The proper Schwarzschild radial distance between two spherical shells
45 replies · 8K views · last reply
Buzz Bloom
TL;DR
I am trying to understand the use of the Schwarzschild metric in measuring the "proper" distance between two non-moving concentric spherical shells which are also both concentric with the event horizon sphere which of course has the Schwarzschild radius.
If what I describe below is correct, I hope someone will confirm this for me. If it is is incorrect, I hope someone with explain my error to me.
For the purpose of this thread the metric is
ds2 = - (1-rs/r) c2 dt2 + dr2 / (1-rs/r)​
where
rs = 2GM/c2.​
(I modified the above from
I assume that the two spherical shells are stationary. Therefore
dt = 0.​
The r coordinate for the radii of the two shells satisfy the relationships:
A1 = 4 π (r1)2​
is the surface area of one spherical shell, and
A2 = 4 π (r2)2​
is the area of the other spherical shell.
The proper radial distance D between the r1 shell and the r2 shell is:
D = ∫r1r2 (1/(1-r/rs))1/2 dr.​
My purpose in studying this problem is that I am interested in estimating the error if I use Newtonian gravity equations for orbital motion rather than the more accurate (but more difficult to use) Schwarzschild math.
Buzz Bloom said:
I am interested in estimating the error if I use Newtonian gravity equations for orbital motion...
Do remember that the trajectory of an orbiting body is not a curve of constant ##t##
Hi Nugatory:
Thank you for your post.
I do understand and that time plays a role in orbital behavior. I plan to limit my study (at least for a while) to radial motion only to keep the math simpler. I am assuming that that the particular approximation of error using Newtonian gravity math rather than Schwartschild math will be similar for time as for distance.
Regards,
Buzz
I'm not sure I understand your motivations, but I don't see anything wrong with what you actually wrote. It would be cleaner if expressed in Latex, looking like this:
$$D = \int_{r_1}^{r_2} \frac{dr}{\sqrt{1-\frac{r}{r_s}}}$$
and is generated by
Code:
https://www.physicsforums.com/help/latexhelp/ has more help on Latex on PF.
In Euclidean geometry, given two concentric spheres given areas, there is an implied radial distance between them. In Schwarzschild geometry, the radial distance given two concentric sheres of the same area is different from the Euclidean expectation. What I don't see is what this has to do with calculating orbits, whether you use Newtonian gravity or GR.
If you are limiting yourself to purely radial motion you can actually solve the differential equations for orbital motion in Schwarzschild coordinates and write ##\tau(r)## and ##t(r)## (unfortunately I don't think you can invert them to get ##r(\tau)## or ##t(\tau)##). These coordinate-based expressions aren't directly useful, but you can derive some direct observables (e.g. time of flight for a thrown ball) and make comparisons between Newtonian and relativistic predictions.
I think that's the right way (or a right way, anyway) to go about this.
Hi @pervect, @PAllen, and @Ibix:
Thank you for your posts.
Regarding the use of Latex, I agree that it is a better form of presentation than what I used, but I have had difficulties using Latex. When I try to preview a post with Latex before posting, I experience display issues that make correcting the Latex very difficult.
Regarding the comparing of coordinate radial distance with proper radial distance, I want to be as certain as I can be that with respect to the distances I want to explore the difference is sufficiently small that it can be reasonably ignored. The problem I want to explore involves calculating whether a test object escapes from a gravitational source or is bound to it, involving a combination of gravitational attraction by a Euclidean point, and the outward acceleration from the expansion of the universe. I feel this topic has not been adequately discussed in several threads, for example.
and
I think that I am now ready to start a new thread specifically to explore (limited to radial motion) of what seems to me (possibly incorrectly) to be a correct way to determining whether a test object moving at a specified radial velocity will escape from a single given mass at a given distance. @PeterDonis has made an good argument that (for practical purposes) the Euclidean escape velocity is a sufficient test, even though it ignores the influence of the expanding universe. I want to explore in detail comparing this practical test with a test including the expanding universe. I have not been able to find on the Internet any source which explores this topic.
Regards,
Buzz
First, it is only the acceleration of expansion that will have any effect at all on escape velocity (the first derivative of scale factor has exactly zero tidal effect). Second, for any reasonable universe parameters, this effect will be much smaller than the difference between GR and Newtonian escape velocity. Thus, to analyze this effect, you would need to merge a Schwarzschild solution and an FLRW solution, which is a nontrivial undertaking.
Where did I make this argument?
Hi Peter:
I will make a search to find some specific posts. I have forgotten the exact threads where they appear.
Regards,
Buzz
Hi Paul:
I may well have a misunderstanding regarding your post, and I will reply as soon as I can. I am now off to a meeting.
Regards,
Buzz
Hi @PeterDonis:
I found one post which I quote from below. I still think there were related other posts, but I failed to find any others that were on topic.
Post #57​
... the correct criterion for whether a pair of objects are gravitationally bound is whether their relative recession velocity is greater than escape velocity.​
I understand that the definition you are using for "escape velocity" is the standard Euclidean one:
Ve2 = √(2M/D).​
This ignores the influence of the Hubble acceleration AH:
AH approx = H2D.​
This approximation ignores the changes in H during the time it takes as the test particle moves.I am still working on how to include this change in H, or to determine that the change in H is negligible regarding the issue of boundedness.
Regards,
Buzz
PAllen said:
Poking around a bit, it seems that the key thing to search for is the McVittie metric, which is an exact solution for a mass point embedded in an FLRW cosmology. Here are two example references:
https://arxiv.org/abs/1508.04763
https://iopscience.iop.org/article/10.1088/1742-6596/484/1/012044/pdf
Hi Paul:
I looked at the first reference and found some strange discussions. First, the date and title:
(2002) Search for a Standard Explanation of the Pioneer Anomaly.​
I did a search on "Pioneer Anomaly" and found (2012)
Here is a relevant quote from this article:
Why was the thermal emission from the spacecraft anisotropic and slowing the spacecraft down? First of all, because the Pioneer spacecraft were spin-stabilized and almost always pointed their big dishes towards Earth. Second of all, because two sources of thermal radiation (heat) were then on the leading side of the spacecraft .​
I confess this seems like it is not relevant to the problem I am exploring, but I will give it and the other article a deeper look over the next few days.
Regards,.
Buzz
This article would appear to be https://arxiv.org/abs/gr-qc/0107022, while the article @PAllen linked is https://arxiv.org/abs/1508.04763, titled "Lensing in the McVittie metric". Perhaps you confused two different browser tabs?
I have to admit I'm not clear what it is you want to do. Are you just trying to determine the escape velocity from some object in an expanding universe? Then the McVittie metric would appear to be what you want to study, from PAllen's description. In particular you'd want to look at radially outgoing timelike geodesics. I suspect that there are quite a few potentially thorny questions on the way to this, though.
Aside: I could murder a chocolate digestive...
Buzz Bloom said:
Hi Paul:
Regards,.
Buzz
I don’t understand. My link is to: ”Lensing in the McVittie metric”, from 2015. There is a brief mention of the pioneer anomaly, but that is tangential to the paper’s topic. The paper discusses the background of using the McVittie metric to analyze small scale effects of expansion. Its specific focus on lensing is not relevant, but the purpose of referencing it was to answer my own point that you need a way to combine Scwarzschild metric with FLRW metric to answer the questions you pose. After a little research, I found the McVittie metric is exactly such a proposal. This paper presents the McVittie metric with background and many references, thus perfectly on point from this point of view.
"Euclidean" is not the right word for the first formula I gave in that post for ##V_E##. That formula is derived from Schwarzschild spacetime; it is the formula for the escape velocity at radial coordinate ##D## in Schwarzschild spacetime relative to a mass ##M##. For large radial coordinates, the radial coordinate is a good approximation to actual radial distance, so ##D## can be considered the distance to the object.
I'm not sure what you mean by "Hubble acceleration", but if you mean the effect of dark energy, go back and read the post you reference again, since the second formula I gave for ##V_E## in that post explicitly takes the effects of dark energy into account. As I noted in the post, this decreases the effective distance ##D## from a given mass at which a comoving object will be moving away from the mass at escape velocity, so if you're just looking for an upper bound to that distance, the first formula is fine.
##H## is decreasing with time, so if you want an upper bound, just use the value of ##H## at the end of whatever time period you're interested in, since that will be the lowest value (which will therefore give you the largest value of ##D##).
Note that the McVittie metric uses isotropic coordinates, so the form of the Schwarzschild metric it is implicitly using is different from the form I used in the post in another thread that @Buzz Bloom linked to and that I was discussing in my previous post. For large distances from a given mass, the difference in radial coordinates between isotropic and Schwarzschild coordinates is negligible, and both are well approximated by the actual proper distance ##D##, so this doesn't significantly affect what I posted, but it's worth being aware of.
Btw, another implication of this is that describing the McVittie metric as a "mass point" embedded in an FRW universe is not quite correct. The metric does not cover the spacetime region at or below the event horizon of the mass at all (it can't since isotropic coordinates do not cover that region). So it is better described as a metric for the exterior of a black hole embedded in an FRW universe.
Hi Paul:
I do not understand why the above might be true.
Imagine two masses, each of mass M, and each occupying a non-moving point relative to co-moving coordinates. Assume at time t0, the distance between the centers of these two masses is D. The Hubble expansion tells us that at time t0 they are moving apart at velocity HD:
V(t0) = H(t0)D(t0).​
There is also a Hubble acceleration happening. I do not mean the acceleration of the expansion. I mean
A(t) = dV(t)/dt = H dD/dt + D dH(t)/dt.​
If we assume
ΩR = ΩM = Ωk = 0​
and
ΩΛ=1,​
then
dH(t)/dt = 0,​
H(t) = (1/a) d(a(t))/dt,​
and​
a(t) = eHt.​
With these assumptions,
A(t) = HV = H2D.​
I call this the Hubble acceleration, but if that is an ambiguous name, I will have to chose some other name.
Now assume (Newtonian view) the inward gravitational acceleration on a test particle at a distance D from the gravitating point mass M equals the Hubble acceleration.
GM/D2 = H2D​
which leads to
D = (GM/H2)(1/3).​
The implication is that the test particle with no velocity will be stationary with no acceleration. This is, this particle will be in an "orbit" with zero orbital velocity.
It seems natural to assume that the Hubble acceleration applies to a test particle at a distance D from a massless origin point P, when (1) the test particle is moving away from P at velocity HD, and (2) it is accelerating away from P with acceleration H2D. Apparently, there is some doubt that (assuming the Newtonian view) if there is a mass M at the origin P, the test particle would not be influenced by H2D, and it would not have a total acceleration of
A = -GM/D2 + H2D.​
Do you know any reference that explains why the Hubble acceleration affects the motion of a test particle at a distance where the gravitational attraction becomes negligible, but this does not apply when the gravitational attraction has a similar magnitude. I have been unable to find any such explanation anywhere on the Internet.
Regards,
Buzz
It's because expansion (as distinct from accelerated expansion) is just inertia; faraway comoving objects are moving away from us because of inertia. That fact cannot affect the escape velocity for objects from, say, the Milky Way.
A slightly more technical version of the above is that, because of the Shell Theorem, a spherically symmetric distribution of matter surrounding some region cannot affect the motion of anything inside the region. To a very good approximation, the distribution of matter in the rest of the universe with respect to a single gravitationally bound system like the Milky Way is spherically symmetric, so it can be ignored when analyzing the motion of objects within the system. The same applies to analyzing what the escape velocity from the system would be.
Also, please learn how to use the PF LaTeX feature. Most of the rest of your post is basically unreadable because of the equation soup and the lack of proper formatting.
Yes, you do. In the formula you derive, you explicitly ignore everything except ##\Omega_{\Lambda}##, which is dark energy, i.e., "acceleration of the expansion".
I already explicitly acknowledged, in the previous thread you linked to, that the presence of dark energy does affect escape velocity, and gave you the correct formula for escape velocity in the presence of dark energy and how that formula is derived.
@Buzz Bloom , the proof of my statement is simple. Two different arguments are possible. First, only curvature, as an invariant object, can affect physics, and this depends on second derivatives of the metric components, which means only second derivatives of scale factor can contribute to tidal gravity. A more cute argument is to ask what happens if the derivative of the scale factor is constant. The answer is that the curvature vanishes identically, which means you have flat Minkowski space in funny coordinates (Milne coordinates). Choice of funny coordinates cannot possibly affect orbits or escape velocity, this linear expansion rate must have exactly zero local effect.
In fact, it is well known that the following possibly counterintuitive statements are true, that follow from the fact that only the second derivative of scale factor matter for local physics:
- if you have a forever expanding universe, such that the rate of expansion is forever decreasing, then local orbits will be smaller than expected, and escape velocity larger.
if you have a forever contracting universe, where the rate of contraction is forever decreasing, then local orbits will be larger than expected, and escape velocity smaller than expected.
Of course, our universe is presumed to have accelerated expansion, so escape velocity will be smaller than expected, and orbits larger than expected.
Hi Peter:
I will work on getting familiar with Latex, but I fear that my frustration limit is likely to prevent me from using it regularly.
Aside from no Latex, can you give me some examples of what you mean by my "lack of proper formatting"?
Regards,
Buzz
Hi Paul:
I think it would be very helpful to me to see a lengthy explanation of
"only the second derivative of scale factor matter for local physics". Can you recommend a paper or book that explains the physical and/or mathematical reason for this limitation.
Regards,
Buzz
You can't do this the way you are doing it.
The general observation you are struggling towards here is correctly stated as follows: in the Schwarzschild-de Sitter metric (which, if you go back and look at my post #57 from the previous thread, you will see that I referenced), there is some finite radial coordinate ##r## (using Schwarzschild coordinates centered on the gravitating massive body) at which there are geodesic timelike worldlines that maintain constant ##r##. That is because the proper acceleration of a worldline of constant ##r## (and constant angular coordinates, so zero "orbital velocity") in Schwarzschild-de Sitter spacetime is:
a = \left( \frac{M}{r^2} - A r \right) \frac{1}{\sqrt{1 - \frac{2M}{r} - A r^2}}
where ##M## is the mass of the gravitating body and ##A## is a constant related to the dark energy density aka cosmological constant. Obviously ##a = 0## if ##r = \left( M / A \right)^{1/3}##.
Note, however, that this bears no relationship to your formula; this ##r## is independent of the Hubble constant and does not change with time.
Buzz Bloom said:
i fear that my frustration limit is likely to prevent me from using it regularly
Then I fear you are likely to find that other people's frustration limit is going to prevent them from reading or responding to your posts.
Buzz Bloom said:
Aside from no Latex, Can you give me some examples of what you mean by my "lack of proper formatting"?
By "lack of proper formatting" I meant "no LaTeX". The whole reason we have the LaTeX feature is that equations are so much more difficult to read without it. Which in turn means people are less likely to read or give useful responses to posts that don't use it.
Buzz Bloom said:
Hi Peter:
Regards,
Buzz
I don’t really understand how to simplify it any more than I have. The scale factor as function of time is part of several metric components. It is part of GR foundations that only curvature distinguishes local physics from SR. Curvature is only affected by second derivatives of metric components, because the Levi civita connection can be made to vanish at any point by coordinate transform. But its derivatives cannot be made to vanish, and these are determined by metric second derivatives. Cosmology is an application of GR, so it includes all features of GR, and cannot violate any generic features of GR.
Have you read any systematic treatment of GR? Sean Carroll’s online lecture notes develop everything from pretty basic starting point, yet develop the material using a pretty complete modern mathematical form.
Note, btw, that this is not the same as (though similar to) the formula I gave in post #57 of the previous thread. That formula, in the notation of this thread, is
D = \left( \frac{2 M}{H_0^2 + A} \right)^{\frac{1}{3}}
So that formula has a factor of ##2^{1/3}## extra in the numerator, and the denominator has the ##H_0^2## term as well as the ##A## term. The reason the ##H_0^2## term is there in that formula is that it is comparing the comoving recession velocity with the Schwarzschild-de Sitter escape velocity, and the former does depend on the Hubble constant, while the latter does not.
