Toolbox13 said:
Thanks, the above was close to my thinking also but could not find a textbook that explains it in detail. I will look up the one that you suggested. I am also not sure what you propose is fully correct.
My thoughts are that the Enthalpy in must equal Enthalpy out based on steady flow energy equation where KE/PE work out of control volume and heat out are zero. If this is the case then h_in must equal h_out, however it is plausible that while h_in = h_out there could be a temperature change due to transfer of energy from pressure term to internal energy term in enthalpy. If this is the case, then it is not h_in = h_out is not valid but rather the relation Dh = Cp(DT) is questionable in such instances. In fact this is derived on teh basis of constant pressure originally, must look it up again.
In short thanks for answer
As you noted, there are really two issues here:
1. Is the relationship Hout = Hin a sufficiently accurate representation of the thermal energy balance (first law) for a steady flow system in which viscous heating is not neglected?
2. Are the thermodynamic property equations we use to calculate the change in enthalpy per unit mass of a given material correct?
I can tell you that the thermodynamic property equations are definitely solid, so that the answer to the second question is "yes," particularly if we use the following fundamental relationship to calculate the change in enthalpy of a material in terms of the changes in temperature and pressure:
dH=C_pdT+(V-T\frac{\partial V}{\partial T})dP
where H is the enthalpy per mole, V is the volume per mole, and C
p is the molar heat capacity at constant pressure. This equation applies to any material, including liquids, ideal gases, and non-ideal gases. Note that, in the case of an ideal gas, the second term is identically equal to zero.
The way that this equation is typically applied is to choose a reference state T
0, P
0 at which the enthalpy is taken to be zero. The equation is first integrated with respect to T at constant P = P
0 (such that only the first term is involved) from T=T
0 to T = T; then the equation is integrated with respect to P at constant T = T (such that only the second term is involved) from P = P
0 to P = P. If you know how the heat capacity varies with T at P = P
0, and you know the PVT behavior of your liquid or gas, then this equation is guaranteed to deliver the correct values of the enthalpy relative to the reference state. The derivation of the above equation is pretty much in every thermo book, and you should look it up if you are not yet familiar with it.
The first question is related to the general way that the first law is expressed in elementary thermo books. It typically neglects the contribution of viscous stresses to the overall stresses at the boundary of the system, and thus in calculating the rate of work done on the surroundings. It only includes the isotropic pressure portion of the stress. BSL provides a more rigorous development which includes the viscous contributions to the stresses. BSL first writes down the
mechanical energy balance equation, which is the result of dotting the differential force balance equation (equation of motion) with the velocity vector. This essentially delivers the Bernoulli equation, with some extra terms included to account for viscous stresses. They then write down the
overall energy balance equation in terms of both thermodynamic energy quantities and mechanical energy quantities, some of whose terms are the same as in the
mechanical energy balance equation. They then subtract the mechanical energy balance equation from the overall energy balance equation to arrive at the
thermal energy balance equation. This is basically a differential form of the first law that properly includes the contributions of the viscous stresses. I very strongly encourage you to read Chapter 11 of BSL, and to study the derivations carefully, especially the way they arrive at the thermal energy balance equation.
I want to commend you on identifying all these relevant and important questions that need to be addressed in order to solidify ones understanding.
Chet
