Thermodynamics - water vapour cycle
The discussion centers on calculating specific work done and heat transfer in a thermodynamic process involving water vapor in a piston-cylinder assembly. Initially, water vapor at 10 bar and 400 °C is cooled at constant volume to 150 °C before condensing isothermally to a saturated liquid. Participants analyze the specific internal energy changes and mass fractions of vapor and liquid, using steam tables to derive necessary properties. The first law of thermodynamics is applied to determine heat transfer and work done during the condensation phase, with emphasis on maintaining constant pressure during this process. The conversation highlights the importance of accurately interpreting steam tables and understanding phase changes in thermodynamic calculations.
michealyap
How to calculate the specific work done.
Water vapor initially at 10 bar and 400 °C is contained within a piston-cylinder assembly. The water is cooled at constant volume until its temperature is 150 °C. The water is then condensed isothermally to saturated liquid.
a) Sketch the process in a T,v – diagram and determine the properties first.
b) For the water as a system, evaluate the specific work done on the system, in kJ/kg.
c) Determine the specific heat removed during condensation.
first i got specific work done from steam table when the water vapor is 10 bar 400 c . the specific work done i got is 2937.6 kj/kg. After that i have no idea how to continue on it. Can anyone explain what is seeing the water as a system.
Relevant equations (yours are the problem statement !) ? Properties ? Sketch ?
five digits of what ? Is this H, perhaps ?
sorry. it is internal energy 2957.3 kj/kg. first law of thermodynamics = change of internal energy = Q+W. then i have no idea what is going on.
Can't find that either. What steam tables do you use ?
What is the saturation T at 10 Bar ?
saturation T at 10 bar is 400C .. i used moran, Shapiro.
My bad, I misread Cengel p 895, 2957.9 so the same. OK, that's ##u## at the start. Part a) asks for a sketch and the properties (most likely at all three states).
What's the situation after cooling down to 150 ##^\circ## at same volume ?
Strange. I find 179.91 ##^\circ##C there !
yeah.. the saturation T is 179.91C but the initially T is 400C so it is saturated vapour. and i got 2957.3
Your ##u## is correct, but it's really superheated water vapor as it says at the heading of the table A-4
yeah.. i thought the situation is like that. initially the
What's on the axes ? And: what makes you think that ? Or are you just guessing ?
For the record: point 1 could be correct.
Sorry, i think this is 1 should be correct. First the water is superheated then same volume to cool down. then same temperature.
Much better ! Now we have to underpin it to see if it's right.
For the record: point 1 could be correct, point 2 and 3 I'm not so convinced
What is the specific volume of superheated steam at 10 bars and 400 C? At 150 C, would that same specific volume lie between that of the saturated vapor and the saturated liquid?
Good point ! Welcome in this thread !
the specific volume is gradually decreased with the T decreased. mean that the graph for the 1st time is correct.
We have the given that the volume stays the same during cooling down in the first stage. So what does that mean for the situation (as I asked in #6) ? (note what Chet asks in #15 too)
At 10 bars and 400 C, the specific volume of the superheated steam is 0.3066 m^3/kg. At 150 C, the specific volume of the saturated vapor is 0.393 m^3/kg and the specific volume of the saturated liquid is 0.001091 m^3/kg. What does this mean to you?
the 1st stage, the specific volume is 0.3066m3/kg..since it is same volume and according to mass of conservation, so i think they will having the same speicific volume
So did you take this into account in determining the internal energy change in the constant-volume step?
yes.. as i sketched in the T-v diagram i sketched the line from point 1 to point 2 as a downward straight line.
Point 2 is placed incorrectly in the diagram. It should be in the two-phase region. This is why I was asking.
oh.. i understand it should be in the region of vapour-liquid region..
ya. i just drew a new diagram, I sketched from point 1 and through the line to point 2.
Much better. Now, what are the mass fractions of liquid and vapor at point 2? What is the specific internal energy at point 2?
it seems unable to get the mass fraction as the formula is x= mg/total weight of liquid and gas. i do not have either mass of liquid of vapor . nor x.
I am quite confused already. the specific volume when the water vapor is superheated, it is 0.3066 m^3/kg since constant volume cooldown, so at point 2 it also should be 0.3066m^3/kg however when i check the steamtable, the saturated vapor of 0.3066m^3/kg does not fall into the 150 degree celcius.
At point 2, you have a combination of liquid and water vapor, with a weighted average specific volume of 0.3066. Let V be the volume of the container, and let M be the total mass of water in the container. Then $$0.3066M=V$$Now, if x is the mass fraction of water vapor and (1-x) is the mass fraction of liquid water, then the volume of water vapor must be ##0.393Mx## and the volume of liquid water must be ##0.001091M(1-x)##. Therefore, the total volume is $$0.393Mx+0.001091(1-x)M=V=0.3066M$$So, $$0.393x+0.001091(1-x)=0.3066$$
Hi, may i know how do you get the volume of water vapor must be 0.393Mx and liquid water must be 0.001091m. is it because to find the speicifc volume at the degree of 150 celcius?
  • #31
by solving the equation 0.393 x + 0.001091 ( 1 − x ) = 0.3066. i got x is 0.779 which is mass fraction of vapor then i got 0.221 for saturated liquid so for specific internal energy, i used interpolation to get the internal energy of saturated vapour and liquid the 150 degree celcius. I got 631.40075 kj/kg for saturated liquid, then i got 2559.49kj/kg for saturated vapor. so by multiplying mass fraction of respected specific internal energy, 631.4075*= specific internal energy for saturated liquid in the system at point 2, then 2559.49kj/kg/for saturated vapor in the system at point 2.To get Ufg = 2558.49-631.4065=1928.081 kj/kg. =using the fomula Uavg= Uf+ X*Ufg = 631.4075 +0.78 *1928.089= 2135.310kj/kg. specific internal energy is 2135.310kj/kg at point 2.
  • #32
Your approach looks correct. But there was actually no need to do any interpolation. In your set of steam tables, there should not only be a table for saturated conditions at specified pressures, but also a table for saturated conditions at 10 degree increments of temperature. For 150 C, that table gives the following values:
Equilibrium pressure = 4.758 bars
Specific volume of liquid = 0.001091 m^3/kg
Specific volume of vapor = 0.393 M^3/kg
Internal energy of liquid = 631.7 kj/kg
Internal energy of vapor = 2559 kj/kg
Enthalpy of saturated liquid = 632.2 kj/kg
Enthalpy of saturated vapor = 2746 kj/kg
  • #33
hi, after that i do not know how to proceed. 1st law of thermodynamics change of internal energy = Q- W. for the process of 1 to 2, constant volume so work done on this is equal to zero. therefore internal energy of procee 1 - process 2 = 2597.3 kj/kg - 2135.310 kj/kg = 462kj/kg. heat transfer out of the system. then how to find the work done for the system?
  • #34
Didn't you just say that the work is zero?
  • #35
Hello, yea i thought the question is asking the whole system first is constant volume , then is condensed isothermally. so the specific workdone is on the process of condensation.
  • #36
OK. Let's talk about the process step between points 2 and 3. What can you tell me about that step (in terms of the first law)? What are the conditions at the end of that step?
  • #37
for process between point 2 and 3, 1st law of thermodynamics , the change of internal energy is equal to zero. so Q=W.
  • #38
This is definitely incorrect. You are condensing the vapor to a liquid at constant temperature and pressure. Did you think that the internal energy is a function only of temperature even if there is a phase change? Start with the equation $$\Delta U=Q-P\Delta V$$What does this give you for Q?
  • #39
Q=heat transfer out. how do we know that it is condensed at constant pressure. In the same time, how do we unable to find the internal energy at point 3, which only contain water.
  • #40
If it is condensed at constant temperature (problem statement), it must be at the equilibrium vapor pressure at that temperature. So the pressure is constant.
Regarding your question about the internal energy at point 3, you sure can find the internal energy at point 3 from the saturated steam table. You can also determine the enthalpy at points 2 and 3, which may be easier to work with.
Don't forget to use the saturated steam table at specified temperatures, not specified pressures, to avoid having to interpolate.
Likes BvU
  • #41
ok.. since at point 3 all the water vapor has condensed to become water. the specific internal energy is 631.68 kj/kg for saturated liquid. pressure is 4.758bar. what is the delta V at here? as the formula U2-U3 = Q -PdeltaV .
Specific internal energy = 2135.7 kj/kg at point 2
Specific internal energy = 631.68 kj/kg at point 3
  • #42
Well, you know that the specific volume at point 2 (averaged over the mass of vapor and liquid) is 0.3066 m^3/kg. And you know that, at point 3, it is all saturated liquid at 0.001091 m^3/kg.
A second way of doing all this is to recognize that, for every kg of water in the container, you have 0.779 kg of vapor at point 2. So, the heat removal to condense this is the heat of vaporization (listed in the table) times 0.779.
A third way of doing this is to get the enthalpy per kg of mixture at point 2. This is done the same way you got the internal energy at point 2. From this, you subtract the enthalpy of the saturated liquid at point 3 to get the heat required to be removed per kg.
See if you can show that all three of these methods give exactly the same results for the heat Q.
  • #43
it did not work so well for the method 1. change of U = Q - Pdelta V . so, 2135.7 kj/kg - 631.68/kj/kg = Q - 4.758 *10^5 * (0.3066-0.001091(m^3/kg)) , therefore .143.857kj/kg = Q , this the Q i obtained..
For second method how to get the heat of vaporiztion?
  • #44
To get the work, you need to subtract the initial volume from the final volume. And, to get the change in internal energy, you need to subtract the initial internal energy from the final internal energy. So, $$P\Delta V=4.758\times 10^5(0.001091-0.3066)=-145000\ J/kg=-145\ kJ/kg$$. And, $$\Delta U=631.68-2135.7=-1504\ kJ/kg=Q-(-145)=Q+145$$ and so $$Q=-1649\ kJ/kg$$
For the 2nd method, to get the heat of vaporization, you subtract the specific enthalpy of the saturated liquid from the specific enthalpy of the saturated vapor (in the table).
  • #45
erm.. that is awesome. thank you.. really have a clearer picture.
Likes Chestermiller
