What happens to the angle of a circular ring as temperature increases?
As temperature increases, the angle of a circular ring remains constant due to isotropic thermal expansion. The discussion confirms that when an object expands evenly, all linear dimensions increase by the same percentage, maintaining the ratio of the length of the circular gap to the radius. Therefore, the correct conclusion is that the angle does not change, supporting option 3 as the accurate answer.
  • Understanding of thermal expansion principles
  • Familiarity with circular geometry
  • Knowledge of isotropic expansion
  • Basic grasp of angular measurements
  • Research thermal expansion coefficients for different materials
  • Explore the concept of isotropic vs. anisotropic expansion
  • Study the effects of temperature on geometric shapes
  • Learn about applications of thermal expansion in engineering
Students studying physics, engineers dealing with thermal properties of materials, and anyone interested in the effects of temperature on geometric shapes.
Jahnavi
A part of a circular ring is missing .What happens to the angle when temperature is increased ?
1) θ increases
2) θ decreases
3) θ remains same
4) θ increases initially but becomes constant after a particular temperature .
As temperature increases , the length of circular gap on the ring will increase , but I am not sure what will happen to the angle .
Could someone help me .
If an object expands evenly due to evenly distributed heated, will its shape change?
If a body experiences unconstrained thermal expansion, the expansion takes place isotropically, and all linear dimensions of the body expand by the same percentage.
In that case , ratio of length of the circular gap to radius remains same as before .
Option 3) would be correct . Right ?
Yes
Thanks !
  • · Replies 19 ·
