What Is Relativity Theory in Simple Terms?
The discussion revolves around the request for a simplified explanation of relativity theory, encompassing both Special Relativity (SR) and General Relativity (GR). Participants share resources, suggest reading materials, and express the challenges of conveying complex concepts in a brief format.
  • Homework-related
  • Some participants suggest that explaining relativity simply is a complex task that may require extensive resources or textbooks.
  • Several recommended readings include Bondi's "Relativity and Common Sense," "Relativity for Poets" by Ben Crowell, Gamow's "Mr. Tompkins in Paperback," Epstein's "Relativity Visualized," and Orzel's "How To Teach Relativity To Your Dog."
  • One participant notes that the speed of light is invariant across all inertial reference frames and that classical concepts of space and time must be revised in light of relativity.
  • It is mentioned that classical physics remains a valid approximation in everyday scenarios where speeds are much less than that of light.
  • Another participant emphasizes the need for a good textbook, recommending Taylor & Wheeler's "Spacetime Physics" for a deeper understanding.
Participants generally agree that the question is too broad for a simple answer and that resources are necessary for a proper understanding. However, there is no consensus on a singular explanation or approach to the topic.
Participants express uncertainty about the original poster's background in math and physics, which affects the level of explanation that would be appropriate. The discussion highlights the varying mathematical requirements of SR and GR.
Jpolisa
Yes... Can someone please explain the relativity theory to me in as much simple terms as possible. It's really way in over my head. Thanks.
That's a book-length topic. Bondi's "Relativity and Common Sense" is a good way of learning it if you can find a copy. A more modern maths-free source is "Relativity for Poets" by Ben Crowell (a former moderator here) free for download at his site https://lightandmatter.com/poets/.
It's impossible to explain SR simply in a few forum posts. Have you tried googling for videos on "simple explanation of relativity", or similar. There's lots of them. You just need to find one that's pitched at your level.
It's hard to know what level of "understanding" you want, especially without knowing your background in math and physics. The mathematical requirements of Special Relativity and General Relativity are very different.
Fortunately, there are some simple introductions that are quick, easy and fun to read. Don't worry if they are too elementary, you can zip through them with no pain.
Look at Gamow's "Mr. Tompkins in Paperback". It also introduces other topics.
After that, you might be interested in Epstein's "Relativity Visualized" and Orzel's "How To Teach Relativity To Your Dog".
Beyond that, there are a lot of choices that have more mathematics. I will leave it to others who have more expertise to recommend those.
The speed of light is invariant across all inertial reference frames.
The classical, Newtonian concepts of space and time must be revised.
Classical equations for a particle's momentum and kinetic energy must be replaced by relativistic equations.
In the everyday world of speeds much less than the speed of light, the differences between Newtonian physics and SR are generally too small to be measured. Newtonian physics remains valid as a good approximation to SR in many areas of applicability.
For a deeper understanding consult a good introductory textbook.
This is much too broad a question for a PF thread. As others have said, you need to take the time to work through a good textbook. Taylor & Wheeler's Spacetime Physics is often recommended.
This thread is now closed due to the OP question being too broad. Thanks to all who responded.
  • · Replies 57 ·
  • · Replies 45 ·
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 0 ·
