Thevenin equivalent with voltage source parallel to first resistor
  • Thread starter siylence
    Equivalent
2 replies · 4K views · last reply
siylence
This was a timed assignment that I never got an answer on, nor was I given the correct answer once the assignment was finished. I understood Thevenin/Norton (or so I thought) until I got a Volt source that was PARALLEL to the first resistor and everything fell apart.
The question is in the picture:
Circuit schematic with a 120 V voltage source in the left branch, a 52 Ω resistor in parallel with it, then 40 Ω and 10 Ω resistors in series on the middle branch, and a 4 Ω resistor leading to terminals a and b.
I am honestly stumped on this one. My textbook has no examples of a problem like this, nor did my professor give one like this in our notes. I feel like there was a curveball thrown.
I ended up getting something like 23.5 Ohms for Rth but that was from calculating the 10 Ohm and 4 Ohm resistors together as if they were in parallel. Then adding that to the 40 Ohm as if it were in series, then taking that resistance and adding it in parallel with the 52 Ohm resistor.
I'm an idiot.
The 52 ohm resistor isn't affecting the output because it is in parallel with the supply which is assumed to be perfect. So, you don't need to include it.
So, you find the Thevenin equivalent using just the 10 and 40 ohms then add the 4 ohms to the resistance Rth, because it is in series.
Sorry this took me so long to reply, but are the answers:
Vth = 120 V
Rth = 24 Ohms
In = 5 A?
