Troubleshooting Mass Flow Rates for CH4 Reaction with Air and Fuel
  • Thread starter Thread starter Jacob87411
    Desperate Thermo
The discussion revolves around calculating the number of moles of products from a CH4 reaction with air and fuel, given specific mass flow rates. The user has established that the mass flow rate of air is 25 kg/s and fuel is 0.87 kg/s, and seeks assistance in converting these rates into moles of products like CO2 and H2O. The conversion process involves determining the mass fractions of each component in the exhaust and applying molar masses to find moles per second. The user confirms their calculations for CO2, finding that 2 kg/s corresponds to approximately 45 moles/s. The overall approach and calculations are validated, emphasizing the importance of checking each mass flow result.
Jacob87411
I have this reaction:
CH4+4(O2+3.76) --> CO2+2H2O+2O2+15.04N2
Through other calculations and given information I have found that the mass flow rate of the air (the O2+3.76N2) is 25kg/s and the mass flow rate of the fuel is .87 kg/s. I am having the hardest time finding, using these mass flow rates, the number of moles of each product I have. Any help is appreciated
Mass flow rates are given in kg/second, and the similarly you would get moles/second when converted into moles.
How would you normally convert 1kg of O2 into moles of O2?
Hint: 1kg/sec x moles/kg = moles/sec
So if I have 25 kg/s of air and air is 21% O2 I have (.21*25kg/s) gives kg/s of O2. Then (.21*25 kg/s)/32 = N_O2? Similarly ((.79*25kg/s)(3.76N2))/28 gives N_N2
How would it work for CO2 for example? Do I find the amount of moles of C, then use the fact that 25% of the moles of oxygen are paired with the C?
Get the kilograms/sec of each molecule using the mass percentages. Then convert it into moles/sec using that substance's molar mass.
For example the molecule CO2 has a molar mass of (C)12.01+(O)16.00+(O)16.00=44.01 grams per mole.
Ok this is what I got (I really appreciate the help by the way):
CO2=44 g/mole
H2O=18 g/mole
O2=32 g/mole
N2=28 g/mole
Total mass of exhaust=565/12
massfractionCO2=.077
massfractionH2O=.064
massfractionO2=.113
massfractioN2=.745
Mass flow of exhaust=mass flow air + mass flow fuel = 25.87 so i take the mass fractions from above and multiply them by that and they give:
CO2=2.00kg/s
H2O=.1.65kg/s
O2=2.92kg/s
N2=19.27 kg/s
And I know for example 1 mole of CO2=44 grams so 2.00 kg/s = 45.45 moles of CO2/s? Is this all correct?
Just make sure you carefully check each of your mass flow results for each substance (as I haven't checked them). The concept is correct, and yes 2kg/s of CO2 is equivalent to approx 45 moles/s of CO2. =)
