The potential of a sphere with opposite hemisphere charge densities
The discussion focuses on the potential of a sphere with opposite hemisphere charge densities, utilizing the general potential formula $$V(r,\theta)=\sum_{l=0}^{\infty}(A_lr^l+\frac{B_l}{r^{l+1}})P_l(cos\theta)$$. The potential outside the sphere is expressed as $$V(r,{\theta})=\sum_{l=0}^{\infty}\frac{B_l}{r^{l+1}}P_l(cos\theta)$$, with specific attention to the z-axis where $$V(r,\theta)=\frac{\sigma}{2\epsilon_o}(\sqrt{r^2+R^2}-r)$$ is derived. The discussion highlights the importance of Gauss's law and the need to consider cylindrical symmetry due to the charge distribution's nature, leading to the conclusion that even Legendre polynomials can be disregarded in certain conditions.
  • Understanding of electrostatics and electric potential
  • Familiarity with Legendre polynomials and their properties
  • Knowledge of Gauss's law and its applications
  • Basic concepts of spherical and cylindrical symmetry in physics
  • Study the derivation of electric potential using Legendre polynomials
  • Explore the implications of Gauss's law in non-spherical charge distributions
  • Learn about cylindrical symmetry in electrostatics
  • Investigate the behavior of potentials in different coordinate systems
Physicists, electrical engineers, and students studying electrostatics, particularly those interested in advanced topics related to charge distributions and potential calculations.
Tony Hau
A sphereical shell of radius ##R## carries a uniform surface charge ##\sigma_o## on the northern hemisphere and a uniform surface charge ##-\sigma_o## on the southern hemisphere. Find the potential inside and outside the sphere.
##V(r,\theta)=\sum_{l=0}^{\infty}(A_lr^l+\frac{B_l}{r^{l+1}})P_l(cos\theta)##
Here is what the solution says:
As usual, quote the general potential formula: $$V(r,\theta)=\sum_{l=0}^{\infty}(A_lr^l+\frac{B_l}{r^{l+1}})P_l(cos\theta)$$
The potential outside the sphere is: $$V(r,{\theta})=\sum_{l=0}^{\infty}\frac{B_l}{r^{l+1}}P_l(cos\theta)$$, which makes sense to me.
The potential at z-axis is: $$V(r,{\theta})=\sum_{l=0}^{\infty}\frac{B_l}{r^{l+1}}P_l(cos\theta)$$ because ##P_l(cos\theta) = 1## for all ##l##s.
However, here comes a strange equation: $$V(r,\theta)=\frac{\sigma}{2\epsilon_o}(\sqrt{r^2+R^2}-r)$$ along the z-axis.
I think this equation may come from the Gauss's law: ##\oint \vec E \cdot d \vec A = \frac {Q_{total}}{\epsilon_o}##. I set the Gaussian's surface to enclose the whole hemisphere. As the charged surface emits a uniform E field outside and inside, the equation becomes ##E\int 2d A = \frac {Q_{total}}{\epsilon_o}##, where ##A = 2\pi R^2##. Obviously this is not the correct idea. Can anyone help? Thanks!
Use the boundary conditions for continuity of potential across surface and discontinuity of electric fields across surface to solve for A and B!
The reason Gauss theorem won't work here is that problem does not possesses spherical Symmetry but Cylindrical symmetry!
Also ##P_l(1)=1## for all l!
Since the charge distribution changes sign for ##z<0##, the potential must also do so, i.e. ##V(x,y,-z)=-V(x,y,z).## This means that you can toss out some Legendre polynomials. Which ones? Hint: ##z=r\cos\theta.##
This is hard but I will make a guess. I think for even numbers of ##l## the Legendre polynomials are tossed.
The ##V_{out}## is given by: $$\sum_{l=0}^{\infty}\frac{B_l}{r^{l+1}}P_l(cos\theta)$$
For the first few ##l##s, $$\frac{B_1}{r^2} + \frac{B_2}{r^3}cos\theta + \frac{B_3}{r^4}\frac{3cos^2\theta-1}{2} + \frac{B_4}{r^5}\frac{5cos^3\theta-3cos\theta}{2} \dots = \frac{B_1}{r^2} - \frac{B_2}{r^3}cos\theta + \frac{B_3}{r^4}\frac{3cos^2\theta-1}{2} -\frac{B_4}{r^5}\frac{5cos^3\theta-3cos\theta}{2} \dots$$ because ##-z=-rcos\theta## and ##V(x,y,-z)=-V(x,y,z)##.
For this boundary condition, the sum of all even numbers of ##l## of the Legendre polynomials is 0.
Tony Hau said:
For this boundary condition, all even numbers of the Legendre polynomials are canceled on both sides.
Yes.
So, on the z-axis you may write $$V(r)=\sum_{l=0}^{\infty}\frac{B_l}{r^{l+1}}$$
To find V on the z-axis, you can break up the charge distribution into rings with the z-axis as the axis of the rings. The potential on the axis of a uniformly charged ring is easy to find. Integrating over the rings will give the total potential at points on the z-axis. However, I get a somewhat different result. I find $$V(r)=\frac{\sigma}{\epsilon_o}\frac{R}{r}(\sqrt{r^2+R^2}-r)$$ on the z-axis for ##r>R##.
The reason for finding ##V## on the z-axis is that it gives you a way to find the coefficients ##B_l##. If you expand the expression for ##V(r)## on the z-axis as a power series in ##1/r##, you can compare it to ##V(r)=\sum_{l=0}^{\infty} \large \frac{B_l}{r^{l+1}}## and identify the ##B_l##.
Nice explanation!
  • · Replies 16 ·
  • · Replies 22 ·
