This allows you to compute the integral as a function of the difference ε.
  • Thread starter Thread starter Scholar1
    Integration
The discussion revolves around evaluating the improper integral ∫ from 2 to 6 of dx/(x-4), particularly focusing on the behavior of the integrand near the point x = 4, where a vertical asymptote exists. Participants explore the implications of this discontinuity on the integral's convergence.
  • Participants discuss the need to split the integral due to the discontinuity at x = 4 and question how to properly evaluate the limits approaching this point. There is also inquiry into the concept of the Cauchy Principal Value and its relevance to the problem.
The conversation includes attempts to clarify the nature of the integral and the conditions under which it can be evaluated. Some participants suggest that the original poster needs to understand the implications of the vertical asymptote and the definition of improper integrals. Guidance on evaluating the limits of the split integrals has been provided, but there is no explicit consensus on the final outcome.
Participants note that the integral does not exist in the traditional sense due to the discontinuity, but the Cauchy Principal Value may provide a different perspective. There is also mention of varying levels of familiarity with the concepts discussed, particularly among participants with different backgrounds in calculus.
Scholar1
None
u=x-4
du=dx
ln abs value x-4 abs value
ln2-ln2=0
What am I doing wrong?
How does the graph of 1/(x-4) look like ? What do you know when x = 4?
Vertical asymptote what does that have to do with this integration?
You integrate from 2 to 6. 4 is in this interval. Your function is not continuous in x = 4.
So what do I split into 2 integrals?
None
u=x-4
du=dx
ln2-ln2=0
You are dealing with an improper integral, so you need to define what it means. In your case, you need to evaluate
I(a,b) = \int_2^a \frac{dx}{x-4} + \int_b^6 \frac{dx}{x-4},
then see of the limit of ##I(a,b)## exists as ##a \uparrow 4## and ##b \downarrow 4##.
So since ln4-4=0 its divergent regardless of all the other stuff?
I cannot tell who you are responding to, but if it is to my post #6, then you need to check if the limit of ##I(a,b)## exists.
There is also the issue of whether or not you mean the Cauchy Principal Value integral, which can exist even if a more general type does not. The Cauchy principal value (if it exists) would be ##\lim_{\epsilon \downarrow 0} I(4-\epsilon, 4 + \epsilon)## in the notation of post #6.
I apologize I was replying to you. I am only Calc 2 so I don't know what the Cauchy Principal Value is. I am confused how to check if the limit exist. Please show me.
I have just explained what the Cauchy Principal value is, by giving an actual formula.
PF rules do not allow me to complete your problem for you.
He just said he doesn't know what it is, you really think he'd understand that equation? I'm in AP Calc BC which is the calc 2 equivalent and I have never seen anything similar to that equation. You should explain it to him from a calculus 2 standpoint.
For your purposes, the integral doesn't exist for the reason Math_QED gave back in post #4. You can't just mechanically follow a procedure and get an answer. You have to know the limitations.
Yes, I would hope that he would understand that equation after working at it for a while---not instantly, maybe, but after spending some time on it. Alternatively, he could Google 'Cauchy principal value' and find numerous web pages dealing with the topic, although skipping the Mathworld and Wikipedia pages on it is probably a good idea for a beginning student.
Anyway, I am assuming that 'Scholar1' (as a Calc 2 student) is capable of evaluating both of the very elementary integrals in the definition of ##I(a,b)##, and that he can then put ##a = 4 - \epsilon, b = 4 + \epsilon## to see what happens. Am I really expecting too much?
By the way: one reason that he/she might be unfamiliar with the Cauchy Principal value is that it is usually found only in some applications in Physics, Engineering and the like. Some writers regard it as a bit of meaningless nonsense in general.
I am actually in AP Calculus BC I just said calc 2 because people are more familiar with that. It wouldn't serve me well to spend time learning something so specific when I am preparing for an exam in a limited spectrum course.
Fair enough.
For the record: the integral (as a general improper integral) does not exist; however, the Cauchy value = 0.
Why are you worried about this integral man? I'm worried about sequences and series
I think the more conventional form of writing the Cauchy PV integral is:
$$I(a,b)=\lim_{ε \rightarrow0+} \left [ \int_2^{4-ε} \frac{dx}{x-4} + \int_{4+ε}^6 \frac{dx}{x-4} \right ]$$
  • · Replies 105 ·
11K
  • · Replies 16 ·
