Can the weight of heat be accurately measured in such small increments?
  • Context: Graduate
  • Thread starter Thread starter alba
    Heat Weight
The discussion centers on the measurement of mass increase due to temperature changes in gold, specifically addressing the claim that a 10°C rise in temperature results in a mass increase of 1.4 * 10^-14 kg. Participants clarify that the energy added to the gold can be calculated using its specific heat capacity, which is 0.126 J/gmK, leading to an energy increase of 1260 J for 1 kg of gold. The use of E=hf to relate energy and mass is deemed inappropriate in this context, as it does not pertain to the mass increase calculation. The conversation emphasizes the importance of using correct physical relations and units when discussing energy and mass.
  • Understanding of specific heat capacity, particularly for gold (0.126 J/gmK).
  • Familiarity with Einstein's mass-energy equivalence principle (E=mc²).
  • Basic knowledge of energy units, including joules and electronvolts (eV).
  • Ability to perform calculations involving temperature changes and energy transfer.
  • Research the principles of heat capacity and its applications in thermodynamics.
  • Learn about the relationship between energy, mass, and temperature changes in materials.
  • Explore the concept of mass-energy equivalence in detail, including practical examples.
  • Investigate precision measurement techniques for small mass changes, such as microbalances.
Physicists, materials scientists, and engineers interested in thermodynamics, energy transfer, and precision measurement techniques will benefit from this discussion.
alba
I read that if the temperature of 1 Kg of gold rises by 10°C its mass increases by 1.4 * 10^-14 kg.
Can you please explain how you get such value from E= mc^2?
I think the increase corresponds to E = h f =1.53*10*10^36 and since
1 kg has 1.1*10^30 electrons, each one gets 1.4*10*6 h
but
10 degrees correspond to energy E = h f = 2.8*10^11 h)
so shouldn't the increase of energy be 2.29*10 ^41 h?
Can you also tell what instrument can measure the weight o 10^-14 Kg and what is the minimal weight that can be detected?
Science news on Phys.org
It is completely unclear what you are trying to do. E=hf is the energy content of a photon and has absolutely nothing to do with the mass increase of the gold. You need to figure out how much energy needs to be added and compute the corresponding mass increase.
E = 1.4*10-14* 9*10^16 = 12 = 1260 J
The energy of a joule can be expressed in many ways, in eV or in h*Herz 1260 /h = 1.9*10 ^36
what is the problem? that is the energy added, I cannot figure out how that relates to T = +10*C
Any ideas?
Which units you use are unrelated to how you solve the problem. There is no point in using E=hf here.
Just putting numbers is not a very good way to present a solution. First write down the physical relation you are using, then write down what numbers you are putting in (including units!).
The energy added must depend on the temperature increase. If yours does not, it is wrong.
To understand how to calculate the "heat" energy required to raise the temperature of something, read this: Specific Heat
Thank you very much for the links, so:
c for gold is 0.126 J/gmK 1000g, therefore 1000g*10 K makes 1260 J (1.5*10^36 hv), right?
1260 J looks good to me.
alba said:
(1.5*10^36 hv)
What's this?
What's this?
Is it so weird to refer to energy by Hz? 1 J equals 1.5*10^33 h/s, right?
Can you tell me if the weight increase is just deduced from the formula, or if it is (and to what precison) confirmed my measurement?
It simply does not make any sense. You could do this by using units of ##\hbar## but this is normally done in particle physics and this is not.
Also, in your answer you are referring to ##hf##. This makes no sense at all unless you specify what ##f## is.
So now you know E (or more precisely, the amount by which the E of the gold increases when its temperature increases by 10°C). Now, what m does this give you?
You must have missed that, in my first post I specified
f =1.53*10*10^36
This is completely besides the point. You cannot just arbitrarily select a frequency.
Apart from that, your "frequency" is not a frequency, it is a number. A number is meaningless without the appropriate physical units.
  • · Replies 25 ·
