Time dilatation between straight and curved lines in Minkowsi space
The problem involves two astronauts who synchronize their clocks and travel along different paths at varying velocities in the context of special relativity. One astronaut moves in a straight line at a constant speed, while the other travels along a semicircular path. Upon meeting, they observe a discrepancy in their clock readings, leading to questions about which clock is "left behind" and the value of the distance parameter involved.
  • Participants discuss the application of Lorentz transformations and question the necessity of these transformations given the problem's context. There are inquiries about the speeds of the astronauts and the implications of their paths on time dilation. Some participants suggest verifying the initial conditions and parameters provided in the problem.
The discussion is ongoing, with various participants offering insights into the calculations and interpretations of the astronauts' speeds and paths. There is a recognition of the need to clarify the roles of the astronauts and the implications of their respective velocities on time dilation. Some guidance has been provided regarding the calculation of proper times and the relationship between the paths taken.
There is ambiguity regarding the specific speeds of the astronauts, particularly the non-inertial astronaut, which has led to confusion. The problem also raises questions about the assumptions made regarding the nature of their paths and the implications for time measurement in Minkowski space.
thetafilippo
Moved from technical forums so no template
Summary:: Special relativity - 2 astronauts syncronize their clocks and moves in different paths at different velocities, which clocks is left behind? and why?
Hi everyone, i have the following problem and I'm not understanding if my strategy to solve it is correct:
Two astronauts synchronize their clocks starting at time zero from the origin O of an inertial reference frame S. They simultaneously reach point $$A:{ x_A=d, y_A=0}. $$
The first astronaut moved in a straight line at constant speed $$v=\frac{c \pi}{4}$$ while the second traveled at constant velocity (in absolute value) over a semicircle in the xy plane of diameter d. Upon their meeting, the astronauts notice a 1 year difference between their clocks. Which clock is left behind, and why?
Which value has d?
Now, I've write down the Lorentz transformations
$$x'=\gamma(ct-\beta x)$$
$$ct'=\gamma(x-\beta ct)$$
And then i substitute $$x'=d$$, $$\beta=\frac{\frac{\pi c}{4}}{c}$$, $$x=dcos\theta$$ and because of the first reference frame reach the point d and the second reach the point $$x=dcos\theta$$
$$d=\gamma(ct-\frac{\frac{\pi c}{4}}{c} d cos \theta)$$
$$0=\gamma(d cos \theta-\frac{\frac{\pi c}{4}}{c} ct)$$
And i get from the second $$d=\frac{\pi}{4}ct$$. It's correct? how i could properly say which clock is left befind? I think that the one that travels in a straight line needs more time to reach the same point,cause the straight line in the Minkowski space maximize the time. Anyone can help me?
In the inertial reference frame, who has the greater speed?
If you study the problem in that reference frame, why do you need a Lorentz Transformation?
Inertial clocks always have the longest possible lapse of time between two events. This is the Minkowski geometry equivalent to the Euclidean "shortest distance between two points is a straight line".
However, I make the speed of your non-inertial astronaut ##c\pi^2/8##, which is greater than ##c##. So you will get nonsensical answers in this case. Adjust your scenario and try again.
it is not specified, I think it is implicitly given by saying that it moves at constant speed along a semicircle of diameter d, therefore the centripetal acceleration $$ a_c = \frac {v ^ 2}{d/2} $$, could it be?
but in any case the centripetal acceleration is not given
Acceleration is not relevant. Only speed matters. However, note my previous answer.
The speed of non inertial astronaut is not given not ##c\pi^2/8##, please could explain what you mean? i didn't get your reply!
could someone explain to me what is the correct strategy to follow? I'm confused by this problem
thetafilippo said:
The speed of non inertial astronaut is ##\frac{c \pi}{4}## not ##c\pi^2/8##, please could explain what you mean? i didn't get your reply!
Your original post says that the inertial astronaut travels at ##c\pi/4##.
I take it that was a mistake.
In that case, both astronauts are moving at constant speed, so all you need to do is calculate their ##\gamma## factors, calculate the elapsed coordinate time, and then use time dilation.
Do both astronauts have the same speed?
The speed of inertial astronaut is
Ibix said:
Your original post says that the inertial astronaut travels at ##c\pi/4##.I take it that was a mistake.
The speed of non inertial astronaut is not given and the speed of inertial astronaut is ##c\pi/4##. How i could calculate the gamma factor of the non inertial one if the velocity is unknown?
No, no the speed of non inertial astronaut is unknown
How far does the non-inertial astronaut travel? How fast must he go if he is to meet the first astronaut at the other side of the semi-circle?
If the inertial astronaut is moving at ##c\pi/4## then the answer to my second question is ##c\pi^2/8##, which is faster than light. Where did you get this question from?
Do they arrive at the same time at A?
Yes, according to the OP.
First you calculate the speed of the non-inertial astronaut using the frame in which the starting point and the destination are at rest. You know the distance traveled, you know the time it took to cover that distance (because the astronauts arrive at the destination together), and that gives you the speed.
This problem is simple enough that no transform is needed. Just determine the time dilation for each path in the original frame.
You know the distance he travels (in the original frame) and the time it takes.
First you should double-check with the original problem description, if the given speed ##v=\frac{c \pi}{4}## really belongs to the first (inertial) or instead to the second (non-inertial) astronaut, with then the first astronaut's speed unknown (Reason). Then you should find out the ratio between the path lengths via the semi-circle and the straight line, to calculate the unknown speed from the known one.
Another hint: A clock by definition is a device which shows the proper time along its world line,
$$\tau=\frac{1}{c} \int_{\lambda_1}^{\lambda_2} \mathrm{d} \lambda \sqrt{\eta_{\mu \nu} \dot{x}^{\mu} \dot{c}^{\nu}}.$$
Here I use the west-coast convention with ##\eta_{\mu \nu}=\mathrm{diag}(1,-1,-1,-1)##. So just parametrize the world lines of the two astronauts and calculate their proper times when meeting again.
I checked and the velocity of the first astronaut is ##v=\frac{c \pi}{4}##.
If i want to solve the problem i should evaluate the 2 gamma factors, then the 2 proper times and set the difference equal to 1 year, but how is possible that the velocity of the non inertial astronaut is greater than c? where is the mistake? this problem comes from an exam sheet of my professor, so the problem description is not wrong!
Professors make mistakes too (there were typos in one of my final exams - corrections were written on a blackboard in the exam room). The question cannot be solved as written.
To my mind, the most likely explanation is that the non-inertial astronaut is supposed to be doing ##c\pi/4##, since then the inertial astronaut is doing ##c/2##. Then the question can be solved as you proposed.
  • · Replies 48 ·
