction (electromagnetic / nuclear, ect) and gravity. why doesn't the macro correlation between their effects hold? Force carriers? really? I find it disappointing that strictly dimensional analysis physics isn't the only field of physics, seriously what the hell is a photon, a gluon, bosons :smile: compared to familiar time / length. Nope continue to distort spacetime with kinetic energy and call the results "sub-atomic particles" of many different varieties.
It's more clear that "energy" is very very broad in observation/definition, & looks like all sorts of things physically. I can't understand why there are no theories/papers connecting gravity and kinetic energy in some way independent of standard model gravitons (boo to those things). This leads to my real opinion that macroscopically spacetime is something that's "physically" manipulated. "How" I think is a question for dimensional analysis length/time only physicists and not sub-atomic particle physicists :smile: but suppose their field, sub-atomic particles, is only nominal. In other words I don't like how the story is told, but at least the math/testing part is "done" :smile:
End Digression
Okay I think I've got some acceptable wording here, clocks and rulers measure spacetime intervals which are invariant. Intervals ignore the observer dependent where & when, but instead measure the more physically fundamental...order. This makes sense when everything is moving around in such a system/structure(geometry)
I'm doing my best to represent the mainstream "textbook teachings" as far as the physics goes, yes. Some of what we're discussing is more to do with the use of words than the actual physics. And the question "is spacetime physically real" borders on philosophy, so I'm not sure there is a "textbook" answer to it as it stands. But the textbooks certainly treat spacetime as part of physics.
Some would say this is a sloppy way of putting it, but I understand what you mean; you're describing a cosmological horizon.
This is one of those fine points that makes some people say the above wording is sloppy. "Spacetime receding" and "relative motion" are not really different things; that is, there is no general way of saying whether a particular observation, such as that the redshift we observe in light from a certain galaxy is tending towards infinity, is due to relative motion or "spacetime receding". We can only make this distinction in special cases; as it happens, the expansion of the universe, at least as it's usually approximated in cosmology (by treating the universe as perfectly homogeneous and isotropic), is one such special case.
In our models of the universe, we can pick out a family of worldlines that has special symmetry properties, and use that family of worldlines to define what "relative motion" means (it means motion relative to that family of worldlines). That allows us to factor out "relative motion" and call what remains "spacetime receding". In the case of a cosmological horizon, we can find a pair of observers, each following one of the worldlines in the special family (these are called "comoving" observers) and show that each one will observe the redshift of the other's light signals tend to infinity, and then each one will see the other disappear behind the cosmological horizon.
Yes, I agree with this way of putting it.
I do too, but note that taking this position requires you to account for how causal influences propagate through what appears to be "empty space"--that is, they require you to attribute at least some kind of physical reality to spacetime itself, since that's all that's there in the empty space between objects.
Actually, what I just said is a bit too strong: one could take the position, based on quantum physics, that there is no such thing as truly "empty" space--there are always quantum fields present, and even if the fields are all in their vacuum states, there are still quantum fluctuations that can have observable effects. One would then account for causal influences propagating by linking every such influence to some quantum field. Gravity would then be one such field.
The problem with this alternative approach as it stands is that quantum field theory, as it's usually cast, requires flat spacetime as a background--that is, it still includes spacetime as a part of the theory. (You can also do quantum field theory on a curved background spacetime, but it still requires *some* background spacetime.) One way of describing the current search for a theory of quantum gravity is finding a way of describing quantum fields and the causal influences they propagate *without* assuming any kind of background--we want the background, what we normally think of as "spacetime", to pop out of this underlying theory as an emergent phenomenon, rather than having to put it in as an assumption. Nobody has managed this yet, but if it is ever done, it would be a natural outcome of such a theory to view spacetime as physically real--because it's now just one of the emergent phenomena that comes out of whatever the underlying fields are. We'll have to wait and see how this pans out.
Because gravity obeys the equivalence principle, and other interactions do not. A magnet does not make all objects "fall" with the same acceleration--nor does an electric field, or any other interaction besides gravity. So there's no way of viewing any interaction except gravity as a distortion of spacetime itself, because the "distortion" at one and the same event would have to be different for different objects, and you can't build a geometric theory that way.
See above; the key difference is the equivalence principle. That's what allows us to "factor out" the properties of different objects and describe the effects of gravity purely in terms of spacetime.
That said, there are certainly plenty of theoretical efforts aimed at viewing gravity as "just another field like the others". I made some comments on this already above.
For me sloppy wording ain't so bad :smile:, for me the most important part is what I say is not on the heavy side of flat out wrong physically, like Greene* or something :-p...&ouch.
About the measure / test for receding spacetime; That's really cool! the "modern" measurements people/physicists/mathematicians can come up with is really remarkable to me.
Thanks again PeterDonis this was fun :smile: From debating the "other side" of "is spacetime something?" I think the best was realizing that measuring spacetime is indisputably a dichotomy of the invariant interval, something indisputably physical.:biggrin: *Of course I mean specifically the "pop physics" books. on the subject of physics without question Greene is much much more knowledgeable then me, by a laughably large chasm. :shy:
Back to the topic... please.
I have not seen any answers to my questions, starting with: <removed trolling>
Since you have not seen the excellent answers that have already been provided there is no use in repeating them or providing further answers.
Thread closed. Come back when you are willing to open your eyes or when you get your monitor fixed, whichever is currently preventing you from seeing.
  • · Replies 63 ·
  • · Replies 17 ·
  • · Replies 45 ·
  • · Replies 29 ·
  • · Replies 71 ·
