enginebob
- Messages
- 10
- Reaction score
- 0
Hi i would like to post for discussion my design of a new type internal combustion engine Please post your comments.The following information is to explain the description and operation.
In drawing #1
The engine has three heavy pistons all attached together; two small and one large one in the middle. The large one is just for mass and as an air pump. The pistons are housed inside the three light weight aluminum cylinders. The pistons are free to move back and forth compressing and then firing on one end.As the piston on the other end opens a port, it allows the compressed air from the large center piston to purge and exhaust through an exhaust valve for that cylinder. The cycle repeats compressing and firing on each end as the opposite end exhausts. There would be check or reed valves in the large cylinder to take in air, and there would be a mechanical operated exhaust valve, and mechanical or electric injector in each cylinder head. There is no clearance between the piston and head so the piston can compress as much as it wants to until it stops, then it fires sending the pistons back.
In drawing#2
The pistons and cylinders are mounted in a light weight frame, on lineal bearings and allow for back and forth movement with two rack gears attached to the one end of the engine cylinder head. The lineal rack gears make contact with two sprag clutch gears (that means like a one way gear that drives going forward in turns freely in reverse). These gears
transfer the work force to an output shaft. The output shaft has a flywheel to maintain constant inertia of the heavy pistons and cylinders moving back and forth.
In drawing #3
This drawing is a end view of the engine attached to the rack gears, top and bottom, driving the two sprag clutch gears that are connected to the output shaft and flywheel turning in one direction. The top rack gear on the right drives one sprag gear and output shaft and the bottom rack gear drives the other sprag gear and output shaft in the same direction. The output shaft is mounted stationary as the engine and rack gear goes back and forth driving the shaft
producing a work force.
I will attach drawing as a post as they will not all fit.
Thanks Bob
In drawing #1
In drawing#2
In drawing #3
Thanks Bob
