Calculate Speed over Time: Net Thrust of 5.25 m/s & 124 Secs
  • Context: High School
  • Thread starter Thread starter NickPerry
    Thrust Time
The discussion focuses on calculating the speed of an object given its net thrust and time duration. Specifically, the example of a shuttle rocket with a net thrust of 5.25 m/s² over 124 seconds is analyzed. The correct calculation involves recognizing that the thrust represents acceleration, not constant speed, leading to the formula: final speed = acceleration × time. The final speed for the shuttle rocket is confirmed to be 1380 m/s, illustrating the importance of understanding the distinction between thrust and acceleration.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of kinematics and acceleration
  • Familiarity with units of measurement in physics (m/s, m/s²)
  • Ability to perform basic algebraic calculations
  • Study the principles of Newton's laws of motion
  • Learn about kinematic equations for uniformly accelerated motion
  • Explore the concept of thrust and its relation to acceleration
  • Investigate real-world applications of rocket propulsion and acceleration
Physics students, aerospace engineers, and anyone interested in understanding the dynamics of motion and acceleration in rocket science.
NickPerry
This should be a painfully simple question, and yet, I can't find the answer.
once you have calculated the net acceleration force of an object, how do you figure out how fast it will be going over X seconds?
example (taken from here: http://sciencelearn.org.nz/Contexts/Rockets/Looking-Closer/Calculating-rocket-acceleration)
the shuttle rocket has a NET thrust of 5.25 m/s and that thrust is constant for 124 seconds. how do you calculate the speed? (they get 1380 m/s)
I thought it was 5.25 x (124 ^ 2) = m / s ^ 2 but that answer is way off.
then i thought, maybe it's linear? 5.25 x 124 ? but that answer wasn't correct either..
I looked at other pages giving examples, but they all seem to skip the part where they convert the m/s to the final time frame.
help?
The article says 5.25 m/s2 That's not thrust. That's acceleration.
The article also says: "As the shuttle uses its propellant, it also becomes much lighter, which increases acceleration"
So the article is clear that the 5.25 is NOT constant for 124 seconds.
Whoops. I must have glanced over that. how about this (where I originally got stuck on)
the acceleration of a flashlight in space:
https://www.reddit.com/r/askscience/comments/dofov/does_a_flashlight_produce_thrust/
1Kg
3watt
10 ^ -8 Newton's of force. for 20 hours (27000 seconds)
how did he get 2.5 meters every hour after 20 hours of acceleration?
EDIT:
of course, now I figure it out:
( 3 x 10^ (-8) ) x 27000 = 0.00081 m/s x 60 = 0.0486 m/M x 60 = 2.916 meters per hour. doh >.<
(I originally forgot that they had their final answer as m/hr not m/sec)
Thank you for putting up with me!
  • · Replies 17 ·
  • · Replies 95 ·
  • · Replies 69 ·
16K
