- 3,777
- 2,000
You can choose to work from whatever frame you find most convenient. It's jut important to realize that this choice of frame is not any more valid in terms of what "really" happens than any other.PainterGuy said:Thank you very much!
Now please bear with me.
Yes, I personally prefer Earth's frame of reference because it seems more natural and as a novice it seems to help understand it better.
In a Newtonian universe, it would take 3.3 yrs to reach the destination according to both Earth and ship. In our Relativistic universe is takes 2.52 yrs by ship time, and 6.7 yrs Earth time. So the 3.3 yrs under Newton is different than both the Earth time and Ship time under Einstein.Yes, I did watch a video about "Einstein train simultaneity". This one: youtube.com/watch?v=wteiuxyqtoM
I'm sorry but I'm confused and my head hurts. "2.52 yrs ship time" is dilated according to the reference frame of earth. Therefore, I think, "3.3 yrs" won't be different from "2.52 yrs ship time" once the pilot completes his mission and his mission's duration is checked using Earth's clock; or in other words once the ship time is converted into Earth time using proper factor, it would be same as 3.3 yrs.
As far as the pilot is concerned, there is no relativistic mass increase to take into account. What he does know is that as he feeds X amount of fuel per second(by his clock) into his engines, it produces a proper acceleration of 10m/sec. Thus if he stood on a scale, it would register just a tad bit more than it would on Earth. This is the same for the pilot in a Newtonian universe or Relativistic one. And the amount of fuel per second they are feeding into the engine to produce that acceleration will be the same in each case. The difference is that one pilot feeds fuel into the engine for only 2.52 yrs(Relativistic Universe) and the other for 3.3 yrs (Newtonian universe) Now according to the Newtonian pilot he would be moving at ~3.5c relative to the Earth after that time, and the Relativistic pilot would be moving at 0.99c relative to the Earth. The Newtonian pilot would also say that he was 5.8 ly from Earth, and the Relativistic pilot would measure that same distance as being just under 0.82 ly."under Newtonian rules, you would have to accelerate for 3.3 yrs. You will have burned 30% more fuel and taken 30% longer (compared to ship time)" - In other words, yes, it would take a Newtonian longer because your clock was running slow. But I don't see how a Newtonian would need to spend more fuel, especially when Newtonian rocket doesn't 'suffer' from any relativistic mass effect, informally speaking, its mass doesn't increase.
Once again, I don't understand why it'd take "30% more fuel" according to Newtonian calculation; in post #53, https://www.physicsforums.com/threa...mass-and-fuel-consumption.984366/post-6299827, @Nugatory confirmed that a Newtonian would say that more fuel has been consumed because Newtonian antiquated model doesn't take into account relativistic effects of mass as it moves.
Why would you wnat to look at it from a perspective that has turned out to be incorrect? Time doesn't have a "fixed flow". Trying to "shoe horn" Relativity into a Newtonian viewpoint isn't going to lead to any understanding of the theory.I understand that the special relativity models the nature more accurately but I'm looking at it from perspective of Newtonian antiquated model. I'm also not focusing on spacetime because even Einstein himself didn't really consider it when he came up with the special theory of relativity. I'm ignoring the general relativity at this stage. Newtonian model uses fixed flow of time and no distinction between rest mass and moving mass.
At constant speed, and after you factor out the propagation time delays (Doppler effect), The rocket sees Planet B's clock as running slow, and Planet B sees The rocket clock as running slow.I googled the effects of acceleration on time and found few things which I didn't know before. I had thought that only when you move fast with respect to an inertial frame, your time gets slow down, i.e. dilated. It looks like acceleration also affects the time in a different manner; I hope it's not a consequence of general relativity because I'm only focusing on special relativity. The theory of general relativity models the acceleration as gravity .
For example, have a look below on the quote. My apologies if it's not entirely accurately but I needed your guidance if it's correct. For example, if a rocket is moving away from Earth to some other planet B. The rocket clock appears to slow down with respect to an Earth observer but a rocket observer notices Earth's clock slowing down. If the rocket is headed directly toward planet B, how would the rocket observer see planet B's clock and how rocket clock appears to planet B observer? I'm assuming rocket is traveling at constant velocity.
This excerpt would apply to a ship is activelyaccelerating towards planet B, and not when it is moving at a constant speed. In other words, If you start accelerating towards Planet B, while you are accelerating, the clock at planet B will run fast according to you. Once you stop accelerating and begin coasting at a constant speed The clock at B will run slow according to you.According to what is said below, as the rocket accelerates the rocket observer sees Earth clock slowing down more but sees planet B clock moving faster. Is it correct?
"Moving fast only. Actually, just moving at all, though you won't notice it much at low speeds.
Acceleration causes another time effect, which seems different but drops out of the same math. Clocks "above" you, or in the forward direction of acceleration, tick faster. Clocks "below" you tick slower. This happens even when you're rigidly attached to the clock, and both you and the clock are accelerated."
Source: https://qr.ae/T3zzwJ
One thing that this excerpt doesn't mention, is that the rate at which the clocks "above" you run fast and the ones below one run slow depends both on the magnitude of the acceleration and and how far "above" or "below" you they are. The more the separation in either direction, the greater the difference in tick rate.
Thus the further way planet B is when you start accelerating towards it, the faster it clocks tick compared to your own.
One thing to keep in mind is that time dilation due to acceleration is only measured by the accelerating observer. Anyone in an inertial frame would just measure an accelerating clock as ticking at a rate that depends only on its relative velocity.
A "Newtonian" (someone living in a Newtonian universe) would measure none of this, As time dilation and length contraction are not a part of Newtonian Physics.Well, if you think I'm making no sense then I'd understand if you don't comment.This is an addition to what I said earlier towards the end of my last post.
"In 1908, three years after Einstein first published his special theory of relativity, the mathematician Hermann Minkowski introduced his four-dimensional “spacetime” interpretation of the theory. Einstein initially dismissed Minkowski’s theory, remarking that “since the mathematicians have invaded the theory of relativity I do not understand it myself anymore.” Yet Minkowski’s theory soon found wide acceptance among physicists, including eventually Einstein himself, whose conversion to Minkowski’s way of thinking was engendered by the realization that he could profitably employ it for the formulation of his new theory of gravity. The validity of Minkowski’s mathematical “merging” of space and time has rarely been questioned by either physicists or philosophers since Einstein incorporated it into his theory of gravity. Physicists often employ Minkowski spacetime with little regard to the whether it provides a true account of the physical world as opposed to a useful mathematical tool in the theory of relativity. Philosophers sometimes treat the philosophy of space and time as if it were a mere appendix to Minkowski’s theory. In this critical study, Joseph Cosgrove subjects the concept of spacetime to a comprehensive examination and concludes that Einstein’s initial assessment of Minkowksi was essentially correct."
Source: https://www.palgrave.com/gp/book/9783319726304#aboutBookThe following part is my personal view and I also attempt to explain why I'm finding the special theory of relativity difficult.
As another example, let's consider a thought experiment. If you are asked to go around the Earth at 0.9c speed for one second using fixed amount of fuel. Let's ignore the air friction, gravity, and suppose the rocket starts and end its journey at 0.9c without any acceleration, also ignore centripetal acceleration. The speed of light is 300000 km/s and circumference of Earth is 40075 km. Using Newtonian calculation, in one second you should be able to go around the Earth 6.74 times. A Newtonian standing on Earth would see the rocket going slow, length contracted in the direction of travel but I don't think the Newtonian would be able to notice that the rocket has become more massive.
Since you are ignoring air friction, gravity and the centripetal acceleration, the the "fixed amount of fuel" you would need to maintain that 0.9c is zero, so I don't even see the point of mentioning fuel, unless it is the fuel needed to reach 0.9 c in the first place.
If the rocket is traveling at 0.9c, then it makes 6.74 trips around the Earth in one second Earth time, reagardless of whether you take the Newtonian or Relativistic view.Therefore, after one second the Newtonian would clearly see that the rocket hasn't circled the Earth 6.74 times.
No, you are not making any sense. Either the ship is moving at 0.9c relative to the Earth, in which case it would take more fuel to reach that speed according to Relativity than Newton, Or the ship has a fixed fuel supply, in which case it would not quite as high a speed under Relativity than it does according to Newton. You seem to want to "double up" on the effects.If the rocket is taken down once Newtonian clock ticks one second, it would also be noticed that for whatever amount of journey it has covered (which is clearly going to be less than 6.74 times Earth circumference), it has consumed more fuel as it should. Forget what the pilot of rocket has to say about it. Do I make any sense?
Putting light sensors at the ends of the Train would make no difference. You could place observers all along the length of the train, and they they would all conclude the the flashes occurred at different times.Also, for example, in the example shown in the video mentioned above about simultanety, youtube.com/watch?v=wteiuxyqtoM , if there were two light sensors at the ends of train, the person on train would also agree that both flashes occurred at the same time. Yes, if the train is some kind of planet and there was no way of communicating with a person situated outside somewhere above that planet, then the conclusion of person riding the 'train/planet' would be acceptable. Perhaps, the example is a bad example but online tutorials are full of such examples.
Here are events according to the Embankment frame:
Ends of train reach red dots, flashes are emitted simultaneously. They reach the embankment observer simultaneously and the train observer at different times.
Same events according to Train frame.
But, again, If you really want to grasp Relativity, you have to accept, that according to the ladder, it is the barn that length contracts, and this is just an "physically real" as your view that the ladder contracts. While it is perfectly fine to work from the frame of the Barn, because that is the frame you are at rest to, it is important to keep in mind that there is nothing special about that choice that makes this view any better than any other.The first thing you might notice is that the train no longer fits exactly between the red dots. In the first animation, it is the train moving relative to the frame, so it is length contracted, and it is the length contracted train that fits in between the dots. In the train's frame, the train is its proper length and it is the embankment that is length contracted. The train ends cannot be at the red dots at the same time. The right end of the train reaches the right dot before the left end of the train reach the left dot. Thus the events that initiate the flashes cannot occur at the same time. However, you will still note that in this frame the flashes still reach the embankment observer simultaneously. You can also see that in both animations, the right flash hits the train observer when he is about 3 ties past the embankment observer, and the left flash reaches him when he is about even with the right dot.
The second animation are the sequence of events, according to anyone at rest with respect to the train frame. It doesn't matter where you are are on the train or where or how many sensors you have.
In my humble view, the theory of special relativity, is presented more like pure math rather than applied math. Personally, I have nothing against pure math but applied math seems more interesting although the very foundation of applied math is in fact the pure math. I have been looking for a book which presents theories of relativity, especially special relativity, more from 'human' and 'physical' perspective but no success. I will elaborate on it below.
A cathode ray tube takes into account of relativistic effects on length and mass of electrons. An electron has length contraction, time dilation, and its inertial mass increases. I wouldn't really care how I appear to the electron - if it sees me length contracted unicorn or alien then that's not my problem :). Most important to me, as a novice, is to understand how an electron looks as it travels at very high speed. I can imagine later, how the world appears to an electron if it were a living being!
"Cathode ray tube (CRT) televisions create pictures by shooting electrons at a phosphorous screen. These electrons are accelerated to high velocities, near 20- 30% of the speed of light. Remember from special relativity that as a particle approaches speeds near light speed, the energy required to propel the particle is increased. Magnets in the television are responsible for placing the electrons in the correct configuration on the screen. They must account for the relativistic effects on these electrons or the picture created will be out of focus (Akpan, 2015)". Source: https://engagedscholarship.csuohio.edu/cgi/viewcontent.cgi?article=1071&context=tdr "These electrons are moving at roughly a third of the speed of light. This means that engineers had to account for length contraction when designing the magnets that directed the electrons to form an image on the screen. Without accounting for these effects, the electron beam's aim would be off and create unintelligible images." Source: https://www.iflscience.com/physics/4-examples-relativity-everyday-life/amp.html, https://www.quora.com/Is-length-con...chard-Muller-3?ch=12&share=c5c2c623&srid=gk8x . The same goes for the ladder paradox, https://en.wikipedia.org/wiki/Ladder_paradox, if I build a barn and let the ladder move through it at really fast speed, then it's the ladder which contracts in my physical world. The ladder is in my world or the world of barn and ultimately the ladder's movement is not permanent, it has to stop ultimately.
In the earlier example of how much fuel you burn while traveling to a distant star at constant acceleration, you could work it out from the Earth frame, but it is pretty involved, having to deal with a changing velocity with its resulting changing time dilation for the ship etc. It is easier to work out from the pilot frame. Both approaches give the same answer, so it makes sense to use the simpler one.
Also, when you ignore how events appear from other frame, you are ignoring a good part of the theory and what Relativity tells us about the very nature of time.
