Time constant of an inductor coil
The discussion centers on the time constant of an inductor coil when shorted in a circuit. The time constant, denoted as t_c, is defined as t_c = L/R, where L is the inductance and R is the resistance. When the inductor is shorted, the potential difference across the coil becomes zero, as the entire induced EMF drops across the internal resistance of the coil. The current through the battery remains constant, while the current through the inductor decays exponentially over time.
  • Understanding of inductance and resistance in electrical circuits
  • Familiarity with the differential equation L (dI/dt) + IR = 0
  • Knowledge of the exponential decay function I(t) = I_o e^{-R t/L}
  • Basic concepts of DC circuits and short-circuiting components
  • Study the behavior of inductors in RL circuits under various conditions
  • Learn about the implications of short-circuiting inductors in practical applications
  • Explore the concept of back EMF and its effects on circuit components
  • Investigate the role of internal resistance in inductors and its impact on circuit performance
Electrical engineering students, circuit designers, and anyone interested in understanding the dynamics of inductors in electrical circuits.
Jahnavi
I think I can solve this problem . But I am bit unsure about how current changes in the circuit and the coil when it is shorted .
Before the coil is shorted , there will be no induced EMF across the terminals of the coil .
When the coil is shorted , is the potential difference across the coil zero (because of the wire placed across it or is it equal to the induced EMF(because of the change in current ) ?
For this one, you don't need to know any electrical circuit theory. All you need is the definition of time constant ## t_c ##: For a function ## I(t) ## that obeys ## I(t)=I_o e^{-t/t_c} ##, it is said to have time constant ## t_c ##.
But I am interested in the circuit theory :smile:
Could you clear my doubts .
With no voltage source in the circuit, it obeys ## L \frac{dI}{dt}+IR=0 ## where there must necessarily be some small resistance ##R ##. This differential equation has a solution of the form ## I(t)=I_o e^{-R t/L } ## so that ## t_c=\frac{L}{R} ##.
When the inductor is shorted , what happens to the battery ? I think it remains connected .
In a very simple circuit, you have a DC voltage ## V_o ##, a resistor ## R_1 ## and an inductor in series. The current in the inductor will be ## I_o=\frac{V_o}{R_1} ##. You then short circuit the inductor, so that the only resistance in the inductor part of the circuit will be a very small resistance ## R ## which is mostly from the wires making up the inductor. The battery and resistor ## R_1 ## still have current ## I_o=\frac{V_o}{R_1} ## and the current for this part of the circuit will also be in the short-circuit wire. (If I could draw a picture, it would be easier).
This is the picture I have in my mind .
Assume R to be the internal resistance of the coil . Initially S1 is closed and a constant current E/R is flowing through the coil .
Then coil is short circuited by closing switch S2 while keeping S1 closed . Are you interpreting it similarly or are you opening S1 while closing S2 ?
I suppose the two interpretations of shorting the coil are different .
I have another (larger) resistor ## R_1 ## right next to the battery. That way when ## S_2 ## is closed , there is no need to open ## S_1 ## at the same time. And to be more exact ## I_o=\frac{V_o}{R_1+R } ##.## \\ ## And what happens with the inductor is it acquires an EMF ## \mathcal{E}=L \frac{dI}{dt} ## that tries to maintain the current in the inductor and the EMF attempts to keep the current from changing.
OK . Thanks :smile:
After S2 is closed (keeping S1 closed) , what will be the current through the large resistor R1 (next to the battery) ?
The large resistor ## R_1 ## next to the battery will have current ## I=\frac{V_o}{R_1} ##. Actually, you could let ## R_1 ## and ## R ## be whatever resistor values you want, and the current in the inductor circuit, after it is short-circuited will have ## I(t)=I_o e^{-R t/L} ## where ## I_o=\frac{V_o}{R_1+R} ##.
OK .
So the current through R1 remains constant even after the coil is shorted (after closing S2) ?
And the current through S2( middle branch) will be the sum of the currents through R1 and Coil/R . Right ?
Does that mean the current through the coil decays through the middle wire without affecting the branch containing the battery and R1 ?
Does that also mean that the induced EMF in the coil does not disturb the current through the battery and R1 ?
See also a couple items I added to the previous post. ## \\ ## There will be a change in the current through the battery because initially ## I_b=\frac{V_o}{R_1+R} ## and after switch ## S_2 ## is closed, ## I_b=\frac{V_o}{R_1} ##. ## \\ ## And ## S_2 ## is assumed to be a short-circuit, so once ## S_2 ## is closed, the battery can not tell what the inductor is doing, i.e. it will not be affected by any EMF's that the inductor generates.
OK .
After S2 is closed current through S2( middle branch) will be the sum of the currents through R1(constant value) and Coil/R(varying) . Right ?
The current flowing through S2 will be varying ?
Does that mean the current through the coil decays through the middle wire while the current through the battery remains constant with a value Vo/R1 ?
The current from the inductor will always go from right to left through ## S_2 ## in the way you drew it, and that current, (which is time varying, ## I(t)=I_o e^{-Rt/L} ##, and eventually drops to zero) is superimposed on a left to right DC current of ## I=\frac{V_o}{R_1} ## from the battery portion of the circuit. Once the inductor current goes to near zero, the current in ## S_2 ## will be left to right and will be ## I=\frac{V_o}{R_1} ##. So that ## I(t)_{S_2}=\frac{V_o}{R_1}-\frac{V_o}{R_1+R} e^{-Rt/L} ## (with left to right as positive). ## \\ ## And yes, you are correct=the current in the battery stays constant once the switch ## S_2 ## is closed. :)
Wow !
Back to the original question I asked in the OP .
I think potential difference across the terminals of the coil will be 0 .The entire induced EMF will drop across the internal resistance of the coil .
Correct ?
Jahnavi said:
Wow !
Correct ?
If you add a resistor ## R ## in the circuit, then you find there is a voltage generated by the inductor. Otherwise, (if ## R ## is simply inside the inductor), if you put a voltmeter across ## S_2 ##, (to measure the inductor voltage), you would measure zero, because the resistive voltage drop is internal to the inductor, just as you stated. Yes, you have that correct. :)
Why is it that books invariably open S1 just after S2 is closed ? Every book does that :rolleyes: .
Is it to protect the battery from getting damaged by a flow of large current?
And since you put a large resistor , this possibility was eliminated because the current was limited ?
Thank you so much Charles !
You are quite amazing :smile:
