Thermodynamics: property tables HELP
To solve the thermodynamics problem involving 1 kg of R-134a in a piston cylinder, the initial conditions at -26.4°C indicate it is transitioning from a saturated vapor to a superheated vapor. The specific volume at this temperature is 0.14 m³/kg, which requires looking up the corresponding pressure in thermodynamic tables. The pressure remains constant throughout the heating process. At 100°C, the specific volume must be determined using the same pressure from the tables, which will provide the final volume of the gas. This approach ensures accurate calculations based on thermodynamic principles.
MEAHH
Thermodynamics: property tables HELP!
1 kg of R-134a fills a 0.14m^3 weighted piston cylinder device at a temperature of -26.4C. The container is now heated until the temp is 100C.
Determine the final volume.
So the boiling point is -26.1, so it is a saturated vapor to a superheated vapor?
the specific volume is .14m^3
Pressure is constant? Using a T-V graph?
I don't understand how to go about this problem any help would be great!
At -26.4 C, the initial specific volume is 0.14 m^3/kg. This point needs to be looked up in the thermodynamic tables for the initial pressure. Once the pressure is known, this is also the final pressure. Now, the tables need to be used again to find the specific volume at 100 C and the same pressure. This will be the new volume (since there is 1 kg).
  • · Replies 44 ·
  • · Replies 20 ·
