What is the significance of thermal expansion coefficients in material research?
The discussion centers on the significance of thermal expansion coefficients in material research, specifically regarding the application of alumina on stainless steel using atomic layer deposition at 180°C. The thermal expansion coefficients for alumina and stainless steel are 17.3 and 8.1, respectively, indicating that they expand at different rates when subjected to temperature changes. This discrepancy can lead to thermal stress and potential failure at the interface of the materials if not properly managed. Understanding these coefficients is crucial for predicting stress levels and ensuring the integrity of the material stack.
  • Understanding of thermal expansion coefficients
  • Familiarity with atomic layer deposition techniques
  • Basic knowledge of material science principles
  • Concept of Young's modulus and its application in stress calculations
  • Research "calculating thermal stress between dissimilar materials" for practical applications
  • Learn about "thermal expansion and thermal stresses" using COMSOL Multiphysics
  • Study "Young's modulus" and its role in material deformation under stress
  • Explore the effects of temperature on material properties in "material science textbooks" or online resources
This discussion is beneficial for material scientists, engineers involved in material research, and anyone working with thermal properties in composite materials.
dstahn
Hi all,
I am very new to physics and have little to no background in engineering, however I am a biochemistry major whoe somehow wound up in material research lab.
One thing I am having trouble understanding the thermal expansion coefficients, how they relate to each other and which one I should be using. I am going to be putting a layer of alumina on stainless steel using atomic layer deposition. The heat this process is at is 180C. The thermal coefficients that I found for these two are 17.3 and 8.1. I don't really know what this means or how to decide if the difference between the two matters.
Can someone help explain it to me?
Thanks in advance
Science news on Phys.org
Not a simple answer - the specifics take some work. Google something like 'calculating thermal stress between dissimilar materials' and take a look. The idea is that the joined materials expand at different rates when temperature changes, so they pull against each other, sometimes causing failure, especially when the temp changes many times in succession.
Generating a model to predict the specific outcome for a particular situation is often an involved procedure.
Thanks for your input I'l try starting there and see if I can't find an equation to compare the two.
This is a very thin film deposited on a relatively thick substrate ?
Sorry to mix units a bit here. It would be somewhere between 5-50nm thick film on a substrate that is about 0.015" thick.
Contraction for combination will be almost the same as that of the substrate alone .
Given the low temperatures involved I doubt whether there would be much out of plane distortion .
Can you see how to go from here to getting the actual stress level in the film and comparing it with the failure stress for the material ??
Not really no. Sorry, this isn't really my strong suit and I am trying to read and learn but I just feel way out of my depth on this project.
Is there any place in particular that I should go to look at how to get these numbers? I am trying to learn so I would prefer some place that gives steps and reasons. I am fine just plugging in numbers and getting answers but I would still like to learn why and how I am getting the results.
The below might help. They are not examples of joined dissimilar materials, but they might help you understand the basic material science at work.
Not sure how basic a discussion is helpful for you - below is a very basic discussion.
If you were to glue a sheet of aluminum to a sheet of stainless steel and you were to take the joined sheets and heat them over a stove burner, they would expand at different rates, and this would cause stresses at the glue-to-steel interface and the glue-to-aluminum interface. These stresses would result in strain, deformation of the steel, the glue, and the aluminum. If the stresses are great enough to cause any of the materials to go beyond their breaking points, then something in the steel / glue / aluminum stack will fail (break). Each of the three materials has a youngs modulus (basically a spring contant) to describe how much it deforms in response to stress, and a thermal expansion co-efficient to describe how much it expands when heated. You are calculating the expansion of the different materials and the resulting stresses that come from the materials not being able to move freely (they are becoming like compressed springs). The material stack can only expand as much as the material in the stack that is least sensitive to temperature. The other materials in the stack want to expand more, but they can't because they are joined to the least expansive material.
Hope that helps at least a little.
https://www.comsol.com/multiphysics/thermal-expansion-and-thermal-stresses
http://www.usc.edu/dept-00/dept/architecture/mbs/struct/Arch213A/213A-lectures/07-Thermal-stress.pdf
Hey Grinkle, thanks so much for the run down on what it is that I am looking at. Putting it that way helped me equate it to enzymes which I am much more comfortable with. I appreciate you helping me.
  • · Replies 16 ·
10K
