Time dependent perturbation for harmonic oscillator
The discussion revolves around the time-dependent perturbation theory applied to a one-dimensional harmonic oscillator, specifically focusing on the potential energy and perturbation Hamiltonian. The original poster is tasked with demonstrating that states with quantum numbers greater than three do not get excited from the ground state under the influence of a specific perturbation.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to analyze the transition probabilities between states using the perturbation Hamiltonian and considers the implications of the matrix elements being zero for certain states. Other participants suggest expressing the position operator in terms of raising and lowering operators to facilitate the calculations.
Participants are actively engaging with the mathematical expressions and exploring the implications of their calculations. Some guidance has been provided regarding the algebraic manipulation of operators, and there is a recognition of the orthogonality of the eigenstates, which is central to the discussion.
There is an emphasis on ensuring that the algebra is correctly handled, particularly with respect to the non-commuting nature of the raising and lowering operators. The original poster is navigating through the complexities of quantum mechanics and perturbation theory while adhering to homework constraints.
Vandmelon
I'm looking at the 1d harmonic oscillator
\begin{equation}
V(x)=\frac{1}{2}kx^2
\end{equation}
with eigenstates n and the time dependent perturbation
\begin{equation}
H'(t)=qx^3\frac{(\tau^2}{t^2+\tau^2}
\end{equation}
For t=-∞ the oscillator is in the groundstate n=0
I need to show that for n>3 the states will not get excited and I only need to look at the first order perturbation.
What I'm thinking is \begin{equation}P_{a→b}=\vert c_b(t)\vert^2 \end{equation} therefore I need to find when c_b=0
and because
\begin{equation}
c_b'=-\frac{i}{\hbar}∫H_{ba}'(t')e^{i\omega_0t'}dt'
\end{equation}
I need to find
\begin{equation}
H_{ba}'=<\psi_n\vert H' \vert \psi_a >=0
\end{equation}
For n>3
It would make sense if H_ba look a bit like this
\begin{equation}
H_{ba}'=\frac{d^n}{dx^n}H'
\end{equation}
But I get some horrible results if I try to solve H_ba. Is it right what I am doing or is it way off.
You want to compute [itex]\langle n| H' |0\rangle[/itex], which is proportional to [itex]\langle n| \hat{x}^3 |0\rangle[/itex]. If you express [itex]\hat{x}[/itex] in terms of raising and lowering operators [itex]\hat{a},\hat{a}^\dagger[/itex], you should be able to see how to reach the necessary result.
so if I use
\begin{equation}
\hat x=\sqrt{\frac{\hbar}{2m\omega}}(a_+ + a_-)
\end{equation}
then if I solved it right
\begin{equation}
\hat x^3 \psi_0=(\frac{\hbar}{2m\omega})^{\frac{3}{2}}[(a_+)^3+a_+ + a_- + (a_-)^3]\psi_0
\end{equation}
Is it correct if I use a_- on ψ_0 it will just be 0 so
\begin{equation}
\hat x^3 \psi_0=(\frac{\hbar}{2m\omega})^{\frac{3}{2}}[(a_+)^3\psi_0+a_+\psi_0]=(\frac{\hbar}{2m\omega})^{\frac{3}{2}}[\sqrt6 \psi_3+\psi_1]
\end{equation}
So it will end up like this
\begin{equation}
\langle \psi_n \vert\sqrt6 \psi_3+\psi_1 \rangle
\end{equation}
If this is correct I am not sure why the oscillator wouldn't get excited for n>3. Or is it my calculations there are wrong?
*EDIT
Oh is it because
\begin{equation}
\langle \psi_n \vert \psi_m \rangle = 0
\end{equation}
for n ≠ m
Vandmelon said:
so if I use
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
You'll want to go back through the algebra here. Remember that [itex]a_+,a_-[/itex] don't commute, so you have to keep track of the order of terms.
Oh is it because
\begin{equation}
\end{equation}
for n ≠ m
You will have to use both of these relations. You have all of the right ideas, just fix the algebra.
  • · Replies 16 ·
  • · Replies 0 ·
