- 19,385
- 15,621
Thank you Peter. I KEEP getting that wrong.PeterDonis said:No, it isn't. It's tidal gravity. But tidal gravity is not what makes things fall into the floor locally on the surface of a planet (or in an accelerating rocket).
MikeGomez said:I don’t have a problem with the statement that gravity is spacetime curvature, because I don’t feel the need to qualify that with “tidal” gravity.
MikeGomez said:We had the discussion in earlier posts that no uniform gravitational field exists and I assumed that was true because nobody challenged it, and that indicates to me that all gravity is tidal.
MikeGomez said:If spacetime curvature is present globally then it seems to me it must exist locally.
MikeGomez said:some of which have an effect locally in a area where the separation is small enough that the EP holds.
MikeGomez said:spacetime curvature, at least of the form that is present around an ordinary spherical planet, disappears in this limit”
MikeGomez said:Could you please discuss a little about this non-tidal gravity which makes things fall to the floor locally.
Is this the vanishing of the Christoffel symbols (or making them small enough to be negligible)?PeterDonis said:The term "locally" is yet another term with multiple meanings. In one sense of the term, spacetime curvature is indeed local, since it is described by a tensor, the Riemann tensor, and tensors are "local" objects--they are defined in the tangent space at each point of spacetime.
However, in another sense of "local", spacetime curvature is not local, because it involves second derivatives of the metric, and in a small enough patch of spacetime around a given point, we can always adopt coordinates (local inertial coordinates) in which the effects of second derivatives of the metric are negligible.
So what would be a good name for this type of gravity? Having to say “the gravity that makes you fall into the floor” is a mouthful, and “apple falling gravity” or “apple gravity” sounds dumb.PeterDonis said:But phenomena that are referred to as "gravity" are still detectable in that small patch of spacetime--for example, bricks fall when dropped in an accelerating rocket, and this can be described, within a local inertial frame, as the rocket accelerating upward while the brick remains at rest, just as a brick falling on Earth can be described, in a local inertial frame, as the surface of the Earth accelerating upward while the brick remains at rest. All of this holds even though the effects of second derivatives of the metric are negligible within a local inertial frame, i.e., spacetime curvature is not "local" in this sense.
Very well then. A few terminology issues remain (for me) but that can be postponed for another time. What I am still hung up on is Ibis’s comments in post #12, which seem to indicate that the physics (and not just terminology) are different for the two cases of falling to the floor on the planet and falling to the floor in the rocket. If that is what he is really saying, I don't think the math will support his argument.PeterDonis said:One other note: you appear to me to be getting hung up on terminology instead of focusing on the physics. This is one reason why discussions of this sort are best done with math, not ordinary language. The math underlying everything I've said is completely unambiguous, and raises no awkward questions about what "gravity" means or what "local" means or what "spacetime curvature" means.
No. You can make the curvature tensors vanish even when the Christoffel symbols do not. Heuristically speaking, the Christoffel symbols capture the effects of both curvature of the manifold and the effects of our choice of coordinates; the Riemann tensor is built out of combinations of these symbols in which the coordinate effects cancel out leaving only the coordinate-independent effects of curvature. For example, in a Euclidean plane the Christoffel coefficients are non-zero in polar coordinates and zero in cartesian; but the plane is flat and the Ricci and Riemann tensors are zero everywhere.MikeGomez said:Is this the vanishing of the Christoffel symbols (or making them small enough to be negligible)?
"Gravity" works fine, and we can use "tidal gravity" for the non-local curvature-dependent effects. (Consider that in natural language no one has any trouble with the convention that "milk" comes from cows even though "soy milk" does not).So what would be a good name for this type of gravity?
The two cases are different. If I drop two objects from my two outstretched hands, and measure the distance between where they hit the floor... On the accelerating spaceship that distance will be equal to the distance between my outstretched hands, and on the surface of a planet it will be slightly less. The equivalence principle just says that we can make that difference arbitrarily small.Very well then. A few terminology issues remain (for me) but that can be postponed for another time. What I am still hung up on is Ibis’s comments in post #12, which seem to indicate that the physics (and not just terminology) are different for the two cases of falling to the floor on the planet and falling to the floor in the rocket. If that is what he is really saying, I don't think the math will support his argument.
I understand that. It is a tidal effect. It doesn’t mean that dropping an object from one hand is any different between the two scenarios.Nugatory said:The two cases are different. If I drop two objects from my two outstretched hands, and measure the distance between where they hit the floor... On the accelerating spaceship that distance will be equal to the distance between my outstretched hands, and on the surface of a planet it will be slightly less.
But milk from cows and milk from soy are pretty different. With gravity, it’s not like that. Perhaps more like the difference in the air between when it is blowing and when it is not, or the difference in the bath water when the water swirling or when it is not, or the difference between the electrons in AC or DC.Nugatory said:"Gravity" works fine, and we can use "tidal gravity" for the non-local curvature-dependent effects. (Consider that in natural language no one has any trouble with the convention that "milk" comes from cows even though "soy milk" does not).
Nugatory said:No. You can make the curvature tensors vanish even when the Christoffel symbols do not. Heuristically speaking, the Christoffel symbols capture the effects of both curvature of the manifold and the effects of our choice of coordinates; the Riemann tensor is built out of combinations of these symbols in which the coordinate effects cancel out leaving only the coordinate-independent effects of curvature. For example, in a Euclidean plane the Christoffel coefficients are non-zero in polar coordinates and zero in cartesian; but the plane is flat and the Ricci and Riemann tensors are zero everywhere.
MikeGomez said:what would be a good name for this type of gravity?
MikeGomez said:When he (Einstein) says that it is of no importance whatsoever that the gravitational fields in general cannot be transformed away, he is speaking about the difference between tidal gravity and non-tidal gravity. Is he not?
So then speaking in the proper language, what makes an object fall to the floor is due to the first derivatives of the metric tensor, not spacetime curvature, which are the second derivatives of the metric tensor. It doesn’t matter if the planet is round, infinite plane, or unicorn shaped.PeterDonis said:However, in another sense of "local", spacetime curvature is not local, because it involves second derivatives of the metric, and in a small enough patch of spacetime around a given point, we can always adopt coordinates (local inertial coordinates) in which the effects of second derivatives of the metric are negligible. But phenomena that are referred to as "gravity" are still detectable in that small patch of spacetime--for example, bricks fall when dropped in an accelerating rocket, and this can be described, within a local inertial frame, as the rocket accelerating upward while the brick remains at rest, just as a brick falling on Earth can be described, in a local inertial frame, as the surface of the Earth accelerating upward while the brick remains at rest. All of this holds even though the effects of second derivatives of the metric are negligible within a local inertial frame, i.e., spacetime curvature is not "local" in this sense.
PeterDonis said:Yes. Tidal gravity is the part that can't be transformed away; but the EP only refers to the other part, the part that can.
MikeGomez said:So then speaking in the proper language, what makes an object fall to the floor is due to the first derivatives of the metric tensor
MikeGomez said:spacetime curvature, which are the second derivatives of the metric tensor
MikeGomez said:Einstein is pointing out that the part that can’t be transformed away is of no consequence to how the part that can be transformed away is equivalent for the planet and the rocket.
And is that because the first derivatives of the metric tensor are transformed away?PeterDonis said:And this can be described in local inertial coordinates, where the first derivatives of the metric tensor are all zero.
PeterDonis said:No. What makes an object "fall" to the floor is that the floor is accelerating upwards and the object isn't. Or, in more technical language, the object is following a geodesic curve in spacetime, while the floor is following a non-geodesic curve that intersects the geodesic curve.
MikeGomez said:is that because the first derivatives of the metric tensor are transformed away?
MikeGomez said:The object is deflecting the planet from its freefall path in addition to the planet deflecting the object from its freefall path.
PeterDonis said:No. What makes an object "fall" to the floor is that the floor is accelerating upwards and the object isn't. Or, in more technical language, the object is following a geodesic curve in spacetime, while the floor is following a non-geodesic curve that intersects the geodesic curve. And this can be described in local inertial coordinates, where the first derivatives of the metric tensor are all zero.
MikeGomez said:It seems to be giving preferential treatment to a particular frame of reference in a relative situation.
MikeGomez said:The planet is in freefall.
MikeGomez said:Does choosing a piece of the surface of the planet as having an accelerated path have any more physical significance than selecting a frame of reference, or is there a deeper physical significance here that I am missing?
