How Does Temperature Affect the Depth of Mercury in a Glass Tube?
The discussion focuses on calculating the change in the depth of mercury in a glass tube when the temperature increases from 12°C to 100°C. The linear expansion coefficients for glass (10 x 10-6 K-1) and mercury (0.61 x 10-4 K-1) are utilized to derive the volume expansion coefficients. The volume of mercury at the initial temperature is calculated as 1.287 x 10-4 m3, leading to a final volume of 1.30772 x 10-4 m3 after heating. The discussion highlights the importance of considering both the thermal expansion of mercury and the glass tube.
  • Understanding of linear expansion coefficients
  • Familiarity with volume expansion calculations
  • Basic knowledge of geometry related to cylinders
  • Proficiency in algebra for manipulating equations
  • Study the concept of volume expansion coefficients in detail
  • Learn how to calculate thermal expansion in different materials
  • Explore the effects of temperature on liquid behavior in confined spaces
  • Investigate the relationship between temperature and pressure in fluids
Students in physics or engineering, particularly those studying thermodynamics and fluid mechanics, will benefit from this discussion.
gomdul2
A glass tube of radius 0.80cm contains liquid mercury to a depth of 64.0cm at 12deg. Find the depth of the mercury column at 100 deg.
Assume that the linear expansion coefficient of the glass is 10 X 10^-6 K-1 and the linear expansion coefficient of mercury is 0.61 X 10^-4 K-1.
volume expansion coefficient = 3 X linear expansion coefficient.
delta V = V- Vo = (vol.exp.coefficient)(Vo)(delta T)
Ok, So I multiplied the linear expansion coefficient of mercury and glass by three to calculate volume expansion coefficient.
Since the glass tube has radius of 0.80cm = 0.008m
Therefore, volume of mercury = (pi)(r^2)(h)
= (pi)(0.008^2)(0.64) = 0.000128679 = 1.287X10^-4m^3.
I don't know if I am on the right track,
what about the volume of the glass tube?
Thanks
Welcome to Physics Forums. It looks like you are on the right track.
A couple of questions to help you think about what to do next:
1. What is the change in the volume of the mercury, after it is heated to 100 deg?
2. What happens to the cross-sectional area?
Thanks Redbelly 98 :)
change in the volume of mercury =
delta V = V-Vo = (vol.coeficient)(Vo)(delta T)
= V - (1.287 X 10^-4) = (1.83 X 10^-4)(1.287X10^-4)(100-12deg)
2.072 X 10^-6 = V - (1.287 X 10^-4)
Therefore, V = 1.30772 X 10^-4 m^3.
Since V = (pi)(r^2)(h)
and r is fixed (r is still going to be 0.008m.)
But what about the change in volume of the glass tube?
I am confused @_@
The radius of the glass tube is not fixed. It changes due to thermal expansion.
21K
