Thermodynamics homework question, , por favor?
The discussion revolves around a thermodynamics problem involving a pressure cooker containing water, where the internal energy of the system increases, and energy is lost to the surroundings. Participants are exploring the relationship between internal energy, heat transfer, and work done in a constant volume scenario.
  • Participants discuss the application of the first law of thermodynamics, questioning how to account for energy transferred to the surroundings and the total energy input from the heating element.
There is ongoing exploration of the energy balance in the system, with some participants suggesting that the total energy input can be calculated by considering both the energy retained by the water and the energy lost to the air. Clarifications about the book's answer have been raised, and participants are working through the implications of their calculations.
Participants are working under the constraints of a homework problem, which may limit the information available and the assumptions that can be made about the system.
Shakoa
I'm stuck on this thermal dynamics problem. It states: "A 2.0 kg quantity of water is held at constant volume in a puressure cooker and is heated by a range elment. The system's interal energy increases by 8.0 x 10^3 J. However, the pressure cooker is not well insulated, and 2.0 x 10^3 J of energy is transferred to the surrounding air. How much energy is trasferred from te range elment to the pressure cooker as heat?"
It's an isovolumatic instance, I think, and I'm using ΔU = Q - W, where W = 0 because of the constant volume.
U is internal energy, Q is heat, W is work.
I got to this:
ΔU = 8.0 x 10^3 J
W = 0
Q = 8.0 x 10^3 J
However, I don't know where to go from here. The book says that the answer is 1.00 x 10^4. I can't get there. I tried being stupid and doing this: 8.0 x 10^3 - 2.0 x 10^3, but that obviously doesn't work.
I looked at other forums with this question, but Q'=Q makes no sense.
Hello Shakoa,
Welcome to Physics Forums!
Shakoa said:
The book says that the answer is 1.00 x 10^3.
Are you sure the book's answer is 1.00 x 103 J and not 1.00 x 104 J (i.e. 10.0 x 103 J)?
Oh, yea, it does. Sorry. Typing error. New keyboard.
I still can't get a "1" in general.
Okay, then. :smile:
The water/pressure cooker system increases its energy by 8.0 x 103 J. The air increases its energy by 2.0 x 103 J. What is the total increase in energy? Where is all this energy coming from?
:V The heat comes from the heating element? Do I add it? That seems like it would make sense.
Just map out where the heat (energy) comes from and where it goes.
A total of "x" amount of heat initially goes into the cooker/water sytem; however, the cooker/water system retains only 8.0 x 103 J, while the remaining 2.0 x 103 J is released into the air. So how much is x? :wink:
[Edit: If y apples are put into a basket, and 2 apples fall out of the basket, leaving 8 apples still in the basket at the end, how many apples y were originally put into the basket?]
*headdesk* >.< I feel stupid now, and I'll feel stupid if this is wrong... x = 10000/all the heat/1 x 10^4
That sounds right to me. :approve: The total heat is 10.0 x 103 J. That was the amount of heat transferred to the pressure cooker (and water system), before some of it was lost to the air. :wink:
Very thank you muy merci. :D Thank you bunches! <3
