The piezoelectric effect in ferroelectrics
  • Thread starter Thread starter qwerasadf
    Piezoelectric
The discussion centers on the piezoelectric effect in ferroelectric materials, specifically BaTiO3 Perovskite. Below the Curie temperature, the tetragonal structure leads to polarization in each unit cell. Mechanical stress increases net polarization through two mechanisms: stretching of dipoles and alignment of randomly oriented domains. The key question raised is whether the movement of 90° domains contributes significantly to the strain and voltage observed in piezo ferroelectrics under mechanical stress.
  • Understanding of piezoelectric materials and their properties
  • Knowledge of ferroelectric phase transitions, particularly in BaTiO3
  • Familiarity with domain theory in ferroelectrics
  • Basic principles of electrostriction and its effects
  • Research the mechanisms of polarization in ferroelectric materials
  • Study the role of domain wall movement in ferroelectricity
  • Explore the relationship between mechanical stress and electric polarization in BaTiO3
  • Investigate the principles of electrostriction and its implications in piezoelectric applications
Researchers, materials scientists, and engineers working with ferroelectric and piezoelectric materials, particularly those focused on applications in sensors and actuators.
qwerasadf
Hey,
I am confused, what is the exact reason for the appearance of a voltage upon a mechanical stress at a ferroelectric material like a BaTiO3 Perovskite?
Below the Curie temperature the structure is no more cubic but tetragonal, let's say c-site is now longer than a- and b-site. And of course there is a polarization in each unit cell now. Ok, now we do mechanical stress at the material. I assume there are many contribution for the resulting increase of net polarization:
First, we do the same as we do at a piezo crystal (quartz), every single dipole in every unit cell gets stretched. Therefore, the whole body get stretched. And the polarization increases.
Secondly, we do streched the random aligned domains! In every ferroelectric there are domains with mutual aligned inner polarizations. When c-site is longer than a and b, and we put a stress from c site, the unit cell should move 90° right? You can imagine hundred pens. When you grab them, they will align! So, the "body of pens" will strain in the "long-direction", thus we have a bigger net polarization due to the alignment of every unit cell / pen in c-direction.
The central issue is: Do the second point make a large strain? Or is the second point just describing the phenomenon of electrostriction? Or, none of them (or a mixture): There are domains, the induced stress let the domain move and therefore we can now do point 1: streching them! Do the movement of domains itself lead to a higher polarization (because c-site itseld is longer), or is the movement a condition for a higher polarization due to the further streching of the c-site?
Thank you !
The short version of the main issue is: Do the movements of 90° domains contribute to the typical large strain in piezo ferroelectrics upon an applied electric field? Do the movements of 90° domains contribute to the voltage upon a mechanical stress?
Or let's say: What is the exact reason for the inverse piezoeffect (strain) in ferroelectrics?
And what is the exact reason for the pieoeffect in ferroelectrics?
Augmentation of Polarization in every unit cell or the movement of the domains resulting in augmentation in polarization?
  • · Replies 64 ·
  • · Replies 56 ·
11K
