The Work Done in Pulling a Supertanker
  • Thread starter Thread starter rock_star
    Work Work done
The problem involves two tugboats pulling a disabled supertanker with specified forces and angles, requiring the calculation of work done over a distance. The subject area includes physics concepts related to forces and work.
  • Exploratory, Mathematical reasoning
  • Participants discuss the calculation of work done, with one original poster attempting to compute the work using a formula involving force and distance. Questions arise regarding potential mistakes in the calculation.
Some participants indicate that the original poster's calculation may not contain an error, while others suggest that rounding might have affected the result. There is a mention of ensuring the correct use of degrees versus radians in calculations.
Participants note the importance of using the correct angle measurement in calculations, highlighting a common source of error in physics problems.
rock_star
Two tugboats pull a disabled supertanker. Each tug exerts a constant force of 1.90×10^6 N , one at an angle 13.0 degrees west of north, and the other at an angle 13.0 degrees east of north, as they pull the tanker a distance 0.840 km toward the north.
2 * (1.90×10^6 N) * cos(13) * 0.84 * 10^3 = 2.9 * 10 ^9
can anyone tell me where I did a mistake?
Thanks a lot before hand
It does not look like you made a mistake.
Solution to what?
It is showed that I made a mistake :(
Rounding error..
It is 3.11 not 2.9 :(
Thanks a lot though! :)
The correct answer is 3.11E+9. Make sure you use 13 DEGREES and not 13 RADIANS. If you entered into a *dumb* calculator, it usually assumes radians. Try writing
2*1.9E6*cos(13*pi/180)*0.84E3 into google, and it gives you the right answer.
11K
  • · Replies 21 ·
