Time Flowing with Falling Stick
jordanhuh
Mod note: deleted image that was way too large.[/color]
I want to know the time flowed while the stick falls.
gravity = g
density of the stick is same so it's center of mass is l/2.
what is the T?
failed to do torque.
You mean - "how long does it take for the stick to fall?"
Is the point of contact a fixed pivot?
... then learn.
The subject requires an actual physics lesson - there is no shortcut - lessons are expensive for a reason.
You need to draw the forces into the diagram.
At the center of mass, gravity creates a torque.
Torque is the perpendicular component of the force times the distance.
In your case, the torque will depend on the angle.
The equation to solve is ##\sum\tau = I\ddot\theta## ... so you need to know about angular momentum as well. For the stick, pivoted about one end, ##I=mL^2/3## - where L is the length of the stick.
