Thermodynamics problem, Heat Engine with two heat sinks
4 replies · 7K views
TeddyLu
I'm having a hard time setting up an equation for a heat engine problem with one heat source and two heat sinks given only the temperature of the heat source and temperature of the two heat sinks as:
TH = 1000 K
TC1 = 200 K
TC2 = 300 K
It is given that the two heat rejected are of equal value.
determine the maximum thermal efficiency.
thermal efficiency (carnot) = 1 - TC/TH = 1 - QC/QH
Since there was two heat sinks with an equal value of heat rejected at each:
QC1 = QC2 = QC
therefore, QH = QC1 + QC2 will turn into
QH = 2QC
I took the entropy balance equation to solve for QC:
0 = QH/1000 - QC/200 - QC/300
but I don't have a constant on the other side to figure out for QC to plug back into find QH and then solve for thermal efficiency.
any help please?
Consider 2 systems First one with heat source at 1000 K and heat sink at 300 K. Find out the maximum thermal efficiency. For the second one, consider the source at 300 K and sink at 200 K. Calculate the maximum efficiency. Multiply the two to get the overall maximum efficiency.
I kept wondering why the equal rejected fact is mentioned. Couldn't figure it out. I'm not too sure this method is correct. Verify it from someone.
QH = 2QC
How did you get this? What happened to W?
You can use the 1st and 2nd laws to solve this problem. The answer is a function of all three temperatures, as you might guess.
I would start from 1st principles rather than attempt to squeeze the Carnot law into the problem. A Carnot cycle runs between 2 temperatures only, by definition.
@siddharth23
Thank you for your reply! I found out that rude man's suggestion below helped with finding the answer to my question.
@rude man
Thank you also for your reply. To answer your question, I used the entropy balance equation to comes to that conclusion. There was no W stated so I excluded it from the problem.
I followed your instructions and was able to formulate an equation to find out the maximum carnot efficiency. The use of all three temperatures and made sure to take half of the heat rejected (QC1 & QC2) and solved for QC/QH to plug back into my equation for the carnot efficiency.
Appreciate all the help for this problem!
TeddyLu said:
@siddharth23
@rude man
Good. So what was your answer?
