High School What Makes Red Dwarf Stars Cooler Than the Sun?
Red dwarf stars are cooler than the Sun due to their low mass, which affects their temperature and convection properties. The Sun is often considered a "cool star" in comparison to hotter stars, as it has a convection zone at its surface rather than in its core. The distinction between "cool" and "hot" stars is somewhat arbitrary, with classifications based on mass and convection behavior rather than strict temperature thresholds. Most main sequence stars, including the Sun, fall into a bimodal classification that separates them into cooler, less massive stars and hotter, more massive stars. Overall, the Sun's temperature is average compared to the broader spectrum of stars, with a significant number being cooler.
hyunxu
Red dwarf stars are main sequence stars but they have such low mass that they’re much ' cooler' than stars like our Sun.
Then Simple question here : Sun is cool or hot??
Astronomy news on Phys.org
what do you think ?
have you googled something like ...
1) the surface temperature of the Sun or
2) the core temperature of the Sun ?
there's 2 things for you to do an report back with your findings :smile:Dave
Although it is a strange term, the Sun is indeed regarded as a "cool star." The basic distinction is the different atmospheric physics you encounter when a star has a convection zone around its exterior, rather than a quiet zone of radiative diffusion there. "Hot stars" typically have convection in their cores, but not so much their exteriors. The discovery of magnetic fields in some "hot stars" has blurred the distinction somewhat, but there is a general tendency for higher mass stars to behave quite differently from lower mass stars, so this basic bimodal distinction between "hot stars" and "cool stars" is likely to persist. (For example, there is a yearly meeting called "
Cambridge Workshop on Cool Stars, Stellar Systems, and the Sun", which more or less answers your question right there!)
Likes ohwilleke and hyunxu
The terms cool and warm can be ambiguous. Artists, fashion designers and painters would say that "cool" colors have more blue in them. This is the opposite of a star's surface temperature.
Likes russ_watters and hyunxu
Quite different
A simple question with no simple answer.
What is "cool" and what is "hot"?
Of the 93 brightest stars, 28 are cooler than Sun, 2 are about equal (Sun itself and Alpha Centauri A), 63 are hotter.
Of the 64 nearest stars, 6 are hotter than Sun, 2 are about equal (the aforesaid), 56 are cooler.
Likes hyunxu
Nevertheless, "cool" and "hot" are not really arbitrary distinctions for stars, they are an effort to notice that stars can be divided into two very different flavors. Of course any such division is artificial, and more divisions can certainly be made, but in a coarse sense you have stars that are more massive, less convective near the surface, and ultimately have core-collapse supernovae, and stars that are less massive, more convective near the surface, and become white dwarfs. So that's "hot" versus "cool" in a nutshell, though even the massive stars can puff out so much as they evolve that they temporarily become "cool" and develop surface convection. In that way of slicing things, the Sun is a "cool star." It's about helping researchers group together objects that may have similar physics that they are interested in, more so than some arbitrary line in the sand of surface temperature.
Likes hyunxu
Ken G said:
... you have stars that are more massive, less convective near the surface, and ultimately have core-collapse supernovae, and stars that are less massive, more convective near the surface, and become white dwarfs...
Wikipedia on Wolf-Rayet stars:
Their surface temperatures range from 30,000 K to around 200,000 K, hotter than almost all other stars.
Massive main-sequence stars create a very hot core which fuses hydrogen very rapidly via the CNO process and results in strong convection throughout the whole star.
For example V429 Carinae has surface temperature 44,700K and is "
... one of the most massive and most luminous stars known...strongly convective all the way to the core and have dredged up fusion products to the surface
The general trend is that if you start at the coolest surface temperatures and start increasing it, at first the core gets more and more convectively stable, while the outer layers remain convectively unstable. This continues until the outer convection zone gets smaller and smaller and eventually nearly disappears, but then the core starts to become unstable. At the highest surface temperatures (like the Wolf-Rayet phase), the core convection zone has expanded to include most of the star. But the pattern generally holds-- high surface temperature implies core convection, low surface temperature implies envelope convection. At the highest end, the core convection merely encompasses most of the star, and at the lowest end, the envelope convection encompasses most of the star. But the main point is, the people who are most interested in how convection affects the atmosphere are generally people who study cool stars, and it is far from established that all Wolf-Rayet stars have convection zones that reach the surface. Indeed, the surfaces of last scattering in Wolf-Rayet stars tend to be found within a supersonic wind, which is certainly not convective.
They are grossly arbitrary, because more distinctions can be made.
Counting nearby stars, I found that roughly half of them are hotter than M3.
It seems that it is roughly around M3...M4 that stars hotter than this possesses radiative stagnant core and accumulate some helium isotopes in core. Thus, all stars hotter than M3, including Sun, are hot stars in one important sense - but just one of many possible senses, therefore arbitrary.
But all distinctions are arbitrary, it doesn't make them useless. Most of the stellar astrophysics community is divided into "hot star" and "cool star" studies. Better if everyone went to the same conferences, but then they'd just be too big and varied.
Ken G said:
...it is far from established that all Wolf-Rayet stars have convection zones that reach the surface. Indeed, the surfaces of last scattering in Wolf-Rayet stars tend to be found within a supersonic wind, which is certainly not convective.
The sun has coronal holes which are not convective. The corona further complicates the hot vs cool question.
The temperature of a star is a real number. There is no obvious gap in the hertzsprung-Russell diagram. The transition from not having a core to having a tiny core is very difficult to see. Somewhere in the M3 to M4 range. CNO burning of hydrogen is taking place in the Sun but at a rate too slow to cause core convection. You could find an overlap where a star has some core convection and some surface convection.
Are they divided by star types or by telescope/detector type? It would also be reasonable for Astronomers to group by the age of the stars they are studying. It is hard to see M-dwarfs that are far away.
Would a study of the Orion Nebula go to the "hot star" conference or the fit in with the "cool" astronomers?
Subfields are generally divided by star type, but astronomers often characterize their expertise by wavelength. It's odd, but you often find "radio astronomers" attending a "cool star meeting", or "X-ray astronomers" attending a "hot star meeting," or vice versa. The lines have historical purposes, but aren't always logical.
Possibly "hot stars," possibly "interstellar medium." If you are interested in the stars that illuminate the nebula, or the history of the supernovae that made it, you might hear about these at a "hot star" meeting. I doubt cool star astronomers care much about the Orion nebula!
They found a lot of young cool stars besides the young hot stars. Including (or excluding?) an eclipsing binary of two young brown dwarfs.
Good point, I guess the real message is the unity of astronomy, and how the distinctions we make for convenience should never let us forget that it's all one cosmos.
I guess it is possible for two Jupiter sized objects to merge when a planetary disk collapses.
At that stage fusion starts, and it can be called a distinct star and not just a nebula..
The Sun is a bigger star than average, yes it is hotter than small stars.
It is not exceptionally bigger and hotter though, there are blue supergiants. although they are rare
A paper link. Also a http://hubblesite.org/video/518/news_release/2006-11 from NASA.
They also found the temperatures reversed. The more massive brown dwarf is cooler. This could be caused by spots.
If you are interested in cold spots on hot stars do you go to the cool conference or the hot conference?
stefan r said:
If you are interested in cold spots on hot stars do to go to the cool conference or the hot conference?
Mind blown.
Likes stefan r
I assume you are referring to the hottest part of the sun, which lies above the surface of the sun. As we get to the surface, temperatures drop significantly. Observations suggest that below the surface temperatures drop even more. Indeed, looking into holes indicates lower temperatures.
According to emmited heat, the consensus seems to be that our sun may be average or slightly below. It is about at the median. This is also complicated by the definition of a star.
There appears to be no consistent temperature throughout the sun and it is very difficult to get emissions deep in the sun. So, the answer is difficult. For most other stars I think we only measure emission temperatures.
At least that is my understanding.
76.45% of main sequence stars are classified as M-type. So median temperature is much lower than the sun. If you list the brightest visible stars then the sun is closer to median.
The milky way looks redder than the zodiacal light. That is not a precise number but you can collect the ballpark data yourself on a clear night using no equipment (if you can get away from city lights).
Erribert said:
I assume you are referring to the hottest part of the sun, which lies above the surface of the sun. As we get to the surface, temperatures drop significantly. Observations suggest that below the surface temperatures drop even more. Indeed, looking into holes indicates lower temperatures...
...There appears to be no consistent temperature throughout the sun and it is very difficult to get emissions deep in the sun. So, the answer is difficult. For most other stars I think we only measure emission temperatures...
Most astronomers use the star as a point source. For far away stars it is impossible to separate the corona and photosphere except during eclipses. The temperature is determined by the spectrum. A star's spectrum is compared to radiation from a black body.
Core temperatures in red giants are much higher than core temperatures in similar mass main sequence stars. Red giants are considered cooler stars. The classification is entirely based on the light that is observed.
No.
On the other side of the median.
93 brightest stars:
https://en.wikipedia.org/wiki/List_of_brightest_stars
include:
6 M stars (all giants or supergiants)
22 K stars (ditto)
2 G stars (both dwarfs)
Grand total of 30 stars as cool or cooler than Sun, including Sun itself, and 63 hotter.
Obviously Sun is a cool star.
As just pointed out, by another criterion Sun is a hot star.
Likes stefan r
snorkack said:
No.
93 brightest stars:
include:
22 K stars (ditto)
There are 9,500 objects visible to (some) human eyes, magnitude 6.5. You could also use stars within 10 parsecs. This list has 4 As , 6 Fs ,22Gs and 35Ks
... which would give very different results!
Is Sun bright or dim?
See:
http://www.atlasoftheuniverse.com/stars.html
Of the brightest 50 (49 of the list, plus Sun), all of them apparent magnitude +2,00 or less, 10 have positive absolute magnitude. 11 have absolute magnitudes under -5.
This star regulus is hotter than sun.We conclude that blue stars are hotter than red and Orange.Why only "blue" stars make it
Make what?
russ_watters said:
Make what?
Why only blue stars are hotter than red and Orange? What's the actual relationship between this "blue colour " and "hotness"
hyunxu said:
This star regulus is hotter than sun.We conclude that blue stars are hotter than red and Orange.Why only "blue" stars make itView attachment 226999
'Hotter' means more energetic photons are being emitted.
Usually this is a simple consequence of how massive the star is.
However other factors such as the composition of the star's elements play a part in stars luminosity profile.
Likes hyunxu
And internal structure. Red giants may be a modest fraction of all stars, but they are a large part (though not a majority) of bright ones.
Likes hyunxu
  • · Replies 49 ·
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 21 ·
