The plots of wave function of harmonic oscillator
The discussion centers on the interpretation of wave function plots for the harmonic oscillator as presented in Griffiths' "Introduction to Quantum Mechanics." The wave function, defined by the equation $$\psi_{n}(x)=(\frac{m\omega}{\pi\hbar})^{1/4}\frac{1}{\sqrt{2^{n}n!}}H_{n}(\xi)e^{-\xi^{2}/2}$$, indicates that while the order (n) increases, the height of the plots does not correlate with the wave function's normalization. Instead, the plots represent the probability distribution, which shows that as n increases, the energy levels rise, allowing the particle to extend further from the origin.
  • Understanding of quantum mechanics concepts, specifically wave functions.
  • Familiarity with Griffiths' "Introduction to Quantum Mechanics" and its equations.
  • Knowledge of Hermite polynomials (H_n) and their role in quantum mechanics.
  • Basic grasp of probability distributions in quantum systems.
  • Study the derivation and properties of Hermite polynomials in quantum mechanics.
  • Explore the normalization conditions for wave functions in quantum systems.
  • Learn about the significance of energy levels in quantum harmonic oscillators.
  • Investigate graphical representations of probability distributions in quantum mechanics.
Students of quantum mechanics, physics educators, and researchers interested in the mathematical foundations of wave functions and probability distributions in quantum systems.
Tspirit
In Griffiths' book "Introduction to Quantum Mechanics", Section 2.3, Chapter 2, the Fig. 2.7 gives the plots of the wave function (##\psi_{n}##) and its modulus of the harmonics oscillator, see the Appendix. With the order (##n##) increasing, they become both higher. However, according to the Equation [2.85], the wave function shouldn't be higher with ##n## increasing. They are just a normalizable wave function, if the baseline is greater than 1, it won't normalize. So how to understand the plots?
$$\xi\equiv x\sqrt{m\omega/\hbar}$$
I doubt if it is just a demonstration of Energy level and the plots' height is not related to the wave function.
first off, the graf you called the "modulus" is actually the probability distrbution.
wth that in mind, the lines "n=x" are (must be) your 0 line, they are just ploted over each other. was that your question?
E=(n+1/2)ħw so with n increasing you have more energy therefore you can "travel" further from the origin.
wth that in mind, the lines "n=x" are (mist be) your 0 line, they are just ploted over each other. was that your question?
Yes, that is. All of the functions should be around the horizontal axis.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 0 ·
