Troubleshooting Mass Flow Rates for CH4 Reaction with Air and Fuel
  • Thread starter Thread starter Jacob87411
    Desperate Thermo
The discussion focuses on calculating the mass flow rates and corresponding moles of products from the combustion reaction of methane (CH4) with air. The mass flow rate of air is established at 25 kg/s, while the fuel (CH4) has a mass flow rate of 0.87 kg/s. The conversion of mass flow rates to moles is demonstrated using the molar masses of the products: CO2 (44 g/mol), H2O (18 g/mol), O2 (32 g/mol), and N2 (28 g/mol). The final calculations yield mass flow rates of 2.00 kg/s for CO2, 1.65 kg/s for H2O, 2.92 kg/s for O2, and 19.27 kg/s for N2, confirming that 2.00 kg/s of CO2 corresponds to approximately 45.45 moles/s.
  • Understanding of stoichiometry in chemical reactions
  • Knowledge of molar mass calculations
  • Familiarity with mass flow rate conversions
  • Basic principles of combustion chemistry
  • Research the concept of mass fraction in chemical reactions
  • Learn about the Ideal Gas Law and its applications in combustion
  • Explore advanced stoichiometric calculations for multi-component reactions
  • Investigate the impact of varying fuel-to-air ratios on combustion efficiency
Chemical engineers, combustion researchers, and students studying thermodynamics and reaction kinetics will benefit from this discussion.
Jacob87411
I have this reaction:
CH4+4(O2+3.76) --> CO2+2H2O+2O2+15.04N2
Through other calculations and given information I have found that the mass flow rate of the air (the O2+3.76N2) is 25kg/s and the mass flow rate of the fuel is .87 kg/s. I am having the hardest time finding, using these mass flow rates, the number of moles of each product I have. Any help is appreciated
Mass flow rates are given in kg/second, and the similarly you would get moles/second when converted into moles.
How would you normally convert 1kg of O2 into moles of O2?
Hint: 1kg/sec x moles/kg = moles/sec
So if I have 25 kg/s of air and air is 21% O2 I have (.21*25kg/s) gives kg/s of O2. Then (.21*25 kg/s)/32 = N_O2? Similarly ((.79*25kg/s)(3.76N2))/28 gives N_N2
How would it work for CO2 for example? Do I find the amount of moles of C, then use the fact that 25% of the moles of oxygen are paired with the C?
Get the kilograms/sec of each molecule using the mass percentages. Then convert it into moles/sec using that substance's molar mass.
For example the molecule CO2 has a molar mass of (C)12.01+(O)16.00+(O)16.00=44.01 grams per mole.
Ok this is what I got (I really appreciate the help by the way):
CO2=44 g/mole
H2O=18 g/mole
O2=32 g/mole
N2=28 g/mole
Total mass of exhaust=565/12
massfractionCO2=.077
massfractionH2O=.064
massfractionO2=.113
massfractioN2=.745
Mass flow of exhaust=mass flow air + mass flow fuel = 25.87 so i take the mass fractions from above and multiply them by that and they give:
CO2=2.00kg/s
H2O=.1.65kg/s
O2=2.92kg/s
N2=19.27 kg/s
And I know for example 1 mole of CO2=44 grams so 2.00 kg/s = 45.45 moles of CO2/s? Is this all correct?
Just make sure you carefully check each of your mass flow results for each substance (as I haven't checked them). The concept is correct, and yes 2kg/s of CO2 is equivalent to approx 45 moles/s of CO2. =)
