The Uncertainty Principle Uncertainty
In summary: That being the case a particle at rest in QM is not possible because that would mean knowing it position and momentum simultaneously - unless of course you mean by at rest zero momentum but you don't know where it is - that is possible - but I don't think that's what's usually meant in saying an object is at rest.ThanksBill
  • #36
i think you do understand what i said,i.e uncertainty principle is frame dependent.and i really mean ,for any measurement we do need a reference frame and since there is no universal reference frame,so i generalize that any measurement whatsoever it be is frame dependent.
  • #37
The uncertainty principle is the same regardless of frame. In fact the POR implies it must be the case - the laws of physics are the same in any inertial frame.
There is certainly no universal frame, at least as far as we can tell today, but regardless of what frame is used to make the measurements the uncertainty principle applies.
Thanks
Bill
  • #38
Thanks
Bill
what u suggest is correct ,but there is small mistake in understanding what i said is principle of uncertainty remain invariant of frame what changes is outcomes of measurement , so in short outcomes of measurement are subjected to frame of reference not the principle itself (satisfying the P.O.R-law of physics does not change in any inertial frame. )
  • #39
Ah, that's much more clear. It sounded as though you were saying that the uncertainty was frame dependent in a way that would allow for NO uncertainty, which would of course violate the HUP.
  • #40
exponent137 said:
How to describe UP of a photon? It is at location 5 m from us and its momentum is 10^-20 kg m/s.
Because, the simplest explanation of UP is Fourier transformation of a position wave function of a rest particle. This gives a momentum wave function. Square of absolute value of both of them are gaussian distributions and this gives thicknesses of these distributions and then product of thicknesses of both distributions.
How to describe gaussian wave function of the photon?
Because you are talking about reference frames, this is similar to my question. How How to describe gaussian wave function of the photon? And how to derive uncertainty for photon? It does not belong to the common derivation of uncertainty.
  • #41
Usually we say that the measurement outcomes are events in the sense of classical special relativity, so they are frame invariant in the classical sense.
But I guess you are thinking about things like http://www.infres.enst.fr/~markham/QuPa/2010Sept26/Borzu-HIPTalk.pdf?
  • #42
But that is the same for any law. The law is invariant and particulars change.
Its a trivial and well known observation.
Thanks
Bill
  • #43
The photon does not have a wavefunction in the usual sense.
A little search on this forum will give the detail of this deep and mathematically advanced issue eg:
https://www.physicsforums.com/threads/why-photon-wave-function-does-not-exist.659614/
Thanks
Bill
  • #44
How much influence does the observer have on the outcome of any measurement?
  • #45
The influence an observer has on the distribution of classical measurement outcomes that he obtains is summarized mathematically by the "observable" that is chosen. Thus for any initial given state, if the observer chooses to measure the position observable, he will get a distribution of classical positions that is determined entirely by the state and the position observable.
If the quantum system survives the measurement (ie. there is a classical measurement outcome and a quantum outcome), the distribution of quantum outcomes is summarized mathematically by the "instrument" that is chosen. A given instrument defines an observable. Thus for any initial given state, if the observer chooses to use a particular instrument that defines a position observable, he will get a distribution of classical positions and a distribution of quantum states that is determined entirely by the initial given state and the chosen instrument.
In general, an instrument used in a measurement will output a different quantum state than the initial given state, and it is usually in this sense that the observer is said to cause a disturbance.
  • #46
I little search on this forum will give the detail of this deep and mathematically advanced issue eg:
Thanks
Bill
Yes I read this thread. (Started with my question :) ) Thus, I can give a different question: How to define uncertainy principle of a photon, it its wave function does not exist. But UP exists always, also at photons?
  • #47
I don't know the answer to your question directly. But the basic reason that a photon wave function doesn't exist (except as an approximation in some single photon cases) is that one has to do field quantization for the electromagnetic field. So the commutation relations and uncertainty relations are not between position and momentum, but between various field observables. Some examples are given in http://web.stanford.edu/~rsasaki/AP387/chap3 (Eq 3.50, 3.106, 3.107).
Likes exponent137
  • #48
The uncertainty principle is actually more general than between position and momentum applying to any two non-commuting observables. That of course still applies to photons. But since position is not an observable the usual form doesn't exist.
Thanks
Bill
Likes exponent137
  • #49
Thanks
Bill
You and Atyy give persuasive explanations.
It is understandable to me, that photon location is not defined. But, how its momentum is defined? It seems to me, that it is defined?
It is known that background of QFT is spacetime of Minkowski. It is defined in everyone point. Why then location of photon is not defined? Maybe, its location is defined only at begin and end locations of photons? (vertex as it is said in Feynman's graphs).
  • #50
Thanks mate - but I generally find Atyy hones onto the key points better than me. I can meander a bit before the key thing jumps out.
Momentum is a different matter - being pretty much always definable via Noethers theorem:
http://eduardo.physics.illinois.edu/phys582/582-chapter3.pdf
Its a difficult issue:
https://www.physicsforums.com/threads/is-position-not-an-observable-of-a-photon .
Intuitively I view it because it travels at the speed of light there is no frame where its at rest so it can't be stopped to find its position, but basically that view is a crock.
Unfortunately the correct answer is rather advanced:
http://arnold-neumaier.at/physfaq/topics/position.html
Don't you hate it when things are like thato0)o0)o0)o0)o0)o0)o0)o0)
Thanks
Bill
  • #51
Actually, many key points I learned from bhobba - especially about Gleason's and noncontextuality!
  • #52
of course. carbon statistically only has probability of its stationary atoms being exactly the same and over time there is also a statistically probable average that some will randomly change. Thus, the uncertainty principle applies to pretty much everything.
  • #53
The way I've always understood the uncertainty principle (which isn't necessarily correct of course) is in terms of textbook introductions, where the information (such as position or momentum) is dependant on the extent to which you can physically extract such information in a physical setup.
I've found this is typically explained in relation to macro-scopic observations, where any measurements on a macro-scopic object need not adversely affect what the object in question is otherwise doing (had you not made the measurement). But in terms of subatomic objects, they are so fragile that any measurement you made on them would adversely affect the object, ie. compared to the case where you did not make a measurement on it. At least that is the idea. So there would be a fundamental uncertainty on what kind of information you can physically extract from the object, ie. in terms of that which you might like to be representative of the object considered as otherwise unmeasured.
Now to say an object is stationary, it seems to me, presupposes that you could obtain the information necessary to make such a statement in the first place. But if I understand the uncertainty principle correctly, you can't make such an assumption in the first place, ie. you can't represent some object as stationary in the first place. The uncertainty principle would rule it out.
If I understand the principle.
Carl
  • #54
Carl
what if the subatomic particles masses are balanced out (thus zero) by the force of them rotating around the sun.
  • #55
In my understanding the uncertainty principle is not about the predictability of the measurement setups, it si the intrinsic property of the quantum particles.it means that all of the properties of the particles do not change with the time continuously.
  • #56
Continuity really has nothing to do with it.
It got to do with the commutation properties of observables.
Thanks
Bill
  • #57
UncertaintyAjay said:
My friend and I had this argument about whether or not the uncertainty principle is applicable to stationary particles. I maintain that it is, because the principle is really about predictability ( isn't it?) But he maintains that it doesn't. So I would just like to clear things up . Does it or doesn't it? Thanks in advance.
from my point of view, there is still apply uncertainty principle even the particles in stationary states. since we not live in isolated system therefore how can you be sure that the object or particles are in absolute stationary..
do correct me if I'm wrong ^_^
  • #58
Object is stationary in one inertial system. Photons are not stationary in any inertial system.
  • #59
The original question is an ill-posed question. It's premise is faulty.
The Uncertainty Principle requires that we do not (or can not) represent a particle as in a stationary state in the first place.
To propose a particle at rest would require that we simultaneously represent both the position and momentum of the proposed particle. But the Uncertainty Principle rules out such a proposition.
Mathematically there would be no problem proposing a stationary particle since we can easily conceive such a particle, but mathematics doesn't have the same limitations as QM. The Uncertainty Principle requires the employment of Plank's constant as a limit.
C
  • #60
carllooper said:
The Uncertainty Principle requires that we do not represent a particle as in a stationary state in the first place.
That's untrue.
Its a statement about non-commuting observables and applies to any state - stationary or otherwise.
Thanks
Bill
  • #62
bhobba said:
That's untrue.
The use of non-commuting variables follows from the principle, not the other way around. There's nothing in mathematics that requires that two variables be non-commuting.
I saw the link on "stationary state" so perhaps that's where we are getting our lines crossed once again. By "stationary state" I read the question as meaning "at rest". As many respondents have as well. So it's in that context (as should be obvious, but obviously not) that I am speaking.
C
  • #63
That also is incorrect.
It is a theorem of non-commuting observables.
Thanks
Bill
  • #64
What motivates the use of non-commuting variables? It is the concept of non-commuting observables. This is a limit proposed in QM. It is not a limit that is in any way required in mathematics with respect to two variables used to otherwise represent a particle at rest.
That's the point being made. But more importantly is why this point is being made. It's being made in the context of an assumption (rightly or wrongly) that the question, as well as many of the answers, are intending by "stationary state", or "stationary particle", the concept of a particle at rest.
Have a read of the thread. It becomes obvious from the discussion that by "stationary particle" is meant a particle at rest.
And it is in this context (not some other) that the Uncertainty Principle is being elaborated as ruling out such a proposed particle, ie. where mathematics itself does not.
C
  • #65
What has motivation got to do with validity? When I muck around investigating a mathematical structure trying to prove something, or simply out of curiosity, all sorts of things motivate me - or maybe nothing at all. Either way its got nothing to do with its implication.
carllooper said:
Have a read of the thread. It becomes obvious from the discussion that by "stationary particle" is meant a particle at rest. And it is in this context (not some other) that the Uncertainty Principle is being elaborated as ruling out such a proposed particle, ie. where mathematics itself does not.
In QM words have a definite meaning. Stationary state is entirely different from stationary particle. Indeed a state where a particle is at rest with a definite position is impossible.
Thanks
Bill
  • #66
I think you'll find the Heisenberg Uncertainty Principle is more than just a mathematical proposition. It has it's origin in experimental physics. Bohr sums it up quite well in this 1949 section of "Discussions with Einstein on Epistemological Problems in Atomic Physics" (highlights mine):
The way to the clarification of the situation was, indeed, first to be paved by the development of a more comprehensive quantum theory. A first step towards this goal was the recognition by de Broglie in 1925 that the wave-corpuscle duality was not confined to the properties of radiation, but was equally unavoidable in accounting for the behaviour of material particles. This idea, which was soon convincingly confirmed by experiments on electron interference phenomena, was at once greeted by Einstein, who had already envisaged the deep-going analogy between the properties of thermal radiation and of gases in the so-called degenerate state. The new line was pursued with the greatest success by Schrödinger (1926) who, in particular, showed how the stationary states of atomic systems could be represented by the proper solutions of a wave-equation to the establishment of which he was led by the formal analogy, originally traced by Hamilton, between mechanical and optical problems. Still, the paradoxical aspects of quantum theory were in no way ameliorated, but even emphasised, by the apparent contradiction between the exigencies of the general superposition principle of the wave description and the feature of individuality of the elementary atomic processes.
At the same time, Heisenberg (1925) had laid the foundation of a rational quantum mechanics, which was rapidly developed through important contributions by Born and Jordan as well as by Dirac. In this theory, a formalism is introduced, in which the kinematical and dynamical variables of classical mechanics are replaced by symbols subjected to a non-commutative algebra. Notwithstanding the renunciation of orbital pictures, Hamilton's canonical equations of mechanics are kept unaltered and Planck's constant enters only in the rules of commutation h
qp - pq = -(h/2p) , (2)
holding for any set of conjugate variables q and p. Through a representation of the symbols by matrices with elements referring to transitions between stationary states, a quantitative formulation of the correspondence principle became for the first time possible. It may here be recalled that an important preliminary step towards this goal was reached through the establishment, especially by contributions of Kramers, of a quantum theory of dispersion making basic use of Einstein's general rules for the probability of the occurrence of absorption and emission processes.
Yes, a particle at rest is impossible. That's the point that was being elaborated.
Regarding semantics, the original question does not use the phrase "stationary state". It uses the phrase "stationary particle". And subsequent elaboration by the author of the question makes it quite clear that by "stationary particle" is not meant "stationary state". And the following comment, does not use "stationary state" either:
"Object is stationary in one inertial system. Photons are not stationary in any inertial system."
And yet, it is precisely in response to the above statement that you make the completely irrelevant point:
"Thats not what stationary state means"
It's obvious throughout the entire discussion that by "stationary" is intended the classical/relativistic use of that term. The discussion on frames of reference and inertial systems and "photons not stationary in any inertial system" make this exceedingly obvious.
I'm the one that actually used the phrase "stationary state" and I'm now very much regretting that I did so.
C
  • #67
Things have moved on a lot since then.
That was all swept away when Dirac developed his transformation theory in December 1926 and generally goes under the name Quantum Mechanics today.
Its a theorem - no ifs or buts about it - see page 223 - Ballentine - Quantum Mechanics - A Modern Development.
Emphasis mine.
QM, as found in Ballentine, is based on two axioms - for an elaboration of that, see post 137:
https://www.physicsforums.com/threads/the-born-rule-in-many-worlds.763139/page-7
The KEY axiom is:
'An observation/measurement with possible outcomes i = 1, 2, 3 ... is described by a POVM Ei such that the probability of outcome i is determined by Ei, and only by Ei, in particular it does not depend on what POVM it is part of.'
Observables etc, which may or may not commute, follow from that. For example does the spin observable commute with position? The uncertainty relations is a theorem about observables that do not commute.
Regarding the stationary state thing, you are entitled to use words in anyway you like, but its good practice to use them in the standard way because it makes reading and understanding by others much easier. Even then the standard use of words like observation etc in QM leads to problems - but we are stuck with it.
Thanks
Bill
  • #68
bhobba said:
Things have moved on a lot since the famous, and it must be said magnificent, Einstein Bohr debates where pictorial visualisations were often used. They were mostly incorrect BTW - its really got nothing to do with firing photons at objects etc - that's just for pictorial vividness. But that was the early days of QM - much water has gone under the bridge since then - and wasn't really Einsteins deepest objection to the theory anyway which was detailed in EPR.
While a lot has certainly happened since those days, it's still as relevant today as it was then. The Uncertainty Principle remains the same principle. It hasn't changed. It's been elaborated of course, but the origin of the principle remains the same. You can't just change that because it happened so long ago. Or rather, if you did, you'd probably want to call it something else.
Also, Bohr might have used pictures but he certainly didn't encourage them. Indeed he famously had a go at Feynman for using a pictorial representation of quantum mechanics. But as Feynman demonstrated you can indeed use pictures (or diagrams) to represent a useful concept, ie. as much as any other way. And Feynman's integral path is a very clever way of elaborating the physics in a pictorial way.
The basics of physics is still very much the same as it ever was, ie. elaborating or inventing what can be otherwise demonstrated in a physical experiment. That hasn't changed. Otherwise it's no longer physics. This doesn't preclude a mathematical line of enquiry, but the expectation is still that it can be demonstrated in a physical setup. You may not know that in advance of course. So it's not a pre-requisite. More of "post-requisite". And there's plenty of room for a greater mathematical understanding of the physics we already have. Efforts to build a quantum computer, for example, don't (on the face of it) require the introduction of any new physics (although it might), nor need it involve any physical experiments for that matter, but can still require a significant amount of mathematical work be done to resolve a candidate solution. But the physical solution will involve building it - demonstrating it in practice. Even if, as theorists, we already know it will work.
And as a side project, of course, is always the ongoing fascination with the weirdness - what are we missing? Are we missing anything? The interpretative game.
C
  • #69
Its physical basis has changed - its simply a theroem abnout non-commuting onservables. Observables can be commuting or not - the uncertainly principle applies to non-commuting observables as a general therorem.
Pictures are sometimes useful - sometimes not. It is now known those ancient discussions about the uncertainly principle are wrong. Feynman OTOH was simply using pictures to represent terms in a perturbative expansion - which Bohr didn't appreciate at the time.
Actually the basic rock bottom essence of any science, including physics, is its all provisional, subject to one thing, and one thing only - correspondence with experiment. The old ideas of Bohr etc etc have been replaced, as undoubtedly many of our current ideas will be replaced. Some have remained unchanged (eg the Copenhagen interpretation remains basically the same) and some have been swept away (eg those ancient discussions about observation disturbing the system as the basis of the uncertainty principle - it isn't).
Who knows what future progress will bring. If I knew I would be out collecting my Nobel prize.
Interpretations are more a psychological crutch IMHO, but each to their own, preordaining anything is not how science progresses - some interpretation may prove to be of vital importance for the next breakthrough.
Thanks
Bill
  • #70
Which is how the principle is being used - as a theorem. There is no suggestion whatsoever that it's being used as anything other than a theorem.
I don't know what the fuss is all about. If one is going to use the concept (or theorem, or whatever else one might like to call it) then it's going to conflict with the concept of a particle at rest. Or vice versa. They don't agree with each other. Today or yesterday. In modern times or 'ancient' times.
C
  • Quantum Physics
  • Quantum Physics
