Time Period of SHM: Opposite Charges in Springs
The discussion revolves around calculating the time period of simple harmonic motion (SHM) for two charged springs, one with a positive charge and the other with a negative charge. Participants express confusion about the interplay between electrostatic forces and spring forces, particularly regarding how the charges will oscillate without colliding due to their attraction. The suggestion is made to use Taylor expansion to approximate the electrostatic force around the equilibrium position, although some participants are unfamiliar with this method. The importance of considering small displacements from equilibrium is emphasized, as well as the need to incorporate the changing nature of the electrostatic force as the charges move. Overall, the thread highlights the complexities of integrating electrostatic and spring forces in a SHM context.
Asphyx820
1. Homework Statement
Two Springs are present (one just infront of the other). The Spring towards the left has +Q charge and towards the right -Q charge (at their ends).The distance between the two charges is d. The Springs are of length l. Find the Time Period of the Simple Harmonic Motion if the charges are of same mass. ( l > d )
Diagram
(Wall)-->(Spring)-->+Q -Q<--(Spring)<--(Wall)
2. Homework Equations
F(elec)=(k Q^2) / (d^2) where k=(1/4)∏ε
F(Spring)=( Kl )
3. The Attempt at a Solution
I know the above two equations, but can't proceed. Is there any other force too? I can't figure out why will the charges move back again? I'm having two confusions
1) The charges are opposite so they will attract each other. When they reach a certain point they will collide (as l > d ) and move back. Is this the reason why they move back? What other equation do i have to use?
2) Is it the Spring force will pulls the charges back before they collide. But it shouldn't be true as ( l > d ) and electrostatic forces are very strong and spring force cannot overcome it. Am i right? so how should i proceed
Pls help me...
You can assume that the system is in equilibrium initially, and then you give a little push to the masses. For a simple harmonic motion, the displacement of the charged masses from their equilibrium positions must be small with respect to the distance between them. Find the time period of small oscillations with this assumption. Do not forget that the springs are connected to two opposite walls, so the sum of the spring lengths and the distance between the masses is constant.
ehild
But what about the electrstatic force. It constantly changes as the distance between the charges change. how to incorporate that. I know by intergrating the force, but then what to do?
Do Taylor expansion of the Coulomb force around the equilibrium position and keep the constant and first-order terms.
ehild
I haven't yet learned Taylor expansion. So is there any other method ?
I actually found this question in a magazine. The answer page was torn. So i don't know the answer too.
I have tried solving it 8-10 times but with no success ! (cant reach the final expansion)
I found this sum interesting so I picked it up
I would be helpful to me if you can solve the sum or give me the equations to be solved
I would be learning things both ways.
Sorry, I am not allowed to solve problems. I can only help.
It is useful to learn how to calculate with small quantities.
Suppose you have to calculate (1+a)2, where a<<1. Decomposing the square, (1+a)2=1+2a+a2. If a<<1 you can ignore the square of it at approximate (1+a)2≈1+2a. Calculate 1.0012and compare it with 1+2*0.001.
Suppose you have a fraction, 1/(1+q) and q << 1.
1/(1+q) is equal to the sum of the geometric series 1-q+q2-q3+... =1/(1+q)
If q<<1 you can ignore the terms with second or higher power, and use the approximation 1/(1+q)=1-q.
Try to calculate 1/1.001 and compare it with 1-0.001.
Here you have the Coulomb force of form A/(R+Δr)2.
Factor out R: You get ( A/(R2) (1/(1+Δr/R)2.
Assume that Δr/R<<1. Try to apply the approximations above.
ehild
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
