A Three dimensional representation of ##U(1)\times SU(2)##
The discussion focuses on the three-dimensional representation of U(1) × SU(2) with zero hypercharge, specifically examining the mass term in the Lagrangian for a Dirac fermion triplet. The mass term is expressed as a combination of the fields L^+, L^0, and L^- and is compared to the standard model's mass term for a doublet. It is clarified that introducing this mass term is permissible since the representation is non-chiral, unlike in the Standard Model where chiral properties complicate mass generation. The participants debate the notation and the independence of the fields involved, questioning the equivalence of different mass term expressions. The model discussed adds a triplet to the electroweak sector, as detailed in a referenced paper.
Ramtin123
Consider a three dimensional representation of ##U(1)\times SU(2)## with zero hypercharge ##Y=0##:
$$ L= \begin{pmatrix} L^+ \\ L^0 \\ L^- \end{pmatrix} $$
Then the mass term is given by [1]:
$$ \mathcal{L} \supset -\frac m 2 \left( 2 L^+ L^- +L^0 L^0 \right) $$
I am wondering where the mass term is coming from.
I know that in the Standard Model the mass term for a doublet which is in two dimensional representation, is given by ## m \bar L L##.
Any ideas or comments appreciated.
Reference:
  1. Eqn (4) in arXiv:0710.1668v2 [hep-ph]
It is just a parameter of the Lagrangian. Since ##L## is a full non-chiral Dirac fermion, there is no problem in introducing that mass term, just as there is no problem in introducing a mass term in QED. The problem in introducing fermion masses in the SM is that the SM is chiral and left- and right-handed fields transform differently under SU(2). In turn, this means that the mass term needs to be generated through something like the Higgs mechanism, but this is not an issue here.
Thanks Orodruin . So, in this case mass term should read:
$$ -\frac m 2 \bar L L = -\frac m 2 \left( L^{+†} L^+ + L^{0†} L^0 + L^{-†} L^- \right)$$
So, why should this expression be the same as the expression above in eqn (4) of arXiv:0710.1668v2 [hep-ph] ?
Isn't this the same up to a constant?
##L^+##, ##L^0## and ##L^-## are independent fields. Let's call them ##\psi^+##, ##\phi^0## and ##\chi^-##.
So I am wondering why ##\psi^{+†}=\chi^-## or ##\chi^{-†}=\psi^+## ?
Then I didn't understand your notation. Which particular model are you discussing?
I am adding a triplet to electro-weak sector of the Standard Model. The triplet is in real non-chiral representation of ##SU(2)_L \times U(1)_Y##, and has vanishing hyper charge ##Y=0##.
The model is discussed in details in section 3.1 of this paper.
