The term mutual velocity, can be described as?
  • Thread starter Thread starter JohnnyB212
    Term Velocity
The discussion revolves around the concept of "mutual velocity" in the context of a collision between two players in a physics problem. The original poster presents a scenario involving a tackler and a halfback, providing their masses and initial velocities, and seeks to understand the mutual velocity after their collision.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the definition of mutual velocity and its implications in a collision scenario. The original poster questions the use of certain velocities in their calculations and expresses confusion about determining a common velocity after the collision. Others suggest re-evaluating calculations and applying conservation of momentum to understand the situation better.
The discussion is active, with participants providing guidance on the concept of mutual velocity and the nature of the collision. There is an ongoing exploration of the correct equations and methods to apply, particularly regarding the assumption that the two players move together after the collision.
Participants note that the collision is perfectly inelastic, which influences the approach to calculating the mutual velocity. There is also mention of directionality being important in the context of the problem.
JohnnyB212
The term "mutual" velocity, can be described as?
A 110 kg tackler moving at 3.0 m/s meets head-on (and tackles) a 95 kg halfback moving at 7.5 m/s. What will be their mutual velocity in meters/second immediately after the collision?
m1 = 110kg
V01 = 3.0 m/s
m2 = 95 kg
V02 = 7.5 m/s
V1f = Final Velocity of the 110 kg tackler
V2f = Final Velocity of halfback
V1f = ((m1-m2)/(m1+m2))V01
V2f = ((2m1)/(m1+m2))V01
V1f = 1.68
V2f = 24.68Am I correct for both? How would I determine the mutual velocity? I noticed V02 wasnt used, so I'm a little confused, any help would be appreciated, thanks.
"Mutual" in the sense of "shared in common". The two players stick together after the collision and thus have the same velocity.
Redo your calculations with that in mind.
Was the equation correct?
Oh! I caught myself on the V1f, which is actually .5897
Still, confused about the mutual portion. How are you to determine the common similarities of two completely different numbers?
No.
Instead of plugging into some formula (which doesn't apply to this situation), why not just apply conservation of momentum?
The collision is perfectly inelastic (they collide and move together). Hint: Direction matters--they are headed toward each other.
  • · Replies 17 ·
  • · Replies 17 ·
