Throttling process (Joule Thomson coefficient)
The discussion centers on the throttling process and its representation through isenthalpic curves, specifically focusing on the Joule-Thomson coefficient. It is established that the sudden temperature change at the inversion point in the isenthalpic graph is attributed to the deviation of real gases from ideal gas behavior. For ideal gases, the isenthalpic lines are horizontal, indicating constant enthalpy, whereas real gases exhibit non-horizontal lines even at low pressures. The conversation also clarifies that a zero pressure value on the ordinate axis does not imply absolute zero pressure but rather a state of low pressure where ideal gas behavior is nearly observed.
  • Understanding of the Joule-Thomson effect
  • Familiarity with isenthalpic processes
  • Knowledge of ideal vs. real gas behavior
  • Basic thermodynamic principles
  • Research the Joule-Thomson coefficient and its implications in real gas behavior
  • Study isenthalpic processes in thermodynamics
  • Examine the differences between ideal and real gases in various conditions
  • Explore graphical representations of thermodynamic processes
Students and professionals in thermodynamics, chemical engineering, and anyone involved in the study of gas behavior under varying pressure and temperature conditions.
theo dsouza
This is a graph obtained during throttling process by keeping pressure and temperature at the inlet of the valve fixed and varying them at the outlet to get different isenthalpic curves for different inlet pressures and temperatures.
Is it true that the sudden change in temperature of this isenthalpic graph at the inversion point is due to the deviated nature of a real gas from the ideal gas? Will the graph for an ideal gas be lines parallel to the abscissa?
Science news on Phys.org
I don't see any sudden changes at the inversion point.
Yes. The lines of constant enthalpy for an ideal gas undergoing a throttling process are horizontal on the graph. Note that, even in the low pressure region (where we usually expect ideal gas behavior), the isenthalpic lines are not horizontal. This is because the Joule Thompson coefficient is the result of deviation from ideal gas behavior.
Chet
In some graphs of the Isenthalpic curves (not the one above) I've seen that the isenthalpic curves touch the ordinate axis to give a positive temperature value and a zero pressure value on the exit side of the throttle valve. Is this possible?
The zero pressure value doesn't really mean zero pressure; it just means "at low pressures," where deviations from ideal gas behavior are negligible. Obviously, if you go all the way to zero pressure, the gas is not longer present, and its temperature is meaningless.
Chet
13K
