The value of the spring constant k that I calculate seems too high
The discussion revolves around calculating the spring constant \( k \) in a scenario involving energy conservation between gravitational potential energy and elastic potential energy. The original poster calculates a high value for \( k \) based on a mass rolling down a hill and compressing a spring.
  • Participants discuss the calculation of \( k \) and question the validity of the high value obtained. There are inquiries about the details of the calculations and the necessity of including units. Some participants suggest considering rotational motion and energy conservation principles, while others express skepticism about the assumptions made in the problem.
The discussion is active, with participants providing guidance on the need for detailed calculations and questioning the assumptions regarding energy conservation. There is a mix of interpretations regarding the role of rotational motion and friction in the scenario, indicating a productive exploration of the topic.
Participants note the unusual input numbers and the lack of clarity regarding the rotational dynamics of the ball. There is mention of homework constraints and the need for careful consideration of energy types involved in the problem.
dannolul
A ball of mass 73kg starts at the top of a 52m high hill with a speed of 20.0 m/s. It rolls down the hill onto a spring and compresses it to a maximum of 46.5cm. Find the spring constant of the spring.
Et1=Et2
ek1+eg1+ee1=ek2+eg2+ee2
ek1+eg1=Ee2
Ek= kinetic energy (1/2mv^2)
eg=Grabitational energy (mgh)
Ee=elastic energy (1/2kx^2)
I expanded ET1=ET2 to get
(Total energy at top) 1/2mv^2+mgh = 1/2kx^2 (Total energy at bottom)
Rearanged i got
k = (mv^2+2mgh)/x^2
so [(73)(20)^2+2(73)(9.8)(52)]/0.465^2
=479137.945N/m
Please show the details of your calculation. Without them, we cannot find where and if you went wrong. Also, when you quote numbers you must attach units to them. 479000 is meaningless all by itself.
Oh Sorry, was on my phone and rushing.
Rearanged i got
k = (mv^2+2mgh)/x^2
=479137.945N/m
Rearanged i got
k = (mv^2+2mgh)/x^2
=479137.945N*m
You mean 479000 N/m. That’s what I got. Why do you think it’s too high? You have a 73 kg mass starting at the top of a 50 m hill initially at 45 miles per hour. When it starts compressing the spring, it’s moving at about 84 miles per hour. It must be quite a spring to stop that mass over a distance of about 2 feet.
In class we havnt really talked about high k constant and only worked with small k constants. So it seemed a little skeptical as I didnt think it should be that high. Appreciate the help.
Other than the unusual input numbers, I am bothered by the solution that conserves energy without considering the rotation of the ball that is clearly said to "roll down the hill." Have you studied rotational motion? If so, you can recalculate the speed of the center of mass of the wheel taking the rotation of the wheel into consideration.
However, in that case one has to consider how the kinetic energy of the wheel is converted to elastic potential energy in the spring without energy dissipation by friction as the ball rolls (?) an additional 46.5 cm before it comes to rest.
I suspect it was just unintentional wording. No radius for the ball either.
EDIT: never mind that is independent of the radius, I still suspect poor wording.
What would stop it rotation at the bottom; the friction with the ground? if so, all of its rotational kinetic energy would be lost to heat regardless, no? Or if there was no friction at the bottom (on either the ground or the spring) it would just be spinning freely at whatever angular velocity it had as it compressed the spring.
Exactly. One has to assume that there is no friction at the bottom. In that case only the translational kinetic energy will be converted to elastic energy which is results in the solution already obtained.
What bothers me more is that mechanical energy would not be anywhere near conserved if you actually did what's described in this scenario.
You want to be careful with statements like this and the misconceptions they generate. Heat is a transfer of energy due to a temperature difference. The correct statement is that the rotational kinetic energy (or indeed any form of mechanical energy) is converted to internal energy.
This distinction becomes important when you study the First Law of Thermodynamics.
It's not a good problem. I give it a C-.
The normal force from the spring will (soon) be much greater than that from the ground. Even a small frictional coefficient against the spring will lift it off the ground completely.
  • · Replies 58 ·
