bgizzle
- 22
- 0
Is there a formula for this? if object is 300m deep, 30m in diameter, 50,000kg, in a ball shape how long will it take to reach surface?
bgizzle said:ok, good to know the calculations i used are correct. Maybe I'm off on this but a 30 ft in diameter sphere weighing 50,000 kg doesn't seem that light or buoyant to me. maybe i am missing something.
voko said:Your own calculation implies that the net acceleration is about 10g. A typical space rocket has about 3g. So your ball will be raising very fast - so fast, that the viscosity of water will need to be taken into account if you want to model the reality closely.
bgizzle said:awesome, thanks xodin, that was exactly what i needed. 250,000 of iron would give a density of ~10cm which should hold at 1k ft depth when compared with your example. Also the ball would be rising at an average leisurely speed of 3.6mph (I am aware that none of this includes viscosity)
If someone would like to share how to include viscosity that would be fine, if not or if I am being too vague, please don't bother. I can accept this estimate is the best I can do for now and assume that my estimates are inaccurate but hopefully within the ballpark.
bgizzle said:i meant thickness of shell not density, your right.
i calculated speed based on the fact that i know the object travels ~984 feet and i know it takes ~200 seconds... is that a correct options for estimating speed?
bgizzle said:ya i was sloppy and just guestimated my conversion of seconds to minutes... i changed it to be exact and got 3.35. again thanks for the help and double checking me.
xodin said:Yep, exactly. Though it's fun to play around our ideal scenario, all of this is horribly inaccurate without taking viscosity into account. Does someone know how to do that? From the little I know about it, I believe it's very complex.
xodin said:If you don't mind helping out one more time, would you mind elaborating how the trigonometric substitution results in a hyperbolic function?
LastOneStanding said:Actually, I lied: you just have to refer to a table of standard derivatives to see that: \frac{d}{dx}arctanh(x) = \frac{1}{1 - x^2}. You can check this if you like. Your calc textbook should also have a proof of this in it. Now just rescale the variables appropriately and you get the result.
LastOneStanding said:Let's just focus on:
\int \frac {dv}{1-\alpha^{2} v^{2}}
Set u=\alpha v, du = \alpha dv. Thus we have:
\frac{1}{\alpha}\int \frac {du}{1-u^{2}} = \frac{1}{\alpha}arctanh(u)
There's your missing alpha. Not just sub u back in and multiply the \frac{1}{a} I ignored.
Incidentally, if you want to show that arctanh(x) = \int \frac{dx}{1 - x^2}, you can use trig substitution like I said—but with hyperbolic trig functions, not regular ones like you tried. Substitute x = tanh(u) and away you go. Of course, if you knew to do this off the top of your head, you could have just solved the original differential equation by inspection without all this fiddling. Solving diff eq's is as much an art as a science. Such is life.
