Time resolved Photoluminescence analysis
The discussion focuses on analyzing time-resolved photoluminescence (PL) in gallium nitride (GaN) materials, specifically how to determine the lifetime decay value (\tau). The consensus is that this value can be derived from the slope of the time-resolved PL data, assuming an exponential decay model. In cases with multiple decay channels, a multi-exponential decay may be observed, which can be identified through log plots. Additionally, the choice of detector—integrating versus spectrally resolving—can impact the PL spectrum analysis.
  • Understanding of time-resolved photoluminescence (PL) techniques
  • Familiarity with exponential decay models in photonics
  • Knowledge of gallium nitride (GaN) material properties
  • Experience with data analysis and log plotting
  • Study the principles of time-resolved photoluminescence analysis
  • Learn about multi-exponential decay fitting techniques
  • Research the impact of detector types on PL measurements
  • Explore advanced data visualization methods for PL decay analysis
This discussion is beneficial for materials scientists, optical engineers, and researchers involved in photonics, particularly those working with gallium nitride and time-resolved photoluminescence analysis.
ezimah
Currently we are working on gallium nitride material where I'm required to analyze the time resolved photoluminescence (PL) result. From literature review we found that many reported on lifetime decay value [itex]\tau[/itex] so could anyone explain how to find this value. Does it come from the time resolved PL slope or there any specific equation we need to uses?
GaN has a direct band gap, so one usually just assumes that the decay of the signal is an exponential decay and the decay constant is the lifetime decay value. What may happen is that there are several possible decay channels, for example radiative and nonradiative ones. In that case one would expect a multi-exponential decay showing more than one time scale. However, this is usually already quite easy to spot in a log plot of the decay.
The other thing you might want or need to worry about is the detection. It may make a difference whether you have a detector integrating over the whole emission spectrum or a spectrally resolving one as the PL spectrum may change over the PL duration. Usually doing both is fine as long as you mention what you actually measured.
Thank for the reply.it's help me a lot.
