Thermodynamics Questions dealing with Entropy
2 replies · 8K views
ana111790
My teacher gave us a packet of questions, I am stuck on a few:
Part 1)
A hot brick is tossed into cold water, and this is an adiabatic enclosure. The volume of the brick and water will not change.
Define the system and surroundings.
Entropy Tot = Entropy of system + Entropy of surroundings
I am assuming the water is the surroundings, and the brick the system, or is it supposed to be a tricky question?
Part 2)
What will happen in terms of temperature changes, after the brick is tossed into the water? Is this answer based on the First Law of Thermodynamics? Explain why or why not.
First Law of Thermodynamics: dU=dQ-dW
I am pretty sure that the brick's temperature will go down, and the water's temperature will go up, but it sais that the process is adiabatic so no Heat is given of. I am not sure how to relate these two, maybe there will be no Temp. change?
Part 3)
What will be Utotal for the process described in part 2? Explain your reasoning.Is the answer based on an application of the 1st Law of thermodynamics? Explain why or why not.
U=W, because the process is adiabatic, not Q is given of. How do I relate it to 1st Law of Thermo then?
Thank you so much for any help!
Hi ana. Welcome to the board. :smile:
When they say "adiabatic" they don't mean there is no heat transfer between the water and brick, they mean there is no heat transfer between the water + brick and the surroundings. In other words, consider the water and brick being inside a perfectly insulated bath tub.
Does that help at all?
It does help indeed!
Thank you for the clarification! :smile:
