Thermodynamics: calculate thermodynamic derivative from data?
The discussion focuses on calculating the thermodynamic derivative -(dE/dV)T from NPT molecular dynamics simulation data. To compute internal energy (E), the kinetic and potential energy columns from the simulation output must be summed. The key to finding the derivative involves changing the volume while maintaining constant temperature and observing the energy change, which can be simulated rather than performed experimentally. The method discussed emphasizes the importance of accurately capturing energy fluctuations in relation to volume changes during the simulation.
  • Understanding of NPT molecular dynamics simulations
  • Familiarity with thermodynamic derivatives and partial derivatives
  • Knowledge of energy components: kinetic energy and potential energy
  • Basic principles of calorimetry for experimental validation
  • Research methods for calculating thermodynamic derivatives in molecular dynamics
  • Learn how to analyze NPT simulation output files effectively
  • Explore techniques for maintaining constant temperature during volume changes
  • Investigate the use of calorimetry in thermodynamic experiments
This discussion is beneficial for molecular dynamics researchers, thermodynamic analysts, and anyone involved in computational chemistry or physics looking to understand energy-volume relationships in simulations.
bumblebee77
I don't understand how to use output from an NPT molecular dynamics simulation to compute a thermodynamic derivative.
I need to compute this (where "d" is a partial derivative, "T" is a subscript that means, "at constant temperature," and "E" is internal energy):
-(dE/dV)T
I have a simulation output file that has these columns:
Time, temperature, kinetic energy, potential energy, total energy
I think I need to add the kinetic and potential energy columns to get the internal energy. But how do I compute the partial of E with respect to V at constant T? E.g., what is the reference point for calculating the delta? Is it E at one time step minus E at the previous time step?
I have another file that provides the volume at each time step. It fluctuates because this is an NPT simulation.
Any hints would be very helpful. Thank you.
Science news on Phys.org
It sounds like you are not clear on the meaning of ##-(\frac{dE}{dV})_T##. This is the rate of energy change per change of volume for the system kept at a constant temperature.
You need to experimentally, or via simulation, change the volume while maintaining or reversibly bringing the system back to the given temperature and see how the energy changed.
Experimentally (in principle) I would use a calorimeter to measure how much heat the system loses when the volume increased a small amount and then how much heat I needed to add (via electric heating element) to bring it back up to the original temperature. The difference is the ##\partial E## for the ##\partial V## at that temperature. In practice this is probably a horribly inaccurate way to do things but that's the kind of think you should be simulating where you can directly compute energy.
  • · Replies 16 ·
