The Science of Heat Transfer: Understanding Refrigeration Process
The discussion revolves around the refrigeration process and the principles of heat transfer involved in it. Participants explore how heat is removed from a refrigerator and the mechanisms that facilitate this process.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants question the role of conduction in heat transfer within refrigeration systems, discussing its necessity for transferring heat from the refrigeration fluid. There is also consideration of the second law of thermodynamics in relation to conduction.
The discussion is ongoing, with participants exploring different aspects of heat transfer and questioning the adequacy of conduction as an explanation. Some guidance has been offered regarding the principles of refrigeration, but no consensus has been reached on the best description of the process.
Participants reference the refrigeration cycle and the role of refrigerants, but there are indications of missing information regarding the broader principles at play. The discussion reflects a mix of assumptions about the mechanisms involved in refrigeration.
scar123
Heat does not naturally flow from a cool body to a hot body. A
refrigerator, however, does remove heat from the icebox and expels it as
warm air to the outside world. What is required to make this process
function?
would conduction be a good answer to this?
Well, obviously without conduction you won't be able to transfer the heat the refrigeration fluid. The rate of conduction depends on the temperature difference. The temperature difference is created because gases cool as they expand.
Well, obviously without conduction you won't be able to transfer the heat the refrigeration fluid. The rate of conduction depends on the temperature difference. The temperature difference is created because the refrigeration fluid cools as it expands.
So conduction would be the answer to this? WHich is better answer though, Conduction or 2nd law of thermodynamics?
The working principle of a refrigerator
Heat is removed from food and the surrounding area, thereby creating an environment which retards the activity of microorganisms. Temperature is usually about 5°C.
A refrigerant is used to remove the heat, i.e., a highly sensitive liquid which converts easily into a gas and back again into a liquid, e.g., freon12 or ammonia.
The refrigerant is carried in tubes at the back of the appliance and around the icebox.
The electric motor activates the compressor in the appliance which forces a gaseous refrigerant in the compressor into the condenser. In the condenser the refrigerant changes into a liquid, heat from the food in the refrigerator is absorbed by the liquid refrigerant and converts it back into a gas, ready for the cycle to begin again. In so doing, the food is cooled.
The refrigerator is thermostatically controlled to ensure an even temperature.
NOW WHAT DO YOU THINK BEST DESCRIBES THIS PROCESS.?
Conduction?
yupp...
