Thermodynamics adiabatic diffuser question
7 replies · 7K views
Superhawkkodaka
An adiabatic diffuser is employed to decrease the velocity of an airstream from 220 to 30 m/s. The air enters the diffuser at a rate of 8 kg/s with a temperature of 300c and a pressure of 100kpa. Determine the exit area of the diffuser if the exit pressure is 125kpa.
Answer is 0.37 m^2
Guys I am really lost with this one.. I used equations pv=mrt, m=p'v'a, v=v'a
Note (v' is velocity as in> m/s and p' is density) just to prevent confusion
What i only got are the initial values v1, a1, p'1..
I can't get a2(exit area) have any ideas guys?
What does adiabatic mean? How can you use this information to relate the inlet and outlet properties?
i for got to add the equation for conservation of energy on open system
q=∑(exi
adiabatic mean
adiabatic means heat transfer is zero (Q=0)
i forgot to add the equation for open systems
Q= ΔH + ΔPE + ΔKE + W --- in this equation Q, W, & PE is equal to zero..
and
ΔH = ΔU + Δ(PV)
this equations might be usable.. my question is how do i use these equations to determine exit area
You can find the outlet temp. via conservation of energy. Then you can find outlet density as you have temp. & pressure.
Then use the mass flow equation you gave in your first post to solve for area.
I must add that there are probably other, potentially simpler ways to solve the problem.
conservation of energy equation? i don't know how to get the final temperature.. can you be more specific with equation for conservation of energy?
i only know this equation for conservation of energy for open system : Q= ΔH + ΔPE + ΔKE + W
i can' simplify tthe equation that i gave to input the temperature in the equation
You have one unknown in that equation so you should be able to solve it.
If you have no idea how to proceed it's generally best to review your textbook and/or lecture notes. We can help with specific problems but a forum is a poor format to learn course material from.
