The principle behind throttling valves
  • Thread starter Thread starter tony_engin
    Principle Valves
41 replies · 134K views · last reply
Toolbox13 said:
Some great answer by Q_Goest, if still online can you explain the following. Has me a bit stumpted.
For flow of an ideal gas across a throttle the enthalpy is constant and hence since enthalpy, Cp(DT), is constant there can be no temperature change across a throttle for a gas flow.
However the head loss across a throttle results in the conversion of mechanical energy to thermal energy (through frictional heating and such) and hence there would be a change in the internal energy, Cv(DT), therefore a change in internal energy requires a change in temperature and hence a change in enthalpy which contradicts my first point of constant enthalpy for a throttle device (as noted above several times).
I am particularily thinking of frictional heating in a flowing system across a throttle, this viscous heating will result in a temperature rise across the throttle but then how does this equal with a constant enthalpy defined as Dh = Cp(DT)?
Note again that this is for ideal gas so no joule-thomson effect.
There is a reason for this. The equation Enthalpy in = Enthalpy out is only an approximation, and omits a term in the energy balance. The term that is missing is the viscous heating. This term is usually very small for a gas, and, can be neglected. See the advanced treatise Transport Phenomena by Bird, Stewart, and Lightfoot, Table11.4-1, next-to-last equation.
Do a calculation for a specific example of the mechanical energy loss associated with the pressure drop using one of the oriface correlations, and convert this into a temperature rise to see how small it actually comes out to be. If, for an ideal gas, you also assume that its viscosity is zero, then the viscous heating is zero, and the Joule Thompson coefficient is exactly zero.
Thanks, the above was close to my thinking also but could not find a textbook that explains it in detail. I will look up the one that you suggested. I am also not sure what you propose is fully correct.
My thoughts are that the Enthalpy in must equal Enthalpy out based on steady flow energy equation where KE/PE work out of control volume and heat out are zero. If this is the case then h_in must equal h_out, however it is plausible that while h_in = h_out there could be a temperature change due to transfer of energy from pressure term to internal energy term in enthalpy. If this is the case, then it is not h_in = h_out is not valid but rather the relation Dh = Cp(DT) is questionable in such instances. In fact this is derived on the basis of constant pressure originally, must look it up again.
In short thanks for answer
Chestermiller,
forgot to add the problem I am looking at has 300 to 8000W of viscous heating, hence hard to ignore it.
Microchannels with high speed flows.
As you noted, there are really two issues here:
1. Is the relationship Hout = Hin a sufficiently accurate representation of the thermal energy balance (first law) for a steady flow system in which viscous heating is not neglected?
2. Are the thermodynamic property equations we use to calculate the change in enthalpy per unit mass of a given material correct?
I can tell you that the thermodynamic property equations are definitely solid, so that the answer to the second question is "yes," particularly if we use the following fundamental relationship to calculate the change in enthalpy of a material in terms of the changes in temperature and pressure:
[tex]dH=C_pdT+(V-T\frac{\partial V}{\partial T})dP[/tex]
where H is the enthalpy per mole, V is the volume per mole, and Cp is the molar heat capacity at constant pressure. This equation applies to any material, including liquids, ideal gases, and non-ideal gases. Note that, in the case of an ideal gas, the second term is identically equal to zero.
The way that this equation is typically applied is to choose a reference state T0, P0 at which the enthalpy is taken to be zero. The equation is first integrated with respect to T at constant P = P0 (such that only the first term is involved) from T=T0 to T = T; then the equation is integrated with respect to P at constant T = T (such that only the second term is involved) from P = P0 to P = P. If you know how the heat capacity varies with T at P = P0, and you know the PVT behavior of your liquid or gas, then this equation is guaranteed to deliver the correct values of the enthalpy relative to the reference state. The derivation of the above equation is pretty much in every thermo book, and you should look it up if you are not yet familiar with it.
The first question is related to the general way that the first law is expressed in elementary thermo books. It typically neglects the contribution of viscous stresses to the overall stresses at the boundary of the system, and thus in calculating the rate of work done on the surroundings. It only includes the isotropic pressure portion of the stress. BSL provides a more rigorous development which includes the viscous contributions to the stresses. BSL first writes down the mechanical energy balance equation, which is the result of dotting the differential force balance equation (equation of motion) with the velocity vector. This essentially delivers the Bernoulli equation, with some extra terms included to account for viscous stresses. They then write down the overall energy balance equation in terms of both thermodynamic energy quantities and mechanical energy quantities, some of whose terms are the same as in the mechanical energy balance equation. They then subtract the mechanical energy balance equation from the overall energy balance equation to arrive at the thermal energy balance equation. This is basically a differential form of the first law that properly includes the contributions of the viscous stresses. I very strongly encourage you to read Chapter 11 of BSL, and to study the derivations carefully, especially the way they arrive at the thermal energy balance equation.
I want to commend you on identifying all these relevant and important questions that need to be addressed in order to solidify ones understanding.
Chet
Hi
On what you term the first question, you are correct but it is generally not necessary to delve into the tensors of Reynolds and normal stresses when control volumes are considered. I am quite familiar with the dissipation term in the differential energy equation, actually spent quite a while working with it. The above result that propose from the textbook I expect is easily found from the first law Q-W=d(H)+d(KE)+d(PE). For throttle everything except d(H) is assumed to go to zero. You may then expand out d(H) and show that viscous dissipation results in a temperature change but then this would contradict the constant h across the throttle assumption (which must be true since it is simply energy conservation afterall). So I think one can view it from two perspectives,
Allow the frictional work to show up in the energy equation giving W(viscous) = d(H) but this implies the the control volume must be drawn within the throttle rather than around it.
Or allow h to be constant when control volume is drawn around the throttle and then split the enthalphy into two terms, u+PV, the u term can then be assigned to equal the viscous dissipation (Cv(dT)) and hence giving a temperature rise. This initially seems in conflict with the constant enthalpy requirement as it indicates a temperature rise but this temperature rise is compensation for by the (V−T∂V∂T)dP using your equation above. This way the enthalpy can remain constant even though there is a pressure rise.
Both ways to think about it are probably reasonable and I think correct.
Toolbox13 said:
Hi
I looked over Chapter 11 in Bird, Stewart, and Lightfoot last night, and I'm very confident you are going to find the answers to all your questions in that chapter. Unfortunately, I have not been able to articulate the essence of that development in a way that satisfies your doubts.
I also am sending you a private message in which I am proposing that we work together to apply the equations in BSL to solve a specific problem, in order to develop a practical understanding of exactly what is going on. I hope you are interested in participating.
Chet
Several weeks ago, in posts to this thread, Toolbox13 and I had been puzzling over some of the thermodynamics fundamentals of throttle values, particularly with regard to the manner in which viscous heating comes into play, and its influence on the temperature of the fluid exiting from the valve. As a result of these interactions, in private messages, we resolved to collaborate in analyzing the system in much greater detail, with the objective of removing the gaps in our understanding. We are now reporting back to the thread on the results of our deliberations, with which we are now in full agreement.
In order to keep things simple, we decided that, rather than deal with the geometric complexities of a throttle valve, we would analyze the simpler situation involved in the thermodynamics of adiabatic laminar fluid flow through a long straight section of pipe. The qualitative results we obtained for this case are fully compatible with those for a throttle valve.
We considered three types of fluids: Ideal (compressible) gases, ideal incompressible liquids, and real compressible gases. In all three cases, viscous dissipation was included in our analyses.
We also included three versions of energy balance equations:
1. Mechanical energy balance equation (obtained by dotting the differential equation of motion with the velocity vector)
2. Overall energy balance equation, including both mechanical and thermal effects.
3. Thermal energy balance equation, obtained by subtracting the mechanical energy balance equation from the overall energy balance equation. This focuses mainly on how the thermodynamic functions vary with position and time.
We considered the differential forms of these energy balance equations as well as the forms of the equations obtained by integrating over a fixed control volume, such as a pipe or a throttle valve. We also considered the predictions for specific thermodynamic functions, such as internal energy or enthalpy.
The following is a summery of our findings:
1. The change in mixing cup average enthalpy between inlet and exit of the pipe section (or throttle valve) is zero.
2. Even though the change in mixing cup average enthalpy is zero, there are non-uniform enthalpy variations over the exit cross section of the pipe. In the case of an ideal gas, this translates into radial variations in temperature at the exit; however, the mixing cup average temperature of the gas at the exit is the same as at the entrance.
3. In the case of an ideal gas, there are two competing physical mechanisms affecting the internal energy change and the temperature change from inlet to exit. These are: viscous heating and expansion cooling. These two effects exactly cancel one another for an ideal gas, such that there is no change in mixing cup average temperature.
4. For incompressible liquids, even though the mixing cup enthalpy change is zero, there is no expansion cooling, and the viscous heating effect brings about a temperature rise.
5. For real gases, even though the mixing cup enthalpy change is zero, the effect of pressure on enthalpy leads to Joule-Thompson heating or cooling.
For Tony:
"I don't understand why pressure will drop when the fluid pass through the valve but not "Why does the pressure not recover?"
Could you please help again? I'm such an idiot..."
You don't want it to recover, you are controlling the valve (opening and closing it) depending on the downstream load.
Tony, minus all the engineering, think of trying to regulate pressure downstream of a MANUAL valve with a varying downstream load.
You tie a 1" water line into a 6" main header that is at 100 psi. you put a manual gate valve on it and it is in the closed position.
On the downstream end of the manual gate valve you have a garden hose (for simplicity) and another valve, your "load" valve. Now you open your load valve wide to atmosphere, then you throttle open the manual gate valve 1/2 way, the upstream line will still be at 100 psi, and if you have a gauge installed downstream of your throttle valve it may well read zero because we are open to atmosphere and can move the water without line losses. It will never recover because the load is there (open to atmosphere). Now, close your load valve to 90 percent, (Your downstream load is reduced) your original throttle valve still open 50% will now not produce the drop you want, if fact it may very well "recover" because the load is so low and the valve is still at 50%. When they are talking about throttling, the downstream load has to be there for a pressure drop.
Let's say you want to drop pressure in a steam line from 200 psi to 80 psi
the control valve will vary its position depending on downstream load, that is why it won't "recover". It is not suppose to. If the downstream load on the steam main drops 90 percent (like when you closed the load valve 90% on the hose) because a process or a heat exchanger was shut down,the throttle valve (control valve) will also close off a huge percentage to keep the downstream press at your predetermined pressure, 80 psi. It is not suppose to recover!
Back to the original manual valve, you can not throttle pressure with a manual valve if the downstream load varies! if the downstream load is constant and the fluid and upstream pressure is constant, you can.
Hope this helps
Dennis
Can anybody explain why the pressure decreases across a throttling valve using the equation U1 + P1V1 = U2 + P2V2? Furthermore, for gases flowing through a throttling valve, is it necessary for the outlet pipe to be greater than the inlet? If not, how can there be an "expansion" or increase in volume?
The pressure decreases across a throttling valve, not because of conservation of energy between inlet and outlet, but because of viscous drag forces acting on the fluid in passing through the valve, which converts mechanical energy to thermal energy. If you had flow through a porous plug instead of a valve, would you really feel that the inlet and outlet pressures should be the same?
No.
The velocity of the gas increases.
Chet
so that means if i have a throtlling valve which decreases the pressure to 0.2 bar from 23 bar of steam, and i am planning to have an arrangement that will give 0.2 bar from 12 bar of steam, which is more beneficial and why, if possible prove by calculation.
Exactly what do you mean by "more beneficial?"
