The typical and the exceptional in physics
445 replies · 33K views
Simon Phoenix said:
Is it just fancy maths or is there really something there? Well whenever we put a test charge in this field we can see it responds to 'something' - it feels a pull or a push. Furthermore, this pull or push is precisely described by this mathematical model. The mathematical model is a very faithful model of something that actually happens. I think it's stretching things a bit to describe the maths as being essentially divorced from the reality here. There really is something that behaves to all intents and purposes as if it were the physical analogue of our mathematical model.
Of course we may need to adjust that picture in the light of new evidence (Newton's gravitational 'force' being replaced by a bending of the fabric of spacetime is a prime example of a very radical revision of our picture of things).
I just don't think 'science' is only about building successful epicycles.
The goal of science is unification of its concepts, so epicycles are generally regarded as science going in the wrong direction. But making unification the goal is simply because we wish to understand, not because there is some unified "thing" there that we are understanding. Remember that when Kepler's laws replaced epicycles, the excitement was because the laws were better unified (ellipses have only two free parameters). This gave the promise that a simple dynamical theory might underpin them, which was then discovered by Newton. That's all great, this is science doing what it tries to do-- all without ever mentioning anything except models and predictions. The mistake is in the incorrect inference that since Newton's laws are so successful, they must represent, or even approximate, some other set of laws that "rule" what actually happens. Laws that rule is an obvious anthropomorphism, and anthtropomorphisms are the clearest form of epistemology. This is the great irony-- whenever we see ontological language, it never takes long for that language to get anthropomorphic, which is the clear sign that it is really epistemology disguised as ontology. Even the concept of a "pull or a push" is anthropomorphic. There's no problem in building these pictures, they help us understand-- let us merely recognize that our goal is understanding, so we will build pictures, and we will try to make those pictures as anthropomorphic as possible. But there's no need to pretend we are not doing that, to pretend we are talking about "what really is."
Thus, if someone says let's picture a pilot wave so we can maintain a classical view of quantum mechanics, on the grounds that classical pictures gibe best with our daily experiences, I say more power to them-- but I also notice the explicitly epistemological character of that language. It's the same for the epistemological character of the thermal interpretation, or any interpretation of quantum mechanics. It's only when the language gets ontological that I say, don't you see the contradiction in making choices about your approach to thinking about reality and calling those choices the reality itself?
zonde said:
Sort of. I would say that "one can picture that matter is made of atoms to greatly simplify different theories about matter (in chemistry and physics)".
And I can agree with that, this is using atoms for what they are meant to be in science. Some people find that unsatisfying, because they want atoms to be more than that, but this comes at the cost of making science less than what it should be.
Hmm, how would look alternative formulations of these theories without some element that takes place of atoms. Just thinking.
The hardest thing is to think outside the paradigm, without having an observational mandate to do so! Even Einstein needed the Michelson-Morley experiment. But it's certainly true that any new theory of matter must be able to explain why the old one worked so well. What amazes me is how easily we discard the ontological thinking of past generations, at the same time that we cling so tightly to our own.
I may agree with you, but not everybody does, on this purely philosophical point. If you go look at the philosophical debate on this, it's really not going to work to tell them "don't you see that..."
You have realist philosophies that still go on with logical positivism as if it wasn't already demolished, because they want to keep the intrinsically descriptive quality of language and act "as if" because they don't see an alternative. You'll see things like Tarski's t-schema to justify the ontology of assertions ('snow is white' is true if and only if snow is white). You don't want to go there, unless you want to go there and do philosophy. Otherwise you just learn to be scientifically agnostic and avoid the point, unless you find a clever way of addressing these things scientifically like PBR did.
atyy said:
But you are the one promoting ontology! If you don't care about ontology, you would not object to collapse.
I think I understand the position of @vanhees71 , as well as your position, so I believe I can explain his position in a way you can understand.
There is a consistent way to protest against collapse without caring about ontology. To do this, the most important thing is to define words one is using. So let us give the definitions:
Definition 1:
Wave-function is a mental tool used by people who understand QM.
Comment: A 100 years ago wave functions did not exist.
Definition 2:
Wave-function update is a mental act by a person who understands QM. In this act, an old wave function is replaced by a new wave function, with intention to better represent the new knowledge acquired by new measurement results.
Definition 3:
Wave-function collapse is any sudden change of wave function which cannot be described by a Schrödinger-like equation and cannot be classified as a wave-function update.
Comment: From those definitions it follows that collapse and update are mutually exclusive.
Now we need the rules for using the wave function (according to the minimal ensemble interpretation):
Rule 1: ##|\psi|^2## is probability density.
Rule 2: If no results of measurements are known, ##\psi## should be considered as changing with time according to a Schrödinger-like equation.
Rule 3: When results of measurement are known, the wave function should be updated.
Comment: The rules are not the axioms. The purpose of the rules is to provide a practical user manual.
Observation 1: From rules and definitions above it follows that wave function collapse should never be used.
Observation 2: Nothing of the above depends on ontology.
I should have reframed that as "tell my why this is not a blatant contradiction in logic." That offers the possibility that perhaps they can provide a reason that it isn't, that I am simply not seeing-- because it sure looks like a blatant contradiction to me!
It's a tricky business, I will agree. All too often these kinds of arguments seem to embed their perspective in an implicit way, like a sleight of hand, disguising that what emerges as a conclusion was slipped in secretly. Of course all logic involves theorems that stem from postulates, so we all assume what we prove, but the sin is in hiding the key assumption so it seems like the theorem follows from a smaller set of assumptions than what is actually required. I regard PBR as a classic example of that-- they argue for the necessity of regarding the wavefunction as ontic by producing contradictions in certain types of epistemic thinking about it, but they embed a key ontic assumption when they assert that systems have attributes. So they assume an ontic playing field, and then "prove" that epistemic views can't play on that field. This should not be too surprising. So in my opinion, all QT is used to do in PBR is provide a suitably complex and subtle milieu to make it possible to conceal the sleight of hand there, like any good magician does.
Of course the other camp has a reason, which you will find, with each of your counter-arguments, more and more refined and subtly contradictory! :)
This is interesting, but can you formalize this objection?
The PBR proof requires that systems have attributes, does it not?
Definition 1:
Definition 2:
Definition 3:
It seems to me that all the definitions rules and assumptions depend on ontology, unless you assume from the onset there is a version of QM that is devoid of any ontology to begin with, but I can't see how since that would be starting with the conclusion as a premise..
Why do you think so?
As I understand it, PBR theorem attacks realist but with epistemic wave function camps. Not non-realist camps. So of course they must assume an underlying ontology AND an epistemic wave function, which they disprove under certain assumptions.
I think I take a different view. That there are 'laws' of nature is an inescapable conclusion. There is something making them there damned apples drop on our heads. I want to know two things (a) what are those laws? (b) why are they like they are? I may never get a fully correct, or complete, answer to those questions - and I admit that they may not even be answerable questions in all cases, maybe the best I'll get is an approximation - but why not shoot for the moon instead of trying merely to throw something over the garden fence?
Perhaps a better way of stating the role of science, in line with Popper's approach, is to suggest that part of the job of science is actually to reject certain ontologies. Atoms exist - and we can even 'see' the pesky little critters - but atoms are themselves only an approximate conglomerate of a deeper picture.
When you say "people who understand QM", you are introducing some specific form of understanding QM, even if it is the so called minimalist one, you are then assuming this particular understanding of QM doesn't have an implicit ontology, but certainly the minimal interpretation has some ontology about the probabilistic basis underlying nature or about considering observables certain objects inherited from classical physics just to giv some examples.
(a) is a scientific question and now answered by General Relativity as the best description of gravity. (b) is not answered by science. You are free to believe anything you like about it and never get disproven by science.
I'm not sure I'm getting your point here. If we wish to understand, surely we want to understand something, don't we? . If the goal of science is unification of its concepts it must mean those concepts are referred to something with features that point to a unique substrate? When you say "model and test", you mean model and test what?. Or are you just against a bad use of the word "reality" that you prefer to substitute by "ever perfectible model"?
I think I can agree with position that atoms is something more than just a thinking tool. Say if we believe that future models can modify our concept of atoms but they will never get completely rid of them then we believe they represent something real. For me it is unthinkable how we could describe human DNA without concept of atoms. And it is unthinkable that we could replace human DNA model with something completely different.
Can you give some examples so that it is easier to understand what you have on mind?
For a human physicist, it is probably impossible to think about nature without having some implicit notion of ontology in mind. But for practical purposes, it is not necessary to be explicit about ontology. The minimal ensemble interpretation does not deny that some ontology exists. It merely refrains from saying anything explicit about it. If you want to say something explicit about ontology (which is legitimate and, in some cases, even desirable), you must step out of the minimal ensemble interpretation.
That is not true. In some cases, science (especially physics) can say why a law is such and such. In other words, some laws can be derived from other (more fundamental) laws. E.g. the Ohm law can be derived from the general laws of electrodynamics.
Ok, but since you admit that it has an implicit ontology that it's simply moreless hidden from view, it gives atyy some motives to say that vanhees71 is actually defending that hidden ontology, and exploiting the advantage of feeling free to criticize other more explicit ontologies in the safety that his own is hidden in a more implicit model.
Yes, I agree with that. I don't think that vanhees71 is always consistent about ontology. But he is consistent in that he does not care too much about ontology, and it is OK to be inconsistent about something you don't really care about. If I want to clear up some ontological questions, I will not discuss them with vanhees71. And he is probably fine with that. He is much better in technical questions (certainly better than me and atyy together), and he knows it.
Perhaps we could all agree that measurements exist? Because I honestly think that is the only ontology a physicist needs.
Demystifier said:
Hmm, logically it may be possible but maybe you can agree that Ockham's razor would favor a more economic ontology without a divide between what's hiden and not hidden.
Maybe. :wink:
Yes, that seems fair, but I would have said that realist epistemology is doomed from the start, even in classical physics. The basic problem is that if you say "atoms are real but what we mean by atoms in science isn't," the contradiction can be exposed by asking "but when you use the concept of atoms in science, don't you mean atoms in science?" If they say no, you simply show where they used the atoms-in-science in their approach to atoms, and if they say yes, you simply show that the initial statement is self-contradictory. Either way, it's a contradiction, the theory being applied is just the distraction that takes the eye off the magician's hand.
Would you say you understand logic? I mean, does it make sense that if A implies B and B implies C, then A implies C? So what is the "something" you understand there? The something is a way of thinking. That's what we always understand-- whenever we understand anything, what we understand is a way of thinking. But there is no ontology of logic, logic isn't a "thing" to understand. It's also not a single entity-- we can mean logic with the axiom of choice, or logic without the axiom of choice, and we can allow for fuzzier notions or use a black-and-white version. If those are all different "things" to understand, then which is the one that's real? Or if "things" don't have to be real, how to you tell a real thing from a nonreal thing? These are the problems with ontology. But for science, the problem with ontology is more basic-- attributes of systems are not testable, attributes of models of systems are testable. We test maps, not territories, so what we need for science are maps, not territories. So you ask, but if it's a good map, what is it a good map of? And I say, I could only answer that with yet another map, so the good simple map substitutes for the more complicated and less understood map.
Why must it mean that? If you regard that as a hypothesis you intend to test, you are being scientific, but good luck testing it. If you regard that as a self-evident truth, I say self-evidence is not the kind of evidence science uses. I know what you are saying, you are saying that if a law of physics works in almost all places and almost all times, what is it that unifies the effectiveness of the law, it must be a unique substrate. But I say that we wouldn't call it a law if it didn't have that property, and we don't need a reason for it to have that property-- we don't test the reasons models work, we just test models.
Test the model against the observations. All you need is to be able to know a model when you see one, and an observation when you see one, and a correct prediction when you see one. That's it, no "things" necessary, except for the pictures we use along the way-- those are always our "things", they are always pictures. But the irony is, pictures are not generally regarded as themselves things, so we are still left with no things.
I say the way the word "reality" gets used in science is "that which we are using science to understand." So what are we using science to understand? We are trying to understand a successful mode of thinking, a mode that is powerful and unifying, passes a load of objective tests, and helps us make good decisions by developing expectations that are borne out. No ontology necessary, indeed whenever ontology appears, science stumbles and has to pick itself up again later-- as it has done so many times before.
I'm not really convinced of that. I think classical physics is essentially ontological in nature (and becomes more epistemic when we consider complex systems that require a statistical approach).
I mean if I give a golf ball a really nice satisfying thwock it's going to travel from A to B on a parabolic path. If I manage to exactly reproduce the same swing with another ball - it's going to follow exactly the same parabolic path (OK I have to neglect air resistance but I hope you see the point). Classical physics doesn't fart about trying to get all philosophical about whether we're describing 'reality' by writing down a quadratic equation for the trajectory - it would actually say that the golf ball IS traveling on a parabolic path. I don't see anything at all epistemic about that and it would be absurd (classically) to try to describe the equation as merely a representation of our 'knowledge' rather than descriptive of something that's actually happening.
It's really only QM that messed things up and lead us down the philosophical rabbit hole.
For Ken G, I'd guess that doesn't prove anything, or maybe it could even prove that we had to get to a certain point to have our illusion shattered - which QM did - and make us wake up to the intrinsically epistemological nature of science.
But anyway, Ken G, I still suggest you look at Feyerabend. For him, Popper wasn't too harsh with ontological presuppositions, he was too gentle, in fact Feyerabend showed that Popper's is yet another form of positivism, albeit a more refined one (here positivism is meant in the proper sense, that one recognizes only that which can be empirically verified in the sense that reality is positively characterized by empirical inquiry). I don't want to get into this but you seem to be very interested in philosophy so I'll point to that which IMHO is important for understanding the situation, even if you don't agree with that.
Ken G said:
I wouldn't call it "very special circumstances" when those are the only circumstances we ever test!
I don't know whom you subsume under ''we'', but most physicists never make a quantum textbook measurement.
Already real measurements of position have an uncertainty of fuzzy width that cannot be described at all by collapse to an eigenstate (which doesn't exist), and only imperfectly by POVMs, the most advanced ''simple'' measurement recipe discussed in the foundations.
Measuring photons destroys them, rather puts them into an eigenstate of anything.
Just about any real measurement doesn't fit the straightjacket of a textbook description. The Stern-Gerlach experiment is almost the only exception.
ddd123 said:
does this old post of yours describe an aspect of your thermal interpretation, a consequence of it, or is it an addition?
Extended causality is most likely a consequence of relativistic quantum field theory, together with the thermal interpretation (which assigns reality to extended objects only).
Definition 1:
Definition 2:
Definition 3:
It doesn't work, because the update is nonlocal in the sense that a correct way of updating the wave function is to assign it to a hyperplane of simultaneity, and then updating it instantaneously by non-Schroedinger evolution across the hyperplane.
There is no collapse, only updating, but the updating can be considered nonlocal.
Objecting to a nonlocal update does depend on ontology, since the update does not conflict with the locality of relativistic QFT.
Another way of saying it is that ontology is a tool for performing wave function updating. In that ontology, wave function updating is nonlocal. And there is nothing about that nonlocality that conflicts with QFT - unless one is mistaking the locality of QFT to be ontological.
