Time required for a liquid to change in Temp (thermo)
The discussion focuses on calculating the time required for a 355ml soda can to cool from 75°F to 38°F in a refrigerator at 35°F using the equation t = pVc/hA * LN[(T1 - Ta)/(T2 - Ta)]. The user initially used incorrect values for the convection coefficient and specific heat, leading to unrealistic results. The correct convection coefficient should be between 25-50 W/m²K, and the specific heat of water should be used in J/kg°C, approximately 4190 J/kg°C. Accurate unit consistency is crucial for obtaining realistic time calculations.
  • Understanding of heat transfer principles, specifically convection.
  • Familiarity with thermodynamic equations and their components.
  • Knowledge of unit conversions, particularly in SI units.
  • Basic understanding of specific heat capacity and its significance in cooling processes.
  • Research the principles of convective heat transfer and its coefficients.
  • Learn about the specific heat capacity of various liquids and how it affects cooling rates.
  • Explore the impact of surface area on heat transfer in cooling applications.
  • Investigate the use of numerical methods for solving heat transfer equations in practical scenarios.
Engineers, physicists, and anyone involved in thermal management or cooling system design who seeks to understand the dynamics of temperature change in liquids.
movetwice
Hi this is my first post here.
I am attempting to calculate how long it takes for a soda can(355ml) to change from Current room temperature(75F), to say 38F, however the refrigerator or ambient temperature in this case is 35F.
I was given a corollary from a friend, but the values I get in return are way off.
t = pV/hA * LN[ (T1 - Ta)/(T2 - Ta) ]
t= [(988.9 kg/m3 )(0.000355 m3 )]/[(255W/m2K)(.0277m2)] * LN[ (75 - 35)/(38 - 35)]
I attempted to use metric for all the units.
p=density
V=Volume
A=surface area
h= convection coefficient of water or the aluminum can?
T1 and T2 are the initial and final temperatures of the drink.
Ta is the ambient temperature.
However I plug-in the equation it seems to not output realistic data. I'll get something like .5 seconds depending on what variables I plug in/manipulate.
Is my equation incorrect or my units incorrect? Also are their any other better equations to do this with? This is driving me mad, please help.
Ideally I need to figure out a working base equation, as well as know what each unit is.
Science news on Phys.org
Hi movetwice, welcome to PF. Your equation has to be wrong, because it gives time in units of kg W K-1!
Presumably your friend is assuming the temperature of the liquid in the can is uniform, and the heat lost equals the heat transferred by convection:
\rho Vc\frac{dT}{dt}=hA(T-T_\infty)
which is solved to give
t=\frac{\rho Vc}{hA}\ln\frac{T_i-T_\infty}{T-T_\infty}
And the convection coefficient looks way too high. I would think 25-50 W m-2 K-1 would be more reasonable, but others may want to weigh in with their estimates.
excellent thank you!, this might be a dumb follow up question, but what is the unit for "c"?
c is the http://en.wikipedia.org/wiki/Specific_heat" .
thanks!
Alright so I'm still running into issues with this equation. I'm thinking my units are off somehow, because allegedly a can of soda is supposed to get to optimal temperature in 20-25 minutes in a freezer.
t = pVc/hA * LN[ (T1 - Ta)/(T2 - Ta) ]
t= [(988.9 kg/m3 )(0.000355 m3 )(4.186)]/[(25W/m2K)(.000277m2)] * LN[ (75 - 0)/(38 - 0)]
t= 2.12207 * 0.679901 = 1.44279
p = 998.9 kg/m3 (standard density of water)
V= 355ml = .000355 m3
C= standard C of water 4.186 J/g*C
h= 25 W/m2k
A= 277 cm^2 = .0277 m^2 (or sqm)
Any advice on where I am going wrong? I'm looking to get a working equation that will be highly accurate so I can isolate and change certain variables and get real usable time calculations.
Have you checked your units? At the end, you should be left with seconds.
H for free convection is usually not more then 5-7 W/m^2*K
Also the temperature should be in K or degC
h= 25 W/m2k
For consistent units, you need c in J/kg*C, which is about 4190.
This will change the result by a factor of 1000.
  • · Replies 22 ·
  • · Replies 19 ·
